    Aug 2015
    NSB FL
    136
    Run Two Batteries At Once?
    Hey Guys,
    I just got this new Traxxas Y parallel connector and was wondering if it would be fine running two batteries at once. It would probably be a Venom 9.6V 5000mah battery and a Traxxas 8.4V 3000mah Stock Battery. Is this fine to run?
    Feb 2013
    Montreal, Canada
    5,590
    You could run two batteries in serries using a y connector or one made by yourself idaly with just as large wiring as the esc.
    Batteries should match in their discharge rating . You could always use a 2s lipo with ac3s lipo of 5000 mah 35c ...as an example.
    With Nimh, not too sure. But a mismatched discharge rate in the lipo could have disastor lingering on the corner.
    Live life to the fullest
    Oct 2014
    Not here.
    4,339
    Quote Originally Posted by Doogamaster2817 View Post
    Hey Guys,
    Nope... it will not work properly and might cause some damage.
    RC Qualifier Panamon Creel's Avatar
    Oct 2014
    Central Mexico
    427
    Hey Guys,
    A parallel connection require that the voltages of the batteries are matched otherwise the lower voltage battery gets overcharged by the higher voltage one which may cause damage to the lower voltage battery.
    Indianapolis
    14,240
    If you want more power, switch to a Lipo. Nimh are just not capable of delivering the kind of power of a Lipo.
    Feb 2002
    9,390
    also, you are adding a whole bunch of extra weight... just run 1 battery, then when it dies, swap it for the other battery
