Results 1 to 31 of 31
    748
    Fastest gearing that will fit ?
    I have a 1/16 mustang vxl, 31/45 gearing, dual 3s battery. Tops out around 55mph
    Its running remarkably cool, I am wondering what other gears will actually fit??
    I believe the 45 spur is about all that can be done as far as spur gear is concerned.
    So pinion...... I ma running 31 now...... how much bigger can I go before it starts to interefere with sometihng ?
    Jun 2011
    Memphis Tn
    37
    32 will fit I don't remember if the 33 or 34 rubs the heat sink .but it doesn't take much to make it fit.
    Rotterdam, Netherlands
    8,617
    55mph with 31/45? Are you using larger wheels?
    RC Qualifier tmbold's Avatar
    Oct 2014
    Louisiana
    347
    I run 31/45 on 3s 55 seems really fast
    748
    I am using 4tec wheels, pretty sure there about the same size. I am also using a gyro so I can actually get the thing up to max speed. 55 is the fastest I have got with fresh batteries, 52 seems to be alot more consistent. Runs real cool so I am gonna push the envelope abit more
    748
    Quote Originally Posted by carpetman65 View Post
    Thats about what I need to know if the 33 rubs a little i assume the 34 may rub too much to compansate for....but if the 34 only rubs a little thats the one I want
    Dec 2014
    1,136
    Quote Originally Posted by knall View Post
    The 4 tec wheels are the same size. What tires r u using?
    Feb 2002
    9,352
    nevermind.....
    8,617
    Maybe I miss something but as far as I can see, 55mph with 31/45 does not only seem fast, but is simply impossible.
    May 2002
    Midvale Utah
    1,773
    The problem there is you have 11.1v as the voltage, which is much lower than the motor will see from a pair if GOOD lipos, even under load. 55 mph is easily attainable with decent packs. 65 is doable with great packs.
    Dacaur
    Aug 2015
    3
    Hey guys, I am fixing to convert my 1/16 revo to the boss. I've heard its been discontinued and I wondered if any of you could shed some light on that.
    May 2002
    Midvale Utah
    1,773
    yea the rally in all forms is no more.... you can still get the parts you need though.... sourcing the body will be the hardest (read, most expensive) part.
    Dacaur
    748
    Enough chit chat LOL. yes I am getting 55mph with dual 3s radar gun used.
    Whats the largest pinion I can slap on there?
    748
    Where can I get this calculator
    Jul 2014
    Dallas
    853
    http://www.scriptasylum.com/rc_speed/top_speed.html
    Bashing Slash ultimate, 2 minis, and 5B
    RC Qualifier Zamboniman808's Avatar
    Oct 2014
    Canada but now New Delhi
    942
    I'm not a regular on this side, but I have a merv that I bought used and the guy I got it from had the 35t pinion with it. I know it fits in the space but I have it set up to go slow with a 55t spur so I couldn't get it to fit together. The mesh screw wouldn't line up with the hole. Just wanted to offer up that a 35t will fit.
    8,617
    Even IF you would get 12.6V from your Lipos (which you don't), you would get to 53 mph. So either you are using larger tires, different gears, or your radar gun needs some serious calibration.
    Many people think that they stay close to 12.6V with good Lipos, but the voltage drop is more than you expect. The reason that I use the nominal voltage, is that you can hold that in most circumstances.
    May 2002
    Midvale Utah
    1,773
    Yikes I had thought this thread was on mini revo when i made that reply for some reason , which has a larger tire. You are right the rally won't hit this speeds on its smaller tires.
    Dacaur
    Sep 2009
    308
    I'm at 34/45 with the Tenbol mount, doesn't rub at all and I didn't have to clearance anything.
    1/10 ERBE & Rally
    1/16 MERV, KB Fiesta & Rally
    748
    Quote Originally Posted by Chris95GT View Post
    What is a tenbol mount? I tried google and nothing.
    Jan 2014
    377
    ditto what he said.
    also how are you guys mounting 3s lipos in parallel? pics w/ descriptions would help.
    May 2002
    Midvale Utah
    1,773
    http://tenbol.com/products.html tonbol mount is a big block motor mount.
    Quote Originally Posted by stick View Post
    Is this a trick question? The vehichle has two battery boxes... you just put a battery in each box... then get a parallel cable.
    Dacaur
    Jan 2014
    377
    do you have pics of your set up? what motor are you using?
    Sep 2009
    308
    No pics of that setup, that was quite a while ago that I was running the Tenbol mount. I've switched to the Traxxas mounts so I could keep a gear cover on them. On my Rally/Mustang I'm running an old Mamba Max/4600kv setup, and on my 1/16 E-Revo I'm running an SV2/5700kv 4 pole setup. They're both insanely fast on 2s and run cool no matter how many packs I put through them.
    1/10 ERBE & Rally
    Jan 2014
    377
    ordered my tenbol mount and hope to have some pics up soon. planning to run 35/43 gearing on 3s using 540 can.
    Jan 2014
    377
    got it finished up last night-got tenbol mount and changed spur to 45T.
    added my fuze 3900kv and 130a esc and running 28T pinion.
    put in traxxas tsm receiver and switched out stock heat sink plate with strc one as it allows for more adjustability.
    fresh 35wt shock oil in front.
    Jan 2014
    377
    some updates:
    finally found a pinion that will fit on tenbol mount. switching back to 43T spur helped and the biggest I can fit is 41T and it clears with about 1mm of clearance. 43t and 45T are too big...:bummer:
    this was on 3s in parallel; lipos have been sitting around for about a week.
    I think next upgrade will be a 4600kv or 5700kv
    May 2016
    8
    Love it. I think sometime in the future i want to build a e4tec
    Jan 2014
    377
    omg, this car is out of control fast with change to castle 5700kv and sidewinder esc.
    still on 3s and 41/43 gearing. will get speed tests this week.
    May 2002
    Midvale Utah
    1,773
    well yea, going from 3900kv to 5700kv, thats a nearly a 50% increase in RPM..... Dont melt your batteries....
    Dacaur
    Jan 2014
    377
