Page 1 of 3 123 LastLast
Results 1 to 40 of 113
    Mar 2013
    243
    Simple motor fan mod. Dropped temps 50 degrees
    So been running with higher gearing and lots of short bursts in front of my house. The motor was ending a run around 185. Dropped a small 5v cooling fan in and dropped my motor temps to 135 after hard running. Works excellent. 50x50 x 10mm thick plugin to any empty reciever port and enjoy much lower motor temps.
    Just search 50x50 5v fan on ebay
    Dec 2015
    51
    Already brought one two weeks ago just waiting on the xmaxx to get here. I wondered how the temp drop would be, that is awesome to hear.
    Mar 2013
    243
    Yeah and going to a 17 pinion from the 15 made it perfect speed wise in my opinion. 39 mph.on fresh batts and settled around 38. It's the perfect speed for this monster. And only 130ish motor temps driving hard with the fan.
    friendswood texas
    1,733
    Where is the like button?
    just a basher
    Riverton Utah
    5,642
    Quote Originally Posted by pro mod steve View Post
    Thinking the same thing...
    Thanks for sharing!
    Is owning 27 RC's too many? No way!
    Nov 2015
    Dallas, TX
    75
    I need to buy a waterproof fan!
    How can I find one that's waterproof?!
    Dec 2015
    25
    If you buy a brushless fan it should be water proof and will work in wet conditions just remember to blow it out with some compressed air after using in the wet as some times corrosion may be in the small brushless motor.
    Nov 2015
    Dallas, TX
    75
    Aug 2008
    South Florida
    108
    RC Champion jeteffect's Avatar
    Apr 2015
    1,756
    Cool post.
    Is this needed for stock gearing or gearing down to crawling gearing, ie: 11/54?
    Thoughts?
    Dec 2015
    85
    Just bought 2 of those.
    Eastern Shore, Maryland
    4,028
    Good job, and very believable. I made cooling fan cooled, heat sinks for both my Emaxx and XO. My Emaxx runs at 123* and my XO at 113*. If for some reason a fan stops, my Xmaxx will go to 160* and my XO will go to 143*. I was planning on doing a fan mod to my Xmaxx, and it's nice that you showed us a good way of doing it.
    Also, I want to see how I can modify the ESC to be able to easily clean and lube the ESC fan. I was able to figure it out with my MM2's, but haven't looked into it with this VXL-6.
    Mar 2013
    243
    Those fans posted will work great but I try to find sellers in the USA. Hong Kong items take forever to get .
    210
    Which way do you point the fan? Blowing on the motor or blowing up?
    Mar 2013
    243
    Towards the motor. The stock heatsink is perfect for a fan. Very deep fins.
    Dec 2015
    38
    That ebay link above ... does that plug directly into Xmaxx? If so, where? (sorry, newbie here) THANKS
    Dec 2015
    63
    I mounted a castle creations dual fan and shroud for a 2028 . Slips right between the rails perfect . Looks factory. Can I post pics directly to here or do they have to be uploaded to something like photobucket first?
    Dec 2015
    38
    Quote Originally Posted by Holdenracing View Post
    Oh man.. that looks like it'd be perfect fit
    http://www.ebay.com/itm/Castle-2028-...8AAOSwHPlWb1gy
    RC Qualifier NBViper's Avatar
    Feb 2013
    MA
    386
    Here's a size comparison between the two that I did when dropping the 2028 into my X-Maxx. Width wise they are very close. Length is a bit longer, but that shouldn't matter.
    -=/ X-Maxx - 8S XLX/2028 \=-
    Dec 2015
    63
    Quote Originally Posted by Kalop View Post
    YEP! That's the exact one I used . Could trim the sides off a little to get it right to the fins or remove the chassi brace rails and put the fan in under them should fit too. I just left mine stock and zip tied it right between the frame rails. Fan is a little longer than the motor which I think is good, my esc has overheated already so I slid the extra fan that way .
    Sep 2008
    Turks and Caicos Islands, BWI
    657
    Thanks for sharing!
    Lol I was looking for it too... This is good!
    Ray00
    E–Revo │ E-Revo BE
    ITCHY THROTTLE FINGER!
    Riverton Utah
    5,642
    Wait wait wait, are you guys saying Castle fans fit over the stock motor heatsink!?!
    210
    You would think something as simple as this would be added stock if it can drop temps that much, considering they could wholesale buy fans from china for pennies.
    Nov 2015
    36
    I think that's what they are saying need to order that if it dose
    Riverton Utah
    5,642
    If it fits over the stock motor, AND heatsink, I'm going to order one. That would be awesome. Talk about awesome combo, massive heat sink, and fans.
    Oct 2015
    64
    These fans are a good investment to keep the motors temps down. I'm running a 50mm Evercool fan that produces a high air CFM around 9-10 CFM. I might go with a smaller 40mm from fans (Wild Turbo Fans) that produce allot of air as well. I run the fan on my XL2 for my XO-1
    Mar 2013
    243
    I kinda like the shroud less fans because with a heasink this big you want as much air in and around the fins as possible. Plus with the castle shroud if the fans stop working you have a big plastic thing blocking air flow to the motor. With fan like I posted, if it stops it won't block air flow at all. And the fans are like 2 dollars. I like the shroud type fans on motors without heatsinks cause they direct air flow down around the motor. With a heatsink your just blocking air to other parts of the sink.
    All that said having any kinda fan will help tremendously.
    Are the esc fans easy to change like the mamba2 and x? Or does the whole esc have to come apart?
    Dec 2015
    63
    It fits about halfway down just setting it over the motor. It can probably be spread by hand enough it's so close BUT the little upper frame rail things must be removed first to try that. Even not doing that it fits a good amount around the fins. Wish I knew how to post pics
    Oct 2015
    64
    I agree with you Dragonfueled. I have both the XL2 and X esc. The XL2 was easy to change out and replaced with a 40mm fan. The X seems to have a pretty high powered fan and I just left that alone. I'm running the X esc on my TC4 thats doing 124mph speed runs 1/4 mile
    *Remove words that have tripped the language filter. It is obvious that the letters of Wild Turbo Fans would trip it.
    Oct 2015
    933
    Here is how to post pictures:
    https://traxxas.com/forums/showthrea...sting-Tutorial
    I am going with the Castle Creations dual fan and shroud setup for mine also. This way if I decide to get a 2028 down the road I will be able to swap it onto it without any concerns and for the price of $11.10 shipped from TH you can't beat it.
    I haven't decided on the ESC fans yet though. Going to have to measure it when my X-Maxx arrives and see what I want to do.
    Jul 2011
    139
    Ordered. $12 hard to pass up
    May 2013
    53
    Ordered, can't beat it.
    Pede Xmaxx Merv 1/18 Rally Blast Spartan M41 Aton
  33. #33
    4,028
    I ordered some, but I'll make a nice bracket to house my motor's cooling fan. Also, some guy put cooling fans on the sides of his ESC. I'll probably do that too. I would also like to figure out a way to get to my ESC's cooling fan without to muck trouble. I always like to keep my fans blown out and lubricated as needed with out it being to much of a chore.
  34. #34
    Jul 2008
    Greenacres, FL
    72
    Let'see some pics, pls...
  35. #35
    Dec 2015
    63
    Quote Originally Posted by fabster32 View Post
    I read the directions on how to post pictures .... Then I went and mounted the sct 5ive bumpers on my x maxx instead �� sorry I really like building stuff more than doing computer stuff ! Lol. Just posting from my phone. I'll set up an account to post pictures eventually I hope. If someone wants to pm me their # I can send them pics and they can post them.
  36. #36
    Dec 2015
    72
    How do you guys run the fans ...like the castle fan and say 2 more on esc 1 on each side. Would you use a 3 way spitter and hook them all up to the receiver open channel? Also when your running all these extra fans aren't you losing alot of run time and pulling volts away from the motor and esc ..so performance is going to lack a little bit and possibly? Couldn't you hook up a separate smaller 11.1v 3s or 7.4v 2s lipo 5000mah receiver battery to a on /off switch just for the 3 fans is that possible?
  37. #37
    Nov 2015
    66
    Are there slightly bigger fans out there, seems like you could get away with a bigger fan. More cfm wouldn't hurt -60mm
  38. #38
    Dec 2015
    Kristianstad, SWEDEN
    29
    Nice job with the fans udluuz. is that 30mm fan on the sides?
  39. #39
    Dec 2015
    72
    Quote Originally Posted by David1970 View Post
    I'll ask again do you plug into receiver? Id be running 2 30mm fans on sides of esc and 1 castle ceraction on top of heat sink on motor. Id use a on/off switch and run them on its own 7.4v or 11.1v 5000mah lipo receiver battery i use for my 5th baja truck. ...would this be a better setup. .so i wouldn't be using the volts from my system please someone lmk thanks
  40. #40
    Apr 2015
    1,756
    Quote Originally Posted by jeteffect View Post
    Cool post.
    Thoughts on this?
