Results 1 to 39 of 39
    Jun 2015
    Brossard, QC
    1,211
    IllusionX's E-Revo
    Alright just showing off my E-Revo. It's a brushed E-Revo converted to brushless.
    The day I got it..
    And its early Christmas here.. I've got tons of parts for both my ERBE and MERV.
    Feb 2013
    Montreal, Canada
    5,590
    Very nice, I would have gotten the duratrax screws, after having had lots of rcscrewz stripping on me;
    Are you going to eventually dye the chassis.
    Live life to the fullest
    Jun 2015
    Brossard, QC
    1,211
    Yeah, I didn't know about the rcscrewz, cuz my cousin runs the same on his summit.
    Everything is going to be moved to a new chassis, and I'm debating if I should dye it.
    Oct 2015
    10
    Sweet. Truck is looking nice!!! Tires tapped and all that good stuff? I'm new to this side of the hobby, but brush less seems to be the optimal method for power. Which is awesome because that what I happened to get the first go around luckily.
    Quote Originally Posted by Jezza View Post
    What all sizes do you have? Or is that 2 broad of a question.
    Feb 2013
    Montreal, Canada
    5,590
    Quote Originally Posted by tunedis95 View Post
    Welcome to the hobby as well,
    In fact duratrax has ready set of stailess screws for the slash 4x4, I had so many spares and luckily traxxas uses almost the same screws in all their tracks so with the extras I put in my erevo, measured them out according to the exploded views and then used it on my erevo.
    I got mine off the lhs , so I can imagine you could buy the ones specificaly as a set for the erevo.
    ST screws are not really recommended as they are weaker, I do no think I will be doing other in st screws for a while
    Jun 2015
    Brossard, QC
    1,211
    Oh, I haven't driven those Road Rage tires really. They are way out of balance, and I have no idea what the previous owner did to them. Supposed to be very new.
    For now, I am driving on trencher X.
    Since I got so many new parts. I started stripping the old chassis.
    Before..
    Stripping..
    Chassis out, and these drive shafts has to go.
    Traxxas constant velocity. I also did not install the new bulk heads. Figured I would when I replaced the diffs.
    Reassembled. Look at this beauty.
    Completed with all stainless screws.
    I have no complaints with the rcscrewz, except for the 2mm hex, which are made a tiny bit larger than traxxas screws, so it's super easy to strip a hex or the hex tool. But I don't think any of the screws would snap. Next I would have to replace all the 10mm and longer 2mm hex screes by better quality.
    I'll update again when I install the GPM steel drive shafts.
    Edit: just commenting on my suspension setup, and honestly, I don't think I would buy used again. Ever.
    The front shocks seems to be variable damping. I guess I'm going to have to shop for new shocks.
    Jun 2015
    Brossard, QC
    1,211
    Question, should I use the integy servo guard or the original traxxas? The integy part doesn't fit 100%, I have to trim a bit of the chassis to install.
    There is also a funny crack on the middle skid plate. Part is ordered, so I will replace that...
    Feb 2013
    Montreal, Canada
    5,590
    The tock guards are very strong, untill now I havenot changed them at all.
    I avoid integy all togther, save on a high torque servo and buy strc single servo arm.
    I would would like to try the strc carriers one day though its not neccessary, as for skid plates and servo guard, I preffer the ones from strc, they are under slayer parts...thos are practically the same except for the arms.
    Jun 2015
    Brossard, QC
    1,211
    Yeah, I just installed the original ones. But the integy front and rear skid plates are super strong. They were already on the car when I bought it.
    I also installed the GPM drive shafts, I'm not sure I like them.
    Jun 2015
    Brossard, QC
    1,211
    Found a beautiful place to bash. They are building a road there.... Please of ore the lake, it was raining the whole week last week and today. Water accumulated there.
    But then, my truck didn't last me 5mins. The motor seems to have loosen up and stripped the spur gear. And then clutch pads also cracked. They are new! Not even broken in.
    Should I get a new motor mount? The hole seems to have worn down..
    While I have this torn down, might as well look at the transmission bearings. I noticed some strange noise when spinning it by hand. They are dirty indeed.
    This truck is a money pit, and I'm starting to regret getting this used.
    Jun 2015
    Brossard, QC
    1,211
    Alright, received my parts today. But I'm having a tiny issue.
    Brand new motor mount.
    Heavy duty clutch...
    Installed.. So beautiful!
    Here is the issue... The cover is rubbing!!
    The spur gear seems really close to the motor...
    Sep 2008
    Turks and Caicos Islands, BWI
    657
    Yes. It will not be a problem. This area on the E Revo is pretty close fitting.
    Ray00
    E–Revo │ E-Revo BE
    ITCHY THROTTLE FINGER!
    RC Champion soundmaster's Avatar
    2,858
    nice how much kv is the motor?
    Jun 2015
    Brossard, QC
    1,211
    Quote Originally Posted by Ray00Ray View Post
    But if I put on this cover, it is rubbing. Should I just let it rub? It will eventually fit right? Lol
    Jun 2015
    Brossard, QC
    1,211
    Quote Originally Posted by soundmaster View Post
    The motor is a 2650kV 6 poles.
    Aug 2015
    116
    can you dremmel the rubbing?
    Jun 2015
    Brossard, QC
    1,211
    Quote Originally Posted by jvinhj240 View Post
    I just left it. It continued rubbing and now no more.
    Jan 2014
    Edmonton, Alberta
    22
    Quote Originally Posted by IllusionX View Post
    Umm Brother?
    Feb 2013
    Montreal, Canada
    5,590
    Hey man with winter settling in, its true we still have not have a bashing sssion. That place you got on the pics looks intersting.
    Will see on sunday if its good weather....
    Jun 2015
    Brossard, QC
    1,211
    Quote Originally Posted by Lunarlancer View Post
    Umm Brother?
    Haha nice! Is yours brushed? I cause mine was converted from brushed.
    Jun 2015
    Brossard, QC
    1,211
    Yeah, but they are building there already. I'm not sure if we can go there anymore. Perhaps at the BMX track.
    SMS me if you want to bash. Only problem now I have 2 lipo only. I sold all my gens ace with the stampede lol.
    I am waiting for 2 more packs to arrive, but seems to take forever.
    Oh, and I got the new gears so I can rebuild the rear diff. Though, I also did not receive the shims to shim the diff....
    Feb 2013
    Montreal, Canada
    5,590
    Yup will sms you, I have to take my 1:1 truck to the garage first, hopefully it wont take too long
    I got some of the traxxas shim so aill take them with me
    Jun 2015
    Brossard, QC
    1,211
    So, after a crisis.. I sold off most of my RC and quit Traxxas.
    I came back with a MERV and wanted something big I can bash AND race at the same time. I was about to get an Arrma Talion or something.. maybe an RC8.3Te, and this came up I couldn't pass.
    For 200$ CAD I got this roller. So here is the official ERBE X2.0
    This is going on a surgery for a complete clean up and verification before being built!
    Sent from my SM-G930W8 using Tapatalk
    Jun 2015
    Brossard, QC
    1,211
    So the surgery has begun...
    It has a brand new bulkhead
    First, inspect the diff and change the oil.
    The ring and pinion gear is pretty nice. Uh oh! The bearing is chipped. Cheap fix.. new bearing.
    The E-Revo being originally brushed, the dff doesn't have the I beam. I'll definitely add it next time I rebuild the diff. It much oil left either.
    That's it for the night.
    Jun 2015
    Brossard, QC
    1,211
    So I went shopping.
    Bought motor mount/slipper set
    Servo saver
    Complete RPM a arms set in black
    Pivot ball caps
    SkyRC TS150 ESC
    GoolRC 4274 cans size 2000kV sensored motor
    Jun 2015
    Brossard, QC
    1,211
    I did more work last night. Pretty clean overall. But I have the diffs without the I beam in the middle. Anyways, some pictures for the show..
    Stripped
    Cleaned the chassis and put the transmission back in
    Same as my previous one, the fins are gone to make place for the battery leads to come out.
    Lazy to rebuild the old shocked, I installed this pair of Revo shocks I had previously rebuilt a long time ago. I kept them when I sold my old one because I thought silver looked better haha
    Center shaft in
    It was getting late, so I stopped here. I am also waiting for my parts to come in!
    Jun 2015
    Brossard, QC
    1,211
    This just came in. Debating installing it or not. Note that I WILL be racing my ERBE.
    Jun 2015
    Brossard, QC
    1,211
    All the shocks and sway bars are in.
    Just waiting for my RPM a arms to arrive Monday!
    Not sure what to I do now, I'm idle waiting for parts now.
    RC Qualifier RCMad72's Avatar
    Dec 2016
    Hillbilly City, Texas
    323
    Looks pretty good! If I were you I'd put the center diff in if you're gonna be racing it.
    if you fall, I'll catch you! - Your Floor
    Jun 2015
    Brossard, QC
    1,211
    This is somewhat another money pit. LOL
    Cracked shock holder and rear body mount. So, these parts are ordered and also ordered the rear chassis brace while I'm at it. I must be at around 600$CAD spent now.
    RC Racer ZUMA's Avatar
    Aug 2010
    Chicago, IL
    228
    Nice build
    Is that center diff in the new brushless models? Or an upgraded one?
    Jun 2015
    Brossard, QC
    1,211
    Quote Originally Posted by ZUMA View Post
    Nice build
    Every E-Revo comes with a locked center. This is the optional part to add a center diff.
  33. #33
    Aug 2010
    Chicago, IL
    228
    Wow really, I didn't know. I got a brushless revo and thought I remember reading in the manual about there being something about 200k or something in the center diff. Thanks for the info I'm going to have to look into that, here I'm thinking I have a center diff. I'm still a newbie on the revo got it a few months ago and haven't been out much because winters been keeping me indoors.
  34. #34
    Jun 2015
    Brossard, QC
    1,211
    Woot! T-maxx brake disc for slipper pad and RPM a arms all around!
  35. #35
    Jun 2015
    Brossard, QC
    1,211
    So I'm still missing the pivot ball boots to finish my install.
    T-Maxx brake disc as slipper pad
    I think it looks better than alu pads here.
    I think the previous owner had a pretty bad crash. No wonder the new bulkhead that was installed. No I'm not bending this back.
    I still have a brand new one from my previous build.
  36. #36
    Jun 2015
    Brossard, QC
    1,211
    It's Monday. Parts are coming in again.
    One at a time lol
  37. #37
    Jun 2015
    Brossard, QC
    1,211
    I did some more today. And realized that I need 2 sets of the #5378x rubber boots.
  38. #38
    Jun 2015
    Brossard, QC
    1,211
    I had to buy another one like this. When you realize you need 2 packs to complete the truck. LOL
    Well, at last, my ERBE is done!! Just missing the ESC and motor, then I can go on and adjust the camber and toe.
  39. #39
    Apr 2007
    Long Island, NY
    320
    IllusionX's E-Revo
    I agree used RCScrewz and the heads strip very easily ...
