Page 40 of 41 FirstFirst ... 3038394041 LastLast
Results 1,561 to 1,600 of 1620
  1. #1561
    Dec 2017
    Germany
    377
    Quote Originally Posted by dallas1990 View Post
    Well I got some money for the rebuild/mod list I would like to get a new motor. I'm thinking about the tp5860 1440kv but idk if my Kershaw motor mount is strong enough.
    I would not recommend TP5860 1440kv, i have many issues.. first its 441A, I'm getting low voltage warnings under full load, higher C-rated Lipos help but Max5 esc is to weak to handle 441A, not getting out full potential. It also have weak shaft, pinion backing off, vibrations and only warranty in China etc.
    i think if you want extreme power, go Lehner 3060 built-in fan and ztw beast 300a or 250a mgm esc.
  2. #1562
    Sep 2016
    190
    Quote Originally Posted by VIX View Post
    That's what I was afraid of. But I already ordered it lol. Oh well I got some 70c lipos but the max 5 will be getting upgraded in 2-4 weeks. Truck is getting it's yearly cleaning and rebuild. So I can wait for a esc or get a different motor. Also I'm just a basher no need for top speed runs much.
  3. #1563
    Oct 2018
    11
    What esc are you upgrading to from the Max 5? Or are you upgrading the parts on the Max 5? If so anymore info?
    Sent from my Pixel 2 XL using Tapatalk
  4. #1564
    Sep 2016
    190
    Quote Originally Posted by G8eraid View Post
    Probably the ztw beast 300 amp esc. I do have a leopard hobby 5892 1340kv but need to resolder a bullet connector on it. If the tp gives me to much trouble with the max 5.
  5. #1565
    Mar 2016
    1,155
    I had the leopard 5892 1340kv and tried to resolder bullet connector but I could not solder it because leopard 5892 had a Copper wires.
    "AVENGED SEVENFOLD "
  6. #1566
    Dec 2017
    Germany
    377
    I would send TP5860 back, refund. It’s a heavy motor for bashing, I would only replace stock ESC to max6, Proline armor body with washers and replace stock parts that’s break a long the way to stronger enjoy the jumps
  7. #1567
    Sep 2016
    190
    Quote Originally Posted by PATS4LIFE View Post
    well double crap. 2 fingers broke off the connector which is why it needs fixed.
    to late the old stock parts where sold 2 years ago.
  8. #1568
    20,527
    I donít understand the copper wire problem. Can you explain?
    Alt-248 on the number pad = į
  9. #1569
    Sep 2016
    190
    Probably his solder didn't want to stick
  10. #1570
    Sep 2016
    190
    Crap I bought 3.5mm bullets for my leopard motor lol. What size do I need
  11. #1571
    RC Qualifier USMC1984's Avatar
    Jul 2019
    Greeley, CO
    500
    Today I procrastinated replacing my steering servo again!
  12. #1572
    Nov 2018
    Spokane, WA
    345
    You need 6.5 mm for the max5
  13. #1573
    Mar 2016
    1,155
    I don’t understand the copper wire problem. Can you explain?
    Tin would not stick to it due to the coating of the copper I’ve tried using sand paper,blow torch,and alcohol to remove the copper coating and still tin would not stick to it,so I end up taking to a electronic repair shop that has been soldering for years and even he said he had a hard time soldering the copper wire on the motor.
  14. #1574
    Sep 2016
    190
    Quote Originally Posted by Overpowerxmaxx View Post
    thank you I'll go to my LHS in the morning for them.
  15. #1575
    Eastern Shore, Maryland
    4,102
    I want you to know, that I'm only telling you this to help you. I'm not trying to be a smart fleshy rear area of a human being, okay. I've soldered bullets on Max5's plenty of times for my friends (so that they could have cleaner installations), and I've never seen a coating on the copper wires. (IMO) there is a very reasonable chance that you're not using a hot enough iron.
    To do Max5 wires you need a Waller100 soldering iron (or equivalent) with a 7/8" flat tip (picture below/right). However, if by a crazy chance you do have some sort of coating on your copper wires, you can use M.E.K. to remove it. Nothing on earth (I'm exaggerating a very small, teeny tiny bit) can stand up to M.E.K. except glass and the material types that make glass.
    P.S. If you ever use M.E.K you definitely want to follow all the safety precautions for using it.
  16. #1576
    RC Champion nickruger's Avatar
    Jun 2017
    Ohio
    1,342
    Quote Originally Posted by ReglarGuy View Post
    Not trying to speak for him, but I believe his problem was with the bullets on a leopard motor, not the max 5. I feel like we, the forum, had a discussion about checking motor wires for "solderability" when I was upgrading my motor. Either way, I agree with what you said. When I was putting the correct size bullets on my motor I had to put a new tip on for the last one because it just wasn't getting hot enough. Motor wire can be funny, I see how he was having a problem.
  17. #1577
    Sep 2016
    190
    Really bad solder job. Im still learning but it works and no resistance. https://imgur.com/gallery/AfANE4N
  18. #1578
    Jul 2019
    Greeley, CO
    500
    That looks like a cold solder joint. The best way to solder is to tin each wire first then attach. make sure you use flux, enough heat and heat-sink clamps if need be.
    The solder should wick onto the material being soldered. If it doesn't then your material is either dirty or too cold. The solder should never be lumpy at all. That is a sign that the solder and not the wires are being heated.
    Apply the iron to the wires and the solder to the wires, not the iron tip. If the wires are clean and hot enough, the solder will flow onto them easily.
    Also, make sure you are using the correct solder...there are different types.
  19. #1579
    4,102
    Quote Originally Posted by nickruger View Post
    Yes, it looks like he was. The good news is, though, that that's the same motor I have on my Xmaxx, so I can still offer him the same advice.
    I shortened the wires on my XLX and Leopard 5892 1340kv motor with no soldering problems using my Weller100 soldering iron. Just for the sake of conversation, mind you, I do test any ESC's and motors I want to solder out first before I start cutting leads.
    From what I've seen in the past and present (from doing many over the years) is, the ESC's and motors that can't have their leads shortened and re-soldered, are usually the smaller ones used for small scale RC's. Not all smaller motors and ESC's, but if I come across one that can't be soldered, it's the smaller scaled stuff.
  20. #1580
    Sep 2016
    190
    Quote Originally Posted by USMC1984 View Post
    Thanks for the tips. Lol luckily I bought 100 pairs of connectors. Also I guess I thought you heated the solder. So I did it backwards. But that's the part of learning
  21. #1581
    Jul 2019
    Greeley, CO
    500
    Do you understand what tinning is? I shouldn't have assumed you or anyone else does, on the other hand, if you do, no offence is meant.
  22. #1582
    Sep 2016
    190
    yea i just need to watch more videos and spend more time doing it
  23. #1583
    Jul 2019
    Greeley, CO
    500
    You might also want to use heat sink clamps to prevent overheating the insulation as well.
    Make sure you have the proper solder and flux too.
  24. #1584
    Sep 2016
    190
    good idea thanks
  25. #1585
    4,102
  26. #1586
    Jul 2019
    Greeley, CO
    500
    What a gem! LOL, that reminded me of the films I saw in the military.
    I love those old tutorial films with no BS, they got right to it in the Sgt Joe Friday voice.
  27. #1587
    Sep 2016
    190
    thanks i'll watch it now. i just got home from town and bought some better solder. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  28. #1588
    Mar 2016
    1,155
    Welp decided to play with truck to test the new leopard 58113 870KV
    Geared at 25/30 1.5mod after 10mins run, boooommm!!! there goes my rear differential ��
  29. #1589
    Oct 2016
    4,244
    Didnít you have fast lane internals?
    Somehow builds are never done....
  30. #1590
    Sep 2016
    190
    https://imgur.com/gallery/dmhy6Zo hows it look? I bought a smaller (physical size) soldering iron and the heat shrink was a little to big so that's why it's burned a little. But that's the cleanest soldering I've done
  31. #1591
    Mar 2016
    1,155
    Quote Originally Posted by Gripdog7205 View Post
    Yes I did and now Iím trying to get it replace through warranty,Iíve sent email with pics yesterday and still havenít got a respond so will see.
  32. #1592
    Sep 2016
    190
    Oooo that looks painful
  33. #1593
    Jun 2017
    Ohio
    1,342
    If those are the FLM spider gears and pinion that's a shame. They look like they are made of high quality hardened steel on their website and those look like the cheap traxxas low alloy ones.
  34. #1594
    Mar 2016
    1,155
    Tell me about it,Iím disappointed about it,but hope they will replace it under warranty,suppose to covered for warranty if it ever breaks.
  35. #1595
    Sep 2016
    190
    just bought some stronger belts for my belt drive. i stretched the belt i got with the pulleys. if i do the same thing again im going mod 1.5 gears. i got a pair of 225-15mm (wide) 5m belts and a pair of 220-15mm (wide) 5m belts.
  36. #1596
    Mar 2016
    1,155
    Tell me about it,I’m disappointed about it,but hope they will replace it under warranty,suppose to covered for warranty if it ever breaks.
    UPDATE:Fastlane will replace the diffs under warranty and was told my 1 year warranty starts all over again.
  37. #1597
    Apr 2019
    60
    Added 4s smc racing 9400 lipos, hota d6 plus charger, proline brute body, integy dust cover, and full cleaning. Next up changing oil in shocks and proline badlands
  38. #1598
    Sep 2016
    190
    Got some ose 8mm and xt90 connectors. Trying to decide what to use my 8awg wire fits in both xt90's are slightly easier not as much solder to fill lol. But I like the 8mm better just nicer to hold and more current. Main reason for the xt90 is my new lipos have them.
  39. #1599
    Sep 2016
    190
    Soldered the 8mm connectors on the max 5. And made adapters for the 8mm to trx connectors just for testing purposes. Didn't drive it just did the steering and hit the gas with no gears on. just for it works purposes.
    Sent from my Phone using Tapatalk
  40. #1600
    Mar 2016
    1,155
    Just finished installing morimoto xb led fog lights..
