Results 1 to 4 of 4
    Dec 2015
    Rally steering binding when turning right..
    Howdy..
    I recently pulled out my rally so my son could play with it. I noticed that when turning right, the connector from the steering servo hits and pushes the camber link. This causes the right side steering assembly to push forward and binds the axle as well.
    Was wondering if anyone else has seen this and if there is a cure.
    Hope i'm explaining this correctly. I've also tried to adjust the steering link and **** the servo mount back a bit but it affects the overall steering.
    Thx
    Dec 2013
    95
    Can you provide a photo? At full lock, I do get a bit of contact, but it's negligible. Less than 1mm of push. Have you had that side of the suspension apart recently? You may also want to check to see if the white spacer is on the proper side of the control arm.
    Dec 2015
    Thanks for the reply.. Here ya go.
    http://photos.napalm.net/clubsi/traxrally.JPG
    This is full lock right and it's made contact and pushed forward.
    The front has been disassembled for a diff replacement due to stock breaking. I don't remember the white spacer as well. Where does that go? From looking at the rally exploded view I don't see one.
    https://latrax.com/sites/default/fil...ews-150730.pdf
    Thanks Again.
    May 2019
    I have the same issue. This rally was built for NASCAR..... (drive fast, turn left)
