Results 1 to 27 of 27
    Alfredmadere
    Guest
    pro 4 hd and rx8 mounting and setting up
    So i have about 350 to 400 dollars to spend on a motor and esc for racing and i have done some resurch and found that the rx8 and the pro 4 hd are my best bet at the moment. but i would like to know how hard it is to mount both of these in the lcg chassis, also do i need anything else other then the motor and esc, do i need wireing? or does that come with it.
    thanks in advance guys!
    RC Champion thesmogman's Avatar
    Oct 2013
    Dublin, CA
    1,249
    If buying new everything is included. The pro4hd motor's are about 3/8" longer than the normal 540 can motors. Since you are not waterproof anymore you can lose the receiver box and just mount the receiver to the chassis. I have plenty of wiggle room still.
    I just two sided taped the esc and reciever down and added Shoe-goo to the corners for reinforcement.
    Are you going with the 4600kv or the 3500kv?
    Alfredmadere
    Guest
    Quote Originally Posted by thesmogman View Post
    i am going with 3500 kv because the track i run on is only 90 x 50
    Michigan
    8,203
    Sounds like you'll have a heck of a system.
    Best of luck to you.
    Sep 2015
    2,198
    An esc mount for your chassis will make it super simple to mount:
    http://www.amainhobbies.com/rc-cars-...lsIaAkgT8P8HAQ
    youtube.com/c/RazorRCvideos
    WA - PNW - USA
    704
    Consider the Hobbywing 3656sd (4000kv) it's a great motor I have one in my sct410 tons of torque and runs super cool. Also don't be afraid to check out the SMC SC motor. I have a 4300 Pro4HD and its ok but I actually prefer the HW. The RX8g2 is an awesome ESC, I have 2 of them and as long as you buy new and know how to solder it is bulletproof.
    slash 4x4
    Alfredmadere
    Guest
    rx8 and pro4hd and savox servo arrived today!!! i will be telling you they perform once my pinions arrive.
    i'll post some pictures!!!
    Alfredmadere
    Guest
    savox servo
    stickers!!!
    pro 4 hd motor in box
    pro 4 hd motor out of box
    rx8 gen 2 esc
    Alfredmadere
    Guest
    sorry about the picture quality, i was using my computer
    Apr 2013
    Portland, OR
    1,389
    Great pics, Alfred! How much did the new setup end up costing you?
    Michigan
    8,203
    Nice looking bath of toys the post man brought you today.
    Best of luck with everything.
    Jun 2014
    Southern California
    7,567
    Very nice... Congrats!
    Alfredmadere
    Guest
    Quote Originally Posted by OSU Beaver 99 View Post
    for all of that it cost around $400
    Alfredmadere
    Guest
    ha ha, yeah currently having a little trouble figuring out how to solder 5 hubs with the 3 wires they give me...
    Oct 2013
    Dublin, CA
    1,249
    Just cut the battery leads from your other esc. Problem solved!!
    I am jealous of that motor. Will you buy me one?
    Just kidding.... you are going to enjoy your new purchases.
    Alfredmadere
    Guest
    well i would but i want to keep my other one around for running on 3s
    Alfredmadere
    Guest
    omg my soldering iron is like the worst thing on the planet. it won't heat up hot enough to tin the tip. this is not working at all
    Oct 2013
    Dublin, CA
    1,249
    You would really want a Tekin 3000kv motor for 3s then you can cut the leads. But this system is going to be plenty on 2s, at least it would be for me.
    You need at least a 40watt soldering iron. I got mine at radio shack.
    Don't overheat the posts on the esc. You can de solder them from the board.
    Alfredmadere
    Guest
    yeah, i went out and bought another really nice soldering iron, the trackpower 950
    now my problem is mounting the the stuff. i am really struggling, can anyone help me?
    Alfredmadere
    Guest
    Quote Originally Posted by RazorRC22 View Post
    hey man, have you used this mount for this setup? i am having trouble mounting stuff and i am considering using this but i don't know if it will work with out glue or modifying my chassis. thanks so much!
    Oct 2013
    Dublin, CA
    1,249
    Look thru the backslash posts. They have bent a piece of aluminum then drilled holes where they needed to screw to the chassis. That mount screw's into the chassis in the same location as the stock esc so that won't work.
    I shoe-gooed a thin piece of plastic to the chassis then double sided taped everything down and added a dab of shoe-goo to the corners of the esc and the receiver for extra insurance.
    Alfredmadere
    Guest
    ok, that sounds good exept i want to be able to change out my motor and esc quickly and with that setup that won't really happen so what i think i am going to do for now is (i have some perferated aluminum) drill some hols in my aluminum and screw that to the chassis, then use some heavy duty velcro.. the kind they use for water ski bindings
    Oct 2013
    Dublin, CA
    1,249
    There you go. That sound's like a good plan!!! And remember to post pic's
    Alfredmadere
    Guest
    sure will!
    Sep 2015
    2,198
    Quote Originally Posted by Alfredmadere View Post
    I've used it with a normal 540 can, but not the Pro4HD motor.
    WA - PNW - USA
    704
    The Parma red servo tape works great super strong and peels off in one piece when you need to swap it. Good choice on the iron. Love mine. It makes a solid joint in a matter of seconds when tinned properly and using flux. The tekin rx8 doesn't like long stints with a hot iron.
    slash 4x4
    Alfredmadere
    Guest
    Quote Originally Posted by snowninja View Post
    it is a great soldering iron. i just started mounting the rx8 today, so far it is going really well, i have to swing bye the home depot to grab some supper strong velcro. i will post pick of the process when i am done
