    Jun 2008
    Littleton, CO
    113
    Will bateries fit?
    I HAVE 2 SETS OF LIPO'S THAT I PURCHASED TO FIT MY 1/10 E-REVO BRUSHLESS. A SET OF SPC 8200mAh 2S 50C AND A SET OF MaxAmps 6000XL 3S 100C. WILL THESE BATTERIES FIT IN THE X01 WITHOUT ANY MODIFICATION?
    Eastern Shore, Maryland
    4,082
    I don't know, but if they do (you should just stick them in, and see if they fit), you won't like the way your XO runs. It's definitely happier with 6s.
    Feb 2015
    29
    Well the max amps are 6s 3s +3s = 6s
    Traxxas xo-1
    Stampede
    Feb 2015
    29
    And the 100c rate will be golden
    Traxxas xo-1
    Stampede
    4,082
    I misunderstood...I thought you wanted to use these
    some how, which I was guessing would be running 4s or if in combo with
    would be 5s.
    475
    I have two 4s 6500mah MaxAmps batterie that fit perfectly. Yours should fit, because in theory, a higher capacity 3s battery is about the same size as my 6500 4s batteries. Having said that, I can't fit anything larger without custom modding the battery trays to hold a taller or longer or wider battery. All depends on the manufacturer of the batteries.
    Jun 2014
    Portsmouth
    19
    Jun 2008
    Littleton, CO
    113
    Understood, that's why I said a "set" of batteries, I know that the sum would be 6S. Thanks
