Results 1 to 21 of 21
    Jul 2013
    30
    Best aluminum castor and steering blocks?
    The only aluminum castor and steering blocks i can find are integy and atomik rc, ive heard that integy is a horrible company, is atomik worth it or no?
    Feb 2002
    9,352
    um.....
    Jul 2013
    30
    Its says that it is for the slash 4x4, and the steering block is different from the stampede
    RC Racer FMcamaroZ28's Avatar
    May 2014
    142
    traxxas ones are the best. Its the same part #s for the slash
    part numbers 6832x and 6837x
    I just bought them off DHZ and got all the bearings too.
    http://www.dollarhobbyz.com/traxxas/...ng-blocks.html
    Jun 2014
    Kansas
    3,013
    That's one thing I like about the slash hcg, stampede. They pretty much share the same parts. Wheels/tires, chassis, center drive shaft, rx box, body, front body mount, front and rear bumpers are the only things that seperate a the 2 part wise. When I searched for parts I always look in the slash area but made sure it was not for the lcg on some parts
    Feb 2013
    Montreal, Canada
    5,590
    I am using the HR C hubs for my hcg slash 4x4 mt and the traxxas carriers all arround. XO1 carriers are the preffered choice by lots of membres.
    FLM C hubs too are very strong, used them on a 2wd pede and wow....is all I can say, quality at its best
    Live life to the fullest
    RC Champion OlorinTharkun's Avatar
    near Farmington NM
    1,229
    I haven't looked for 4x4 but in 2wd, STRC makes good aluminum parts.
    What broke, uh, needs upgrading now?
    RC Racer FredR54's Avatar
    Feb 2015
    Seaford, Delaware
    167
    Thanks
    Fred
    RC Champion skmfkr's Avatar
    Mar 2014
    Savannah, GA
    1,502
    those pictured above will fit on a slash or stampede 4x4
    Nov 2014
    Bay of Plenty NZ
    250
    Do the strc rear hub carriers come with the same 3.5 toe in as the traxxas ones?
    40+ RC's, 4 = Traxxas. Doing this since the 80's.
    Aug 2014
    79
    I'm running rpm but i think i wanna switch to alum... u guys think the strc are worth getn over the traxxas? seems there double the price
    Mar 2014
    Savannah, GA
    1,502
    id just get the trx. i actually bought mine used on ebay. figured they were gonna get some scratches eventually. i might as well save some money. i just got c blocks since. ive got the tekno hub carriers. ive only broke them once and just got a new tekno plastin ones again
    RC Qualifier JohnnyHildo's Avatar
    Jan 2015
    Canada
    747
    ^ agreed. my traxxas aluminum parts have stood up well and fit perfectly.
    sl4sh 2200 / p4de 2400
    Jul 2013
    30
    So i did end up getting the traxxas steering and caster blocks. Sadly, it did not fix the issue i was hoping it would but i wouldve gotten aluminum ones eventually anyways lol
    Jan 2015
    Canada
    747
    Quote Originally Posted by jeff fa fa View Post
    yes because your binding issue is in your steering bellcrank. i would consider pulling it all apart and reassembling.
    none the less, the caster blocks and c hubs are good places to use aluminum.
    May 2013
    205
    Just exactly what kind of issue are you having? I have the atomic at one point but the quality was about the same as Integy. The traxxas ones are the best you could ever get eventhough theirs a little bit of play up front but with longer e-maxx pin and teflon washers will take the play away.
    Jul 2013
    30
    Quote Originally Posted by Pedro Penduko View Post
    My steering is completley screwed over, i can fully turn one direction but hardley turn to the other, but after finding out that the caster and steering blocks, helps but didnt eliminate the issue, i went ahead and bought the strc bellcrank, its supposed to come in tomorrow (the 4th) so after installing that i will see how evreything turns out and will come back with an update
    Jan 2015
    Canada
    747
    i run an strc and would advise that you don't tighten the pillar or drag link screws down until they bottom out or you'll find binding issues there too. mine are on a couple of turns short of bottomed and i recommend blue loctite on all of the screws as well.
    Jul 2013
    30
    So i installed the strc aluminum bellcrank, no luck, but i can definitley tell the binding is occuring withing the bellcrank butbi cannot determine what exactly is causing it. Any specific things i should check into?
    Jan 2015
    Canada
    747
    well if you replaced the steering bellcranks than everything in them should be brand new. however, you do re-use the stock bellcrank bearings.... did you check them? if it isn't the bearings i would remove the links to your caster blocks and individually rotate them by hand to see if anything is hanging up. there are also instances of people finding the aluminum to aluminum parts sticking but on a brand new part i can't see that happening yet.
    past this it is out of my hands as there aren't really that many parts to go through and assuming you've installed everything correctly shouldn't be difficult to diagnose an issues cause.
    Jul 2013
    30
    Quote Originally Posted by JohnnyHildo View Post
    After taking out the the toe links and moving the bellcrank, it moved smoothly, but ince i move the tires it was very tight. So took the steering block out, and it looks like i got some loc tite on the non threaded part of the screw, but after removing excess loctite, it seems to all work smoothly. But wont know for sure until my replacment stub axle comes in tomorrow (the 4th meant the 3rd last time lol). So hopefully everything will run great! Thanks for all the helps guys!!
