Results 1 to 2 of 2
Thread: charger
    Dec 2014
    34
    charger
    can traxxas 8 amp ez peak 100 w dual battery charger be able to charge 9000 mah 60c battery?dont i need at least 9 amp to charge at 1c?
    RC Qualifier Panamon Creel's Avatar
    Oct 2014
    Central Mexico
    427
    The EZ-Peak dual battery charger has a 100W or 8 Amps limit (whichever comes first) so on the high output channel you'll get 8 Amps max. (2S or 3S) if you charge on that channel only. 1C general charging is the max. recommended for LiPo but you can also charge at less than 1C, just takes a little longer.
