Results 1 to 31 of 31
    5,644
    My X-Maxx is Down.
    Well guys, my X-Maxx defeated me today. Long story short it doesn't drive correctly anymore due to some freak glitch programming error of some sort.
    Long story, I took my X-Maxx out to drive in the snow. Everything was working normal, but driving forward was only 50% power, and reverse was 100% power. Reverse was way overpowered, it would hit 100% power at a quarter throttle input. No big deal I thought, maybe two of the motor wire had gotten switched some how. Nope. Black was with black, blue with blue, and white with white, so that wasn't it. Ok then, I'll just re calibrate the ESC throttle. No dice. It wouldn't let me. It would flash red like it should, but when I gave it full throttle to calibrate it, it would shut off. And when it didn't shut off, the steering servo would twitch out towards full left lock. I tried calibrating it for reverse, and same thing. After messing with switching the channels on the TQI a few times and trying everything, I gave up. I even re bound the entire radio system, yet still it wouldn't correct itself.
    I pulled the non TSM receiver out of my Summit so I could rule out either the receiver or radio. After I installed my Summit's TQI receiver, it worked and drove normally like it should, but only for about 10 seconds then the entire truck shut off. When I turned it back on, I had no forward at all, only 100% full power reverse. When I tried to re calibrate the ESC again it went as it should, but I would just get a quick flashing green LED code on the ESC, which means the throttle calibration is off. After resetting everything I could, the radio, ESC for what it would let me, nothing would work. Even switching back to the stock receiver and transmitter is came with didn't change anything, so that rules out the issue to a ESC fault.
    My X-Maxx still drives, but everything is completely backwards. Switching two motor wires doesn't do anything either, I tried literally every single combo of tricks I could think of over the last hour and still nothing.
    I'm going to pull the ESC out and try my Summit's Castle Mamba Monster 2 esc and go from there.
    Manager at LHS ~7 Years. I've seen some stuff lol
    RC Racer dwilli9013's Avatar
    Dec 2015
    Machesney Park Illinois
    151
    Bummer reeks bad of moisture in electronics but I'm no Electrical Engineer Just Mechanical.
    Be interesting to see how the MM 2 works of for you. I've thought that as well.
    XMAXX EREVO SAVAGE Digging Ditches
    5,644
    Quote Originally Posted by dwilli9013 View Post
    That's what I've been thinking. I'm going to leave the ESC and receiver in a bag of dry rice over night and see what happens. Worst that could happen is nothing so it's worth a shot.
    Traxxas Employee TireSlinger's Avatar
    Sep 2010
    953
    It's important to note that an issue with the temp sensor on the motor will probably cause what you're seeing with limited forward power. The setup is designed to limit power if the motor gets too hot, or if it's not receiving a temp signal.
    One of several things could have happened:
    - Bad temp sensor
    - Loose plug in the V/T slot.
    - Disconnecting the voltage tap. (Red plug must get power either from RX or main battery in order for temp sensor to work. Plug into channel 4 or 5 on RX.)
    Might want to try inspecting all of that or replacing the temp sensor.
    Our doubts are traitors, and make us lose the good we oft might win, by fearing to attempt.
    5,644
    Quote Originally Posted by TireSlinger View Post
    - Bad temp sensor
    Really? I think I just found my issue. I removed the voltage and temp sensor entirely. I pulled the temp sensor off the motor since I wasn't using the telemetry and coiled it up inside the receiver box. Yesterday when I was removing the Castle fans for snow running today I removed the voltage and temp sensor completely. since I wasn't using either of them. So are you saying the temp sensor affects the ESC performance for the motor? If I understood that correctly, that's really cool.
    Things might have just got interesting...
    Aug 2015
    122
    Curiouser and curiouser...
    Sep 2010
    953
    Basically the motor's temp sensor will cause a to limit throttle input if the motor gets too hot. If the RX isn't seeing a signal from the sensor it's going to default to that "protection" mode to try and prevent damage.
    If you plug the temp sensor (grey plug) into V/T and the red plug back into channel 3, 4 or 5 it should work again. If the sensor isn't on the motor it's not going to help prevent a motor overheat since it'll just read ambient temp, not motor temp.
    I believe the receiver will blink red when it's in the motor thermal shutdown.
    5,644
    Hmmm ok that's probably my issue. I didn't know that. I thought the sensor was just installed for telemetry reasons, I didn't realize there was a safety cut off built it. That's awesome to know, I'm going to install the sensor back right away.
    The receiver LED as green the entire time...
    Dec 2015
    Pittsburgh, Pa.
    69
    I have a question, while I agree with everything above or at least it sounds like a possible cause but.......if it's the temp sensor why would u still have full power in reverse? Just a thought to ponder.
    Sorry I meant to quote tireslinger.
    RC Qualifier Fuglio's Avatar
    Sep 2015
    497
    - Bad temp sensor
    Nice info! Is it in the manual? Where did you find this out?
    Aug 2009
    134
    Let us know if issue is resolved.
    A.K.A MAXX05
    1 BL Revo,Erevo,Emaxx
    4 XMAXX
    Jul 2007
    1,323
    Quote Originally Posted by Fuglio View Post
    He's a Traxxas employee.
    I need R/Cers anonymous.
    Sep 2015
    497
    Quote Originally Posted by RobWilJas View Post
    Lol thanks
    RC Champion jeteffect's Avatar
    Apr 2015
    1,756
    The info, tricks and tips, quick replies, support from members and a Traxxas employee is what makes this forum valuable and more positive than negative! Awesome!
    Wolf, let us know your next steps!
    Traxxas Employee
    Nov 2013
    42
    Please note that you need to put the original X-Maxx RX in the truck. Its model is set to X-Maxx. Unless you programmed the Summit's RX model to X-Maxx (using a BT module and the Traxxas Link App) it won't limit the throttle when the motor gets too hot.
    Dec 2015
    Wi
    274
    Thanks tireslinger you rock. I think most of these esc troubles we read about are brought on by man ,not system.
    Jul 2007
    1,323
    Quote Originally Posted by steveomaxx517 View Post
    There are some with ESC failures that are in completely stock trucks with no modifications to the truck or programming. I know there's one here on the forum that I believe was caused by user error but not all of them. I'm sure Traxxas will figure out what's causing it though and either fix it or replace them with a different ESC.
    Apr 2015
    1,756
    Agreed.....
    Dec 2015
    New Jersey
    75
    Mine did the same thing and I did zero modifications. Stock gearing, haven't even opened the receiver box. I have had great success with the Xmaxx. I have run a good amount packs threw it and love my Xmaxx. I first did all the usual stuff with no success and then I called traxxas. We went threw every thing to no avail. Traxxas rep told me to send it in for repair or replace.
    A small percentage of minor issues should be expected with a new release. In no way with it sour my high opinion of this awesome design.
    RC Qualifier NBViper's Avatar
    MA
    386
    I can confirm that disconnecting the Temp Sensor will result in this issue...
    I removed it in the midst of my Castle XL2/2028 upgrade and noticed a limited forward throttle being sent from the receiver, however reverse was un-affected. I was baffled and thought is was the ESC until a checked the logged data from the Castle ESC and saw that the input signal was being clipped.
    So, I suggest checking your Temp Sensor as TireSlinger stated.
    210
    No offense to traxxas but I think a better motor/esc should have been included stock. Buy an 800 dollar truck and if the esc goes you gotta replace it with a 500 dollar castle setup. That's only 300 less than the whole original thing.
    RC Champion SLW-SVT's Avatar
    Lake Jackson, TX
    1,638
    wow thanks for the info. i was having the same problems after unplugging the temp wire and forgetting where it was originally plugged in.
    X-Maxx Max6 | EB48.3 | ET48.3 | Axial Grave Digger
    RC Qualifier cazrack's Avatar
    Dec 2015
    Sweden
    613
    How much better is these Castle motors and escs compared to traxxas stock?
    I seems to cost a lot of cash , you can basicly buy a second truck to use as backup and spare parts.
    Sep 2010
    953
    Quote Originally Posted by Maxxnutt69 View Post
    I'm not sure of the exact reason for this, however one thing to consider is that limiting throttle in reverse will also severely limit your brakes. If this were to happen in the middle of a high speed run that could cause some ... excitement The radio system sends forward / reverse signals and the ESC decides if it's going to use the reverse input as a brakes or reverse.
    Prolonged full throttle driving in reverse is also fairly difficult. The vehicle effectively has "rear steer" at that point and is easier to flip over / lose control.
    5,644
    It's running again! Turns out TireSlinger was right of course... I re installed the temp/voltage sensor and it's back to it's normal beastly self.
    Thanks TireSlinger for all the help!
    Mojave Desert
    3,013
    Well I haven't been on the forums too long but over my few years I've noticed Tireslinger is VERY helpful and informative. Props to a Traxxas Employee scanning the forums and lending a helping hand.
    We are all one race. The human race.
    210
    Post has nothing to do the original topic.
    Feb 2008
    812
    I did the same mistake and the my Lhs shipped the reciver for evaluation
    Can we find this in the manual somewhere?
    Jan 2014
    11
    I just experienced this same issue after unplugging temp/voltage sensor! I switched the transmitter to 70/30 and it ran fine! Tried to re-callibrate with transmitter on 50/50 and it would not calibrate! I'll retry with the sensors plugged in on 50/50.
    Jan 2015
    Salado Tx
    171
    Great thread. Problem, discussion, input from users and Traxxas employee and a solution. Awesome.
    Jul 2019
    5
    Is there a way how to bypass it? I removed my temp sensor and now i cant get 100% throttle and i no longer have that sensor
