Results 1 to 14 of 14
Thread: Fan is Stuck
    RC Qualifier RobertZ311's Avatar
    May 2015
    420
    Fan is Stuck
    When I try to charge, the fan gets stuck and makes a super loud grinding noise while moving very slowly. I can't charge without this happening about 10 times before it works. This charger is brand new! Is there any way to fix it? Please help!
    RC Qualifier Panamon Creel's Avatar
    Oct 2014
    Central Mexico
    427
    Contact Traxxas support directly and they likely will replace it.
    May 2015
    420
    Quote Originally Posted by Panamon Creel View Post
    is there any way to fix it though? I don't want to have no charger in the meantime
    Apr 2015
    20
    What charger is it?
    May 2015
    420
    Quote Originally Posted by JudgeDredd View Post
    What charger is it?
    the ez peak 4 amp ID charger
    Apr 2015
    20
    That charger is very easy to open and take the fan out to put a drop of oil on its bearing. This will fix the problem for an undefined period of time, but in mine it was probably a month.
    May 2015
    420
    motor oil?
    Apr 2015
    20
    I'm sure you could use motor oil. I used trinity bearing oil which I had from my LHS.
    20,550
    3-in-1 oil or other light machine oil would work. Motor oil is a bit heavy for this application.
    I used Trinity Royal Oil on a MMPro fan and on a different charger's fan, both yesterday, and the difference is extreme.
    Alt-248 on the number pad =
    May 2015
    420
    Wonder if WD-40 works
    20,550
    WD-40 is a water displacer and grease solvent, not a lubricant. As such it is not recommended for this purpose.
    May 2015
    420
    I put a drop of engine oil in and it does the same thing.
    Bash the Slash!
    Dec 2006
    Argentina
    4,787
    Singer Machine Oil from sewing machines works great. I've been using it on fans since I can remember.
    1,953
    WD-40 white lithium grease and the silicone lubricant both in aerosol cans work wonders. The multipurpose aerosols are no good as already mentioned.
