Results 1 to 26 of 26
    Nov 2015
    6
    Converting to Big boy tires
    Need help new to this hobby and bought the 6.3 wheels and tires to put on my 2wd stampede but the hex nut is too small for the wheels please tell me there is conversion for this set up. If so parts number would be nice
    Mar 2004
    N. Idaho... Da Sticks!
    7,611
    Standard is 12mm, are the new wheels 14mm or 17mm?
    Once you know that, you can just type into Google "12mm to 14mm hex adapter" (or 17mm).
    Once you get the tires mounted, recommend gearing down a couple of teeth, running larger tires on stock gearing will stress the motor. Go down a couple of teeth on the pinion, or go up a few more teeth on the spur.
    20,527
    If you bought the 6.3" Maxx wheels and tires for your Stampede, it doesn't matter which adapters you get to make them fit. They still won't work well with the rest of the truck.
    Alt-248 on the number pad =
    RC Turnbuckle Jr. JerrysMaxx's Avatar
    Jul 2014
    NAWLINS
    3,952
    Unless it's going to be a shelf queen .
    What esc/motor are you planning on using to push those tires?
    T/SportMax/Slayer Pro/Bandit
    Stampede/Rustler
    Nov 2015
    6
    I'm planning to upgrade to the vxl system and run lower spur gear like maybe 100 or more to make it more dirt and mud slinging fun I want speed but not some 70 mph on dirt speed its gonna be setup for off-road terrain use.
    Jul 2014
    NAWLINS
    3,952
    Quote Originally Posted by Speedz2015 View Post
    Like mentioned above, they won't work well with that truck. You are going to be putting a lot of stress on the ESC, motor, steering servo and tranny. My guess something will burn up before you finish a battery pack.
    Stampede/Rustler
    20,527
    Quote Originally Posted by JerrysMaxx View Post
    ...You are going to be putting a lot of stress on the ESC, motor, steering servo and tranny...
    ...yokes, driveshafts, axles, bearings and carriers...
    Jul 2014
    NAWLINS
    3,952
    I seriously doubt he will get to that point before he fries the ESC or motor.
    Stampede/Rustler
    RC Turnbuckle Jr. jvogel's Avatar
    Oct 2010
    PM me if you want to bash near Grass Valley, CA
    3,144
    I'm planning to upgrade to the vxl system and run lower spur gear like maybe 100 or more...
    Correct me if I'm wrong here but I thought a 90 tooth spur gear is the biggest you can get in 48 pitch.
    Obstacle Magnet
    RC Qualifier Zamboniman808's Avatar
    Oct 2014
    Canada but now New Delhi
    942
    Quote Originally Posted by jvogel View Post
    I think you are right. Imagine the torque you could generate with a 100t spur mated with a 9 or 10t pinion!
    Dec 2014
    1,136
    Not sure how much ur big wheels weight. My digger has tamiya juggernauts. They r 6.8" tall and 4" wide fairly light. Had problems with the drive yolk. Changed to steel yolk no more issues. I use vxl3s 12p90s I think on 2s. It's fun.
    20,527
    I can think of situations where either is just as likely, but my intent was not to replace but to complement your wording, i.e. I was piling on.
    @ blown68ssrs : In which situations are those big tires better suited to a Stampede than something based on a 2.8" or even 2.2" wheel?
    Dec 2014
    1,136
    I don't really have any reference. When I set out to build the digger, I wanted it to look like a monster truck. I put the stock 1/10 digger wheels on my son's 1/16 digger and found these big wheels for mine. We mainly run them on pavement and snow banks. I had a gyro on mine and drift with it for awhile.
    I am sure its not the best combo. It's just fun for my household.
    Nov 2015
    6
    For those that doubt me in my endevers its called having machinist background I can make any part imaginably cable of the cad cam programming world. Plus its called 3d printing
    Jul 2014
    NAWLINS
    3,952
    It's not a question of your capabilities, what is fun about this hobby is the ability to make yours personal or create something unique. The big question I have is the ESC/motor going to be able to handle those tires. Look at the X-Maxx for example.. it was designed with a new ESC and motor to be able to handle the massiveness.
    By the way machinist and electronics are two different worlds, unless you have knowledge in both, one may not compliment the other if you are getting my point. I can make all the parts I need, but if my power plant can not handle it what's the use. There are others who want to do 100 plus mph but do not realize the more powerful the power supply (ESC/motor) it will not do you any good if the drive train can not handle it.
    Good luck with your project and keep us posted. Pics too!
    I do not know what hex size you are dealing with (asked by Greatscott) but there is an adapter made by HR to convert 14mm hex T=Maxx wheels.....http://www.hot-racing.com/index.cgi?...r=TE10M06;c=72
    Stampede/Rustler
    Nov 2015
    6
    I will certainly do that and yes I have knowledge of both worlds I'm majoring in mechanical engineering with a minor in electrical engineering with emphis on robotics thanks for being respectful about this.my project might be as big as the new Xmax in the end so we will see how it goes
    Oct 2010
    3,144
    I think our dear friend JerrysMaxx said it well.
    And, pictures of this project are wanted please!
    Obstacle Magnet
    Jul 2014
    NAWLINS
    3,952
    What's up doc? Glad to hear from ya again! Definitely want some pics... possible video
    Stampede/Rustler
    Oct 2010
    3,144
    Just loitering in the forums as usual. All my best to the gators.
    Obstacle Magnet
    Nov 2015
    6
    Hey does anyone know if the motor from redcat racing is any good I noticed it was for a 1/5 buggy, its a unsesnored brushless 980 kv motor 07788# part its something I'm considering or waiting till traxas vxl6 system comes out for parts I figured if designed to run a bigger vehicle it will move this thinking beast when its fully done
    Sep 2014
    VA
    323
    You plan on putting a 980kv on a 2wd stampede?? That motor probably needs 6 to 8s.
    Jan 2014
    Catawissa Missouri
    11
    I have a question anybody can help me I was reading through some of the post I put some big Joe 2- tires on my Traxxas 3 3 they are 3.85 by6.65and they have a half of inch offset rims are 17 millimeterI upgraded the shocks on here everything else is stock just wondering is that putting my motor on your stress just wondering if I need to do anything with my gear ratio Thanks Robert
    Nov 2015
    6
    Possibly heat destroys electronic components keep that in mind Jvogel is a good one to hit up on that one
    Jul 2014
    NAWLINS
    3,952
    Quote Originally Posted by bigkid2020 View Post
    This should have been in the T Maxx forum but I will reply....
    Does your wheels look like this?
    I have a 3.3 on it and still run stock gearing. Wheelies on command!
    Stampede/Rustler
    Jul 2014
    NAWLINS
    3,952
    It's a NITRO not electric.
    Ahhhh ye good ole Doc V, he's the man.
    Stampede/Rustler
    Feb 2002
    9,356
