Page 3 of 7 FirstFirst 12345 ... LastLast
Results 81 to 120 of 242
  1. #81
    RC Turnbuckle Jr. GeneralPede01's Avatar
    Sep 2015
    Toomsuba, Ms
    3,186
    Here's a pic on the inside of the stock diff.
    That pin holding those spider gears in is the one I'm referring too. After you pull those out and clean your diff cup you can look at the sides of the cup where that pin slides down and see if the pin slot is messed up. Mine was so bad that the gears had started eating through the cup, and also grinded a couple of my ring gear bolts down.
  2. #82
    Sep 2015
    96
    Quote Originally Posted by GeneralPede01 View Post
    Check the inside of your diff cup, I've had a diff mess up before and the gears were fine but the pin that holds the spider gears inside the cup the slot the pin slides into was wore out which was making my gears bind up. I just replaced it with xo-1 parts and haven't had a problem since.
  3. #83
    Sep 2015
    Toomsuba, Ms
    3,186
    You have too pull your axles off, then remove your bearings, then you remove the 4 bolts on the ring gear which will give you access too the inside of the cup.
  4. #84
    Sep 2015
    96
    Both bearings shot, but I'm not sure about the guts
  5. #85
    Sep 2015
    Toomsuba, Ms
    3,186
    Go and YouTube and type this in
    Very good video on how too clean and rebuild diffs.
  6. #86
    Sep 2015
    96
    Is this the problem
  7. #87
    Sep 2015
    96
    [IMG]http://images.tapatalk-cdn.com/15/11/26/fbe043dcf32f0bb865e153220c902356.jpg[/IMG
    This is the problem?
  8. #88
    Sep 2015
    96
  9. #89
    Sep 2015
    Toomsuba, Ms
    3,186
    Yep that's same thing that happened too me.
  10. #90
    Oct 2010
    3,144
    Great photo matt77tree! The XO-1 differential has metal inserts on the sides to spread out the load and prevent that pin from indenting the plastic housing. Very informative. Thanks.
    Obstacle Magnet
  11. #91
    Sep 2015
    96
    Thanks. Now I'm curious if I'll be able to rebuild this one until that xo1 comes. Those bearings were totally gone so I'm glad to have the truck opened up. Wish we had a hobby shop within 100 miles
  12. #92
    Sep 2015
    Toomsuba, Ms
    3,186
    All you would need is a new cup, but if you already have xo-1 parts coming, I'd just wait on those. Did you order just gears or did you order the xo-1 cup as well?
  13. #93
    Sep 2015
    96
    I better check, it is a kit and was thirty dollars plus.
  14. #94
    Sep 2015
    Toomsuba, Ms
    3,186
    If it was that much you must have ordered a complete diff, if that's the case it will be a drop in replacement.
  15. #95
    Sep 2015
    96
    Yep cup, bearings and about ten other pieces.
    Quote Originally Posted by matt77tree View Post
  16. #96
    Sep 2015
    Toomsuba, Ms
    3,186
    Do you have a link too what you ordered?
  17. #97
    Nov 2015
    Florida
    63
    Yeah I feel like the 2400 is kind of a dog on 3s ! So I'm thinking the 2650 would be more impressive on 3s ?
  18. #98
    Sep 2015
    Toomsuba, Ms
    3,186
    Quote Originally Posted by rcrob1974 View Post
    I've had the 2400 on 3s and it was far from being a dog, was actually pretty quick.
  19. #99
    Sep 2015
    96
    http://www.amazon.com/gp/product/B00..._st_dp_summary
  20. #100
    Sep 2015
    Toomsuba, Ms
    3,186
    Yep that's a drop in replacement all you have too do it put your axles on it and bolt it back up and go
  21. #101
    Oct 2010
    3,144
    I agree with GeneralPede01. On 2s the 2400 was a dog but quite peppy on 3s. The 2650 is peppy on 2s (same battery and gearing). I measure "peppiness" based on the truck's ability to clear jumps, wheelies, speed, etc. E.g. the 2400 on 2s couldn't clear the triple jumps but the 2650 could.
    Obstacle Magnet
  22. #102
    Sep 2015
    96
    That's great. Saying delivery 12/2 - 12/5, seems like a long time. I can drive 140 miles to Abell Hobby, but rarely have that much time
  23. #103
    Sep 2015
    Toomsuba, Ms
    3,186
    I feel you on that I was having too drive that at first, but now I have a hobby shop that's only 20 min away, very thankful for that.
  24. #104
    Sep 2015
    Toomsuba, Ms
    3,186
    Quote Originally Posted by jvogel View Post
    Agreed, the 2650 has more get up and go, but the 2400 is defiently no slouch on 3s, never tried 4s but I imagine it's pretty fast on 4s as well.
  25. #105
    Nov 2015
    Florida
    63
    Thanx for the info !
  26. #106
    Sep 2015
    Toomsuba, Ms
    3,186
    No problem, that's what the forum is for.
  27. #107
    Nov 2015
    Florida
    63
    Does the 2650 fit right in the slash 4x4 lcg with no modifications ?
  28. #108
    Sep 2015
    Toomsuba, Ms
    3,186
    2650kv speed and performance
    I have no idea on that chassis, I run mine in a p4de. I'm sure it will require some modifications too the chassis but shouldn't be any more than you would take off a p4de or sl4sh hcg chassis.
  29. #109
    Oct 2010
    3,144
    I have the 2650 in my Sl4sh LCG. I have a great memory but it's short. I think it just goes right in with no fuss but the tryptophan is kicking in.
    Obstacle Magnet
  30. #110
    Nov 2015
    Florida
    63
    Omg Lol !!
  31. #111
    Sep 2011
    Iowa City, Iowa, USA
    4,359
    It fits with minimal modification. I think there is one part you have to cut off but that's it.
  32. #112
    Jun 2014
    Kansas
    3,013
    I think it has something to do with gearing. I have 2 lcg chassis's running the 2650 and had to do nothing to the chassis. While there's some that had to cut some post down where the stock esc mounts to. I also have a hcg chassis and same results nothing to trim or cut off.
  33. #113
    Nov 2015
    Florida
    63
    What gears do u run in them ? I just bought a mmp 2400 before doing much research and am now thinking I want a mamba monster 2650 ! So I guess I'm going to just order one and see for myself which one I like better....
  34. #114
    Oct 2010
    3,144
    My P4de MMv2 2650kv is geared at 18/54 currently but I'm fairly confident I can go up in gearing a lot and still keep temps in range on 3s LiPo.
    Obstacle Magnet
  35. #115
    Sep 2015
    Toomsuba, Ms
    3,186
    My gearing in the 2400 for everyday use was 19/50 on 3s. Gearing for my 2650 for everyday use on 3 and 4s is 19/52.
  36. #116
    Jun 2014
    Kansas
    3,013
    19/54 in one and 18/52 in the other.
  37. #117
    Nov 2015
    Florida
    63
    Which one do you favor the 2400 or the 2650 ?
  38. #118
    Sep 2011
    4,359
    I run 18 50 on 2s and 15 50 on 3s. I run them hard and a lot of times it's on my track that has a lot of braking and accelerating areas that tend to build up heat.
  39. #119
    Nov 2015
    Florida
    63
    Which motor ?
  40. #120
    Jun 2014
    Kansas
    3,013
    Which motor ?
    I favor the 2650 over the 2400. Simply because of the 5mm shaft and is a blast to drive with
