    Apr 2015
    268
    ESC Cutoff different voltage 2 lipo's
    Hi Guys,
    Got 2 5000mah lipo's and there brand new and running good (2S and 3S). Lipo cutoff on Mamba Monster: 3.5v
    I was running my ERBE today and after a while(normal running time) it started the lipo cutoff.
    Went home and after a hour I started balance charging my 2s Lipo, started from 3.2volt on both cells, looks pretty low in my opinion for cutting off.
    My 3s started on 3.7v on all three cells.
    Is this oke? Or should I check something because it's not good at all?
    Dec 2014
    Canada
    162
    Mabey try incresesing the lvc to 3.6 and then see if the problem fixes it self, could just be a one time malfuntion or a glith. If it gets ramdomly fixed it is probobly part of the battery breaking in considering they are brand new. Drive 3/4 of a pack and check your voltage with a voltage meter. Then keep checking till you are at 3.5v
    Apr 2015
    268
    Thx, will try the 3.6v first. Batteries are driven and charged 2 times.
    Apr 2015
    268
    Once again (put lvc to 3.6v) it stopped after a while. 3s still on 3.7v
    2s on 3.2 and 3.4. Tried them on my other Revo, so thinking something is wrong with that pack:S
