Results 1 to 38 of 38
    RC Qualifier RobertZ311's Avatar
    May 2015
    California
    420
    Slash Steering Problems
    Hi. I have a slash 4x4 that I have had for 2 weeks. It of course has the TQi Top Qualifier radio system and I am having problems with it. First off, I have to set the steering trim all the way left for it to be straight, or it drives right. Second, it makes a screeching sound when I turn right. These problems seem like they would be an easy fix but I am new to RC so I don't know a lot. Please help!
    Feb 2013
    Montreal, Canada
    5,590
    Put back your trim at 0 then re centre and re align the servo physically.
    Unscrew the servo from the link and horn. Swicth on the transmitter then the esc and making sure the settings are 0 trim. This will re-centred the servo to its end points, then you can re link the horn and arm on making sure the tyres are straight when you connect everything.
    If it still happens then chexk your bellcrank if that is fine it could be that the servo is damaged
    Live life to the fullest
    RC Qualifier Blizz318's Avatar
    Apr 2015
    BROOKLYN NYC
    670
    Quote Originally Posted by RobertZ311 View Post
    I'm also have the same problem not as bad as you but feels like it works when it wants to I was told to change the servo gears but not sure if that will work maybe we will both get the answers where looking for. These guys here know there stuff
    May 2015
    12
    When you say "screeching sounds" do you mean a clicking noise? because i have had hat happen to mine, and all i did was replace the gearing in the servo and it worked great after that! But if i'm wrong, as i always would do, look it up on youtube, i'm sure you are not the only one to have this issue.
    RC Champion soundmaster's Avatar
    2,858
    I think what he means is a buzzing sound that occurs when the servo is binding.
    First of all you have to recenter the servo by hand.
    1) Remove the servo horn
    2) set steering trim to neutral
    3) put back the horn with tires as straight as possible
    4) now only marginal trim is requred
    If now anything is binding you have to shorten or lengthen the link. I found that from the factory the links are often not perfectly set. It takes some try and error to set it right. Just take you time and dig into it
    Oct 2014
    Not here.
    4,338
    That sounds like a broken servo to me.
    Jun 2014
    Southern California
    7,912
    Before you go get a new servo, closely examine all your linkages and steering bell crank.
    Maybe a twig or piece gravel is wedged in there somewhere.
    If it is, just work it out and you should be good to go!
    Hope that was it. Cheap and easy is the best kind of fix!
    Apr 2015
    BROOKLYN NYC
    670
    Broken Servo or just gears striped I still have Control
    C.I. RC
    2,858
    True. Could also be stripped servo gears or just something got stuck in the steering mechanism.
    Both already happened to me.
    Apr 2015
    BROOKLYN NYC
    670
    So only real way to find out is just to take it apart not sure if I wanna do that I don't wanna damage the seal
    C.I. RC
    Indianapolis
    14,465
    Is it a screeching or a buzzing sound. My servo makes a buzzing sound every so often. I think it just means there is a load on it.
    Apr 2015
    BROOKLYN NYC
    670
    Yeh sum times both that and also some kinda of banging noise
    C.I. RC
    Oct 2014
    Not here.
    4,338
    Blizz. We are talking to the OP. Don't thread jack.
    May 2015
    California
    420
    Quote Originally Posted by soundmaster View Post
    Sorry, I'm new to rc. What is the servo horn?
    2,858
    The arm that is attached directly to the servo.
    May 2015
    California
    420
    No matter what I do, it STILL WONT WORK...
    2,858
    check for stripped gears next.
    May 2015
    California
    420
    The gears are not stripped, but there is a lot of grease in there. Should I scrape some of it out of there?
    2,858
    No leave it as is. With the servo detached check the steering for binding.
    Next you could reset the radio.
    May 2015
    California
    420
    I'm sorry, I'm new to rc haha, how do I check the steering for binding?
    2,858
    Place the truck upside down and move the linkage the servo attaches to. The tires should steer left and right without any resistance.
    May 2015
    California
    420
    I already did that, they do.
    2,858
    Ok than no mechanical issue. Must be the servo, receiver or radio.
    So what is the servo doing if you steer left and right without attaching it to the steering assembly?
    I am off for today. Maybe someone else can help from now. Good luck. We will find the problem for sure
    May 2015
    California
    420
    The white part on the bottom that the horn connects to moves left and right.
    May 2015
    California
    420
    I made a video of the sound it is making. http://youtu.be/gGC3dlVQkcs
    Oct 2014
    Not here.
    4,338
    Sounds like the servo saver is moving on itself. Plastic against plastic squeak. Does it do it if you hold the front end up in the air?
    part #6845 in this diagram.
    https://traxxas.com/explodedviews/Sl...Front-Assembly
    May 2015
    California
    420
    Quote Originally Posted by matts175 View Post
    No it does not when in the air, but it still makes the electronic sound as you can hear in the video. I don't know if its coming from the servo or receiver.
    Oct 2014
    Not here.
    4,338
    Sounds kind of normal to me.
    May 2015
    California
    420
    listen to it closely, it's hard to hear in the video but there is a buzzing noise
    Indianapolis
    14,465
    Every Traxxas vehicle I have ever had with the Tra2075 servo makes that same buzzing sound. That is a normal operating noise. It seems to make the noise when there is a slight load on the servo.
    Oct 2014
    Not here.
    4,338
    Yup. Normal.
    2,858
    Every Digital Servo makes that kind of noise.
  33. #33
    May 2015
    California
    420
    Thanks, now all I have to figure out is the turning right sound
  34. #34
    Oct 2014
    Not here.
    4,338
    Post #26........
    Do you get that sound if the truck is in motion?
  35. #35
    Feb 2015
    A place where I have food, shelter, shower, water, bed and internet
    989
    well, good luck
    Sl4sh, Arrma Talion, Stamp4de, Castle, MIP, RPM
  36. #36
    May 2015
    California
    420
    Post #26........
    Well, I can't hear it over the noise of it moving but I don't thinks so.
  37. #37
    Oct 2014
    Not here.
    4,338
    It should be fine to run it like that then.
  38. #38
    May 2015
    California
    420
    Alright thanks guys got my truck dialed again
