Results 1 to 17 of 17
    RC Qualifier RobertZ311's Avatar
    May 2015
    California
    421
    From caster block install
    Hi, I have aluminum front caster blocks coming, but I have plastic steering blocks. My question is, do I need loctite on it using plastic steering blocks?
    Bash the Slash!
    Indianapolis
    14,198
    I have plastic steering knuckles and aluminum C hubs on my daughter's LCG Slash 4x4. It seems like it will work well. I am close to having it running
    May 2015
    California
    421
    Oops. Sorry, my phone auto corrected loctite to picture. Do I need loctite on the screw because it is going into the plastic steering block?
    Bash the Slash!
    Jul 2003
    70
    I thought loctite on a screw going into plastic caused degrading issues with the plastic? I could be wrong but that's what I remember reading somewhere.
    May 2015
    California
    421
    Quote Originally Posted by tnafe View Post
    Yes that's why I'm asking, it goes in metal AND plastic.
    Bash the Slash!
    Sep 2015
    2,198
    I thought I tried this, aluminum blocks and plastic spindles, and thought there was something wrong and they don't mate properly. In any case, my aluminum blocks broke pretty quickly (both sides) and I never bought them again.
    youtube.com/c/RazorRCvideos
    May 2014
    56
    Just locktite threads going into metal not plastic. Plastics will hold the screw from backing out but if it get loose and backs out I put a small amount of white pipe tape on the threads to keep them from spinning.
    Indianapolis
    14,198
    Quote Originally Posted by RazorRC22 View Post
    Do you mean the C hubs or steering knuckles? On the 2wd Slash I know exactly what the steering blocks are. On the Slash 4x4 the front end is C hubs and steering knuckles if I'm not mistaken.
    May 2015
    California
    421
    So do I loctite or not?
    Bash the Slash!
    Sep 2015
    2,198
    Maybe I'm using the wrong terminology, but Traxxas calls the outer part (squarish thing that moves up and down) the caster block. That's what I meant by aluminum block. The inside part that moves with the axle in it I refer to as the spindle, I think that's the automotive term:
    https://en.wikipedia.org/wiki/Spindle_%28automobile%29
    I see that Traxxas calls it the steering block. OP got it right!
    Sep 2015
    2,198
    Quote Originally Posted by RobertZ311 View Post
    No. As long as it's threaded into the plastic, it is not supposed to move.
    May 2015
    California
    421
    Ok, thanks for the straight answer.
    Bash the Slash!
    RC Champion soundmaster's Avatar
    2,858
    Never use loctite metal to plastic! Only metal to metal.
    if you have issues screws backing out from plastic you can use litte ca-glue.
    Jun 2014
    Kansas
    3,013
    I call that a steer knuckle. The piece that goes through the knuckle that holds the wheel hub on I call that a spindle. Mostly found on trailers and 2wd vehicles. I might be wrong on terminology but that's what I call both pieces
    May 2015
    California
    421
    Got everything on and drove it. Feels nice. Thanks guys!
    Bash the Slash!
    Sep 2015
    2,198
    The red looks good!
    May 2015
    California
    421
    The red looks good!
    Thanks!
    Bash the Slash!
