Page 22 of 22 FirstFirst ... 12202122
Results 841 to 858 of 858
  1. #841
    Sep 2016
    Champaign, IL
    10
    Outstanding thread guys. Thanks to everyone that asked and answered questions. So much use able info. I probably have 40 screenshots for easier reference lol
  2. #842
    RC Turnbuckle Jr. GeneralPede01's Avatar
    Sep 2015
    Toomsuba, Ms
    3,187
    Quote Originally Posted by illiniharrison View Post
    Thanks, I never expected my thread to have this many views and replies lol.
    Triple digit club member!
    100mph pede 4x4
    116mph Mamba Rustler
  3. #843
    Dec 2015
    St. Peters, MO
    3,333
    Quote Originally Posted by GeneralPede01 View Post
    100mph pede 4x4
    Mr humility!!! Lol You rock my friend.
    Sent from Eastern Missouri
  4. #844
    Sep 2015
    Toomsuba, Ms
    3,187
    Quote Originally Posted by Briber View Post
    Lol thanks I do what I can
    100mph pede 4x4
  5. #845
    RC Qualifier NOFTCHX's Avatar
    May 2015
    New Hampshire, U.S.A.
    819
    hey general how come you went back to nylon/plastic steering hubs and c-blocks for the front and back to plastic in the rear? did the aluminum parts not hold up or what made you put them other parts back on?
  6. #846
    Sep 2015
    Toomsuba, Ms
    3,187
    Quote Originally Posted by NOFTCHX View Post
    I switched backed to plastic hubs in front, because after awhile with aluminum on aluminum it's eats itself away and causes a lot of swap. I done the bearing mod and that helped. I just wanted to try the hot racing and rpm combo since hot racing castor block have adjustable screws to help eliminate castor and hub slop. I still have rear aluminum hubs.
    100mph pede 4x4
  7. #847
    May 2015
    819
    ohh no doubt. what bearing mod did you use? I just got fast eddy bearings and am working on putting those in on top of other mods like the dynamite temperature recording system and others, I love the wrenching and the after of seeing your work. What did you use for bearing mod? When you used the hot racing with the rpm did you need to use washers or shims?
  8. #848
    Sep 2015
    Toomsuba, Ms
    3,187
    https://traxxas.com/forums/showthrea...-reduction-mod
    Link to the bearing mod, didn't use washers or shims. Hot racing castor come with a set of bushings.
    100mph pede 4x4
  9. #849
    May 2015
    819
    I remember reading that, I thought you meant you did all new bearings all around. What degree do you have the rear aluminum hubs?
  10. #850
    Sep 2015
    Toomsuba, Ms
    3,187
    Na I just done the bearings for the aluminum blocks and hubs. I have mine reversed so it's at 1 degree.
    100mph pede 4x4
  11. #851
    May 2015
    819
    have you ever tried them normal with 4 degrees? IF so what do you think performs better with the hot racing and rpm setup? (The rear set at normal or the rear set at reverse?) Just wondering have you ever switched out the bearings at all?
  12. #852
    Sep 2015
    Toomsuba, Ms
    3,187
    Yes when I very first installed them I had them at 4 degrees till I found out you could switch them around to change the degree. I like it at 1 degree, but not everyone does. Not sure what your asking about the bearings. If your asking if I've wore out bearings and changed them then yes, if your asking if I've switched brands then no, I still use traxxas bearings.
    100mph pede 4x4
  13. #853
    May 2015
    819
    you answered what I asked man thank you. I'm with you and I prefer my rear at 1 degree also, I feel its more stable. What is your thoughts on running mod 1 gears in place of mod .8 gears? I have 9tooth all the up to 24 tooth pinion gear in mod 1 and 36tooth to 40 tooth spur gears and I wanted to possible always run mod 1 in place of the mod .8. I thought put the 9t pinion on and 40t spur to start and if its ok then keep or move up in pinion if need be. What is your thoughts(and anyone else that would like to add I thank you general and everyone else out there.) on doing that to my p4de with a mamba monster x 2650kv system?
  14. #854
    Sep 2015
    Toomsuba, Ms
    3,187
    Me personally see no need to use mod 1 gears for bashing, 32 pitch/.8 mods gears will do just fine. Only time I used a mod 1 setup was for speedruns only.
    100mph pede 4x4
  15. #855
    May 2015
    819
    ohh. do you know of people running mod 1 gears all the time? when you put together the front steering hub assembly did you use any grease or oil when you put it together?
  16. #856
    Sep 2015
    Toomsuba, Ms
    3,187
    Some ppl do, it's not necessary but if you want to run mod1 gears all the time you can. No I use any grease to put front hub assembly together.
    100mph pede 4x4
  17. #857
    May 2015
    819
    fair enough man thanks for now.
  18. #858
    Sep 2015
    Toomsuba, Ms
    3,187
    No problem, and hope you get it all going good.
    100mph pede 4x4
