Thread: Help please!
    Apr 2015
    21
    Help please!
    I finally finished building my brushless emaxx and had the first run earlier this afternoon. Well the problemnow is the braking. Everytime I run my emaxx forward and hit the brake, the truck flips forward and also it seems like it runs faster in reverse than forward. Can anyone please help me?
    Feb 2015
    82
    Sounds like the forward and reverse are "swapped". You probably need to reverse the throttle channel and then swap two of the three motor wires (any two). The ESC LED should flash green when going forward (assuming MM2).
    Proud member of the red card club.
    RC Champion NFS's Avatar
    Aug 2013
    2,097
    Recalibrate the radio and esc, if it goes in reverae when pulling the throtle just switch motor wires, you can reduce the amount of brakes using the castle link, I use 30% brakes.
    Apr 2015
    21
    I have the traxxas mxl-6s. I will try that. Thanks
    Apr 2015
    21
    Where is the ESC led on mxl?
