Page 1 of 2 12 LastLast
Results 1 to 40 of 65
    Indianapolis
    14,242
    Third times the charm!
    I have another El Sob special motor to go with the El Sob esc! I love this motor system and I am determined to make it work again
    RC Champion Dcuda69's Avatar
    Jan 2015
    WI
    2,973
    Good luck!! Hope this one lives a long happy life!!
    Slash 4x4 Ult 2150kv
    Rustler vxl
    Ford GT vxl
    Indianapolis
    14,242
    Thank you Dcuda! As I always do with a new motor, I did the foam mod to keep dirt and other contaminates out of the bearing. I am going to be running a 19 tooth pinion and a 50 tooth spur.
    Jun 2014
    Southern California
    7,590
    Good luck with this one.
    As you said... third time's a charm!
    Crossing my fingers that it's not like baseball... three strikes and you're out!
    Indianapolis
    14,242
    One thing that I love about the Slash 4x4 is how easy it is to install motors! I am already finished and when the heat goes down I will give it a proper test drive
    May 2013
    205
    No offense but, how is this become ElSob special when this motor come stock on Funny Car? other than that, enjoy your new motor
    Indianapolis
    14,242
    El Sob special is its nick name. I have run this motor system for well over a year! It's been great until recently when I broke two motor shafts.
    Jun 2014
    Southern California
    7,590
    Matts dubbed it the "ElSob Special" in his thread and it stuck!
    "I'm calling this one the "El Sob Special". This is his absolute favorite. Through his recommendation, it's the one I run."
    https://traxxas.com/forums/showthrea...uy-quot-thread
    May 2013
    205
    ohh!! sorry to hear that and I see why its third times the charm, I wish castle bring back their 5mm rotor kit.
    Indianapolis
    14,242
    Quote Originally Posted by Pedro Penduko View Post
    If they would, I would jump on it with all four feet! This is a great motor system, I've just had a little bad luck
    Feb 2015
    63
    I am going to be building a slash 4x4 MT Aand watching this thread.
    Keep us a to date
    Feb 2013
    Montreal, Canada
    5,590
    Back on the field...looking good El Sobn sound great....
    Live life to the fullest
    Michigan
    8,203
    Good luck ElSob, I have faith in it, I run three of them and have never had any issue besides front bearings ing the motors.
    Pro Mod confirmed he too had replaced them with a much better bearing has has had trouble free 2400kv's since.
    I believe he run a few of them as well but dont quote me on that.
    Indianapolis
    14,242
    She is ready to go for a good run! I rebuilt the rear differential, oiled the bearings, stretched the springs for optimal performance and rotated the tires! Tomorrow I will take her out and see what her new motor can do
    368
    Just an idea here but you should try to run it without the foam stuffed into the motor. Hasn't each one broke right after the bearing? And also don't you only run on pavement anyway? What's the point in the foam mod if you don't run in dirty conditions. That is my suggestion to start ruling out causes. I know it is probably very very minimal but that foam probably does create a little extra heat right at that spot with friction. How tight do you run your slipper? Could your motor shaft be the weak link since you have very grippy tires, strong axles, and stong differentials?
    Ultimate Slash 4x4, HCG Slash 4x4, Ruckus 2wd
    Jan 2015
    WI
    2,973
    Quote Originally Posted by wfburton159 View Post
    Some good thoughts there for sure. I was thinking about gears....ElSob weren't you running 20/50? Any possibility that big(diameter) 20t pinion is too much for the small shaft? Has anyone had shaft failures with a 18 or 19t gear? I'm running 18/54 on 3s without issue(so far) bashing hard in grass/dirt/asphalt. Just thinking out loud here as I really like my ElSob 2400kv and would like to keep it alive as long as possible!
    Rustler vxl
    Ford GT vxl
    Feb 2015
    A place where I have food, shelter, shower, water, bed and internet
    989
    hey el sob, which tires are those?
    Sl4sh, Arrma Talion, Stamp4de, Castle, MIP, RPM
    Aug 2012
    Invercargill, New Zealand
    89
    Hi el sob sorry for asking (as it has probably been covered elsewhere) but what esc are you using to power that beast of a motor?
    Indianapolis
    14,242
    The foam isn't stuffed in the motor. It is a thin sheet that goes across the top. I put a liberal amount of oil on it. The last 2400 motor didn't have one. I was in Indianapolis when I installed it. My slipper is not too loose but not locked down. As in weak link, the first motor lasted more than a year. The second didn't last two months.
    RC Qualifier NoobPlayer03's Avatar
    Sep 2014
    New Jersey
    259
    Hopefully the new special will work out for ya, let us know how it goes!
    Aww, SNAP. You crashed into the curb at 100mph.
    368
    Ok foam doesn't seem to be the problem. Hopefully this one will give you another year of performance. That might be the life of them for you. Nothing will last forever. The second motor was a used one right?
    Oct 2014
    Not here.
    4,339
    I wonder if it would help at all to run a 1/8" to 5mm shaft adapter and then run 5mm bore pinions?
    Feb 2013
    Montreal, Canada
    5,590
    Quote Originally Posted by matts175 View Post
    I run a HR pinion with an adapter for my El Sob special as all the pedes came with 3mm shaft before. I do not know if helps but I know I have nvr had a problem with it....
    Michigan
    8,203
    I have to be the odd man out again and say while I agree the motors are pushing a lot of power for a 3mm shaft I've never had an issue with any of my three, I'll add they get put thru the ringer as well.
    I ran 5s thru one and that same motor runs fine to this day.
    I have found the output shaft bearings get loose in a hurry and fine myself changing them more then I would on most other motors, (2200 and 2650 cc) you can hear them before they show any play.
    While I think ceramic bearings are over kill in an rc, should I ever break a 2400 3mm shaft I will follow Pro Mod's idea and replace the output shaft bearings with ceramic.
    It wouldn't take much for a bearing to start getting loose and let a piece of debris in between the pinion and spur
    This has happened with much less powerful 540 can motors as well.
    Then there is the outside chance a bad batch of hardened steal got past QC at castle, unlikely but not impossible.
    Jun 2014
    Southern California
    7,590
    Quote Originally Posted by Jelle318 View Post
    JConcepts G-Locs
    https://www.jconcepts.net/shop/glocs...-30-x-22-wheel
    Indianapolis
    14,242
    https://youtu.be/axMF5Bz1SNs
    My first run with the new El Sob 2400 motor! It was also my daughter's first time as a camera person! She's alive!!!!
    Jan 2015
    WI
    2,973
    Yay!! Hope it hangs in there. What gears are you using now?
    Rustler vxl
    Ford GT vxl
    Jun 2014
    Southern California
    7,590
    Good to see your rig up and running... when is Violet's rig making it's debut?
    368
    That would be one requirement of running a camera! Hopefully the motor lasts a little longer this time.
    Michigan
    8,203
    I know your mod does a great job of keeping the dirt out, but perhaps for a while and being its a ten minute job, maybe pulling the motor and checking the front bearing every four or so packs might be worth the time.
    Thats the motor I'm running in my sand build but am running a team associated slipper with pro-light 32p spur and RR hardened pinion
    Jun 2014
    Portsmouth
    19
    <iframe width="560" height="315" src="https://www.youtube.com/embed/mFYJHIQQ9gw" frameborder="0" allowfullscreen></iframe> 2400kv 4s 17p 40s
    Jun 2014
    Southern California
    7,590
    Quote Originally Posted by Redman10x View Post
    Here's your vid:
    but why did you post it on this thread? Just wondering...
  33. #33
    Feb 2013
    Montreal, Canada
    5,590
    Nice run. I am thinking of getting ceramic bearings on my electric rigs , just put some on my revo and wow...just awsome feel, so smooth...well it feels that way....
    Eh El Sob you may want to try the 2650 and 2200 to one day.
  34. #34
    Indianapolis
    14,242
    Violet did a much better of being my camera girl today! It is my birthday https://youtu.be/4tmSj3GCevk
  35. #35
    Apr 2013
    Portland, OR
    1,389
    Happy birthday, El Sob! Violet did a great job!
  36. #36
    RC Qualifier Fordbronco1995's Avatar
    Jan 2015
    Cleveland TN
    744
    Nothing relaxes me more after working on my rig than a nice game of candyland
    Happy birthday
  37. #37
    Feb 2013
    Montreal, Canada
    5,590
    Happy birthday, looks like you had a great time
  38. #38
    Oct 2014
    Not here.
    4,339
    Happy Birthday!!!
  39. #39
    Apr 2014
    south jersey
    274
    Happy birthday
    slash 4wd upgraded
  40. #40
    May 2015
    Melbourne, Australia
    45
    Happy birthday mate!
    Slash 4x4 Ultimate
