Results 1 to 11 of 11
    RC Qualifier RobertZ311's Avatar
    May 2015
    California
    421
    Stripped bolt on slipper clutch
    So the bolt that holds on the end of the slipper clutch that connects to the driveshaft is stripped and I need to change my spur gear. I have tried everything to get it off and I can't. Do I have to buy a whole new slipper clutch?
    Jul 2014
    Dallas
    853
    What all methods have you tried? Have you gotten a small enough easyout and used that?
    Bashing Slash ultimate, 2 minis, and 5B
    May 2015
    California
    421
    Quote Originally Posted by Jrc121 View Post
    I do not have one
    Jul 2014
    Dallas
    853
    Do you have quality hex drivers or are you using the hex keys that came w the truck?
    May 2015
    California
    421
    The ones that came with it, I can't seem to find another one that size.
    Jul 2014
    Dallas
    853
    It is 1.5mm. All of the hobby brand tools carry them. Check the tip on your wrench it is probably rounded out. If you have a rotory tool cut that worn out tip off. That may help you out. But a good set of tools will keep those little screws from stripping out in the future. I love my MIP drivers!
    May 2015
    California
    421
    I took it apart backwards by putting the nut all the way against the driveshaft piece, then I pulled the little rod out. But It is still stripped on the other side.
    May 2015
    California
    421
    The Duratrax 19-in-1 tool set is more in my price range, haha!
    May 2015
    California
    421
    Just got back from the hobby store with an aluminum bearing adapter, spur gear, and the Duratrax tool kit.
    Michigan
    8,203
    Quote Originally Posted by RobertZ311 View Post
    If your going to replace the spur cut the plastic around the screw head off and use some small channel locks.
    May 2015
    California
    421
    Which screw head? I replaced the spur by taking it apart from the back.
