    Jul 2014
    121
    unlocked to load
    i just finished putting in the 32pinion ready for its run tomo can anyone tell me how tight they have there pinion mash to spur whats the best indication how free its spins ? also i bought 24 pinion today does it matter if the 24 pinon is not the same width as the spur ? as its not thats why i didn't put it in and went for the 32 pinion
    Feb 2015
    29
    My 52 tooth pinion that I bought is different than the spur and its width is different it works fine
    Traxxas xo-1
    Stampede
    Feb 2002
    9,373
    pinions are usually thinner than spur gears
    a lot of seasoned RCers can just tell what the proper mesh is, however, if you are having problems, check out youtube and a method called setting gear mesh with paper
    Jul 2014
    121
    if you throttle it then release it how much should the wheels spin if no spin then the mesh is too tight tho how much free spin should it be
