Page 38 of 41 FirstFirst ... 283637383940 ... LastLast
Results 1,481 to 1,520 of 1625
  1. #1481
    Mar 2016
    1,155
    Quote Originally Posted by PATS4LIFE View Post
    Just finished installing some stuff for now..
    Leopard BL5 esc/leopard 5892 1340kv
    Fastlanerc esc/motor mount
    1.5M gear mod
    HR Cush gear cover
    HR Pin retainers
    RPM threaded hinge pins
    HR 25mm serrated wheel nuts
    Pro-line Badlands MX43 wheels/tires
    Waiting for
    HR steering brace
    Fastlanercs fully assembled bulletproof diffs/trans/outdrive
    RPM oversized rear carriers.
    Just received my rpm oversized carriers
    HR steering brace
    SMC 10500mah batteries
    "AVENGED SEVENFOLD "
  2. #1482
    Feb 2017
    UK
    568
    Quote Originally Posted by Overpowerxmaxx View Post
    I just received my duratrax bandito x tires
    Any comments?
    How do they perform?
    What's the weight difference to stock?
    I'm after a set of on-road tyres, and these look decent......
  3. #1483
    Oct 2016
    4,382
    Got an aluminum steering tie bar installed. First bad crash, my servo horn stripped. Guess I found my cheap easy weak spot. To be fair the crash involved hard cartwheels of my 30lb truck. Gonna stick with plastic on this one.
  4. #1484
    May 2014
    Proline Badlands,2085x servo,RPM rear hub carriers,max6 speed controller,Jim's bearings,hinge pins with nuts,Russian indestructable body.
  5. #1485
    26
    I just got an xmaxx a couple weeks ago after selling off all my ground RC's a few years ago.
    I like it! Its bone stock so far. Until something happens.
    Made a jump on the weekend, sorry its lame need BIGGER jump haha.
    <link removed due to language in video. Feel free to edit and repost so as to conform to forum rules>
  6. #1486
    Sep 2018
    43
    Changed pinion and spur to 20/46.
    Changed paddle tires back to stock tires
    I started a thread last night on "best way to paint or hydro dip" bodys.... but cant find it. Did it get deleated by mod???? Does anyone know the best way to "paint" these bodys? Plz lmk thanks
  7. #1487
    13,649
    Quote Originally Posted by Nitro Blowin View Post
    Read your private message I sent to you five hours ago.
  8. #1488
    Oct 2016
    4,382
    Got my servo horn replaced and now my truck is in one piece. Happy now.
  9. #1489
    Mar 2016
    1,155
    Installing fastlanerc bulletproof gears set
  10. #1490
    Apr 2007
    Long Island, NY
    365
    Looks like a killer setup.......
  11. #1491
    Oct 2016
    4,382
    What did you do with your X-Maxx today?
    I agree. Looks good. Curious why youíd delete the center diff though. I havent managed to damage any of my gearing, I could see myself getting the diff setup and pinions. Now I say this I will blow something up. Other than looking absolutely awesome(then disappearing) why billet cups?
  12. #1492
    Mar 2016
    1,155
    Not sure what happened here,ran the truck maybe less that 5min all of sudden throttle diminished and then no respond and notice the motor wire weren’t attach anymore
    Anyone tell me what could possibly went wrong here?
    BTW it’s first run on the motor leopard 5892(1340kv)
  13. #1493
    United Kingdom
    877
    Looks like they did not solder the connectors on at all! If you have a good iron you could do this yourself. Need heat shrink etc to.
  14. #1494
    Mar 2016
    1,155
    Quote Originally Posted by o0wiz0o View Post
    That’s what I was thinking,probably poor solder connection,you think it can cause the motor to get really hot also like 2-3 min run I touched the motor and it feels really hot and it was early morning run @ 60degrees temp.
  15. #1495
    Oct 2016
    4,382
    Thatís what I was thinking,probably poor solder connection,you think it can cause the motor to get really hot also like 2-3 min run I touched the motor and it feels really hot and it was early morning run @ 60degrees temp.
    Yeah. No tinning was done. Thatís really slack on the leopard side. Iíd say that was your heat issue. Are you running 8S, and whatís your gearing?
  16. #1496
    Mar 2016
    1,155
    Quote Originally Posted by Gripdog7205 View Post
    Yeah. No tinning was done. That’s really slack on the leopard side. I’d say that was your heat issue. Are you running 8S, and what’s your gearing?
    Yes I’m running on 8s with 1.5M 30/30 and mesh is fine
    Also have CC BEC 2.0 @7.4V for my savox servo
  17. #1497
    Oct 2016
    4,382
    Yes Iím running on 8s with 1.5M 30/30 and mesh is fine
    Was your input shaft really hot as well. I never had good luck with the belt drive, due to tension/heat issues. I have a thread about it. Either way your geared 1:1 which wonít work with your motor choice. Iíd fix the motor leads and gear down a bit.
  18. #1498
    Mar 2016
    1,155
    Was your input shaft really hot as well. I never had good luck with the belt drive, due to tension/heat issues. I have a thread about it. Either way your geared 1:1 which won’t work with your motor choice. I’d fix the motor leads and gear down a bit.
    No input wasn’t as hot as the motor itself,I’ll gear down once I figured how to solder the copper wires on the motor,if not I’ll probably get me CC 2028 motor.
    Are still running drive belt?thought about it but I wasn’t sure about tensioning.
  19. #1499
    Oct 2016
    4,382
    No Iím not. For some reason I thought you were. I see now youíre running mod 1.5. I prefer gears very much. I would stick with the leopard motor, I really like mine. If I swapped it would be to a TP motor.
  20. #1500
    Mar 2016
    1,155
    No I’m not. For some reason I thought you were. I see now you’re running mod 1.5. I prefer gears very much. I would stick with the leopard motor, I really like mine. If I swapped it would be to a TP motor.
    I will try solder the connectors back on Leopard motor,I had the same motor on my maxx 6s before and had no issues.
    Thought about the TP motor also but I keep reading about people breaking shafts on them and warranty aren’t good.
  21. #1501
    Oct 2016
    4,382
    Thought about the TP motor also but I keep reading about people breaking shafts on them and warranty arenít good.
    All good points. I really donít want for more. Iím running the 5898 1100kv. Geared 37/46. I have a 39 but have never run it.
  22. #1502
    Mar 2016
    1,155
    Well my leopard 5892 1340kv crap out on me,it just keeps overheating since the wire connectors came off,I replaced the connectors with new ones I even had someone solder it professionally but it’s still overheating
    But anyways I ordered 950kv 8pole brushless motor to replace the leopard motor so as for now back to stock motor.
    Requests regarding product support for non-Traxxas is not allowed here.
  23. #1503
    Mar 2016
    1,155
    Ordered me fastlanerc billet heatsink with fasltane dual fans and ABC3 complete bearing set
  24. #1504
    Eastern Shore, Maryland
    4,173
    Why are your 3 motor wires wrapped up so tight with heat shrink? They should be loose around the bullet connectors.
  25. #1505
    Mar 2016
    1,155
    Quote Originally Posted by ReglarGuy View Post
    I just did for added protection
    Anyways sent motor back if warranty will cover but haven’t received any update since they received it Wednesday and I’ve been emailing them and no responds yet and RcJuice don’t even have a phone # that I can call listed on their site:/
  26. #1506
    Mar 2016
    1,155
    Ordered leopard 58113 V2 motor 870kv
  27. #1507
    4,173
    If I may suggest, you should consider using only a zip-tie (or, something comparable in size) not so close to your bullet connectors, but about an inch or so back.
  28. #1508
    Mar 2016
    1,155
    Will do thanks for the tip
  29. #1509
    Sep 2018
    43
    This all took me few days being life has been busy.
    Totally Dissembled the xmaxx.
    Cleaned all parts.
    Installed RC screws stainless screw set
    Replaced all bearings with RC bearing set
    Replaced front diff oil with 30k weight
    Refreashed center diff with 20m weight
    Replaced rear diff with 50k weight
    Replaced rear hubs with RPM oversize hubs
    Replaced spur gear with 46T GDS gear
    Replaced pinion with 20T
    Added washers for rear bumper screws to wheelie bar (screws were pulling through)
    Added synthetic marine grease to all metal on metal gears, except driveshaft and pinion/spur.
    Added dielectric grease to reciever box seal.
    Placed tape over holes inside rims of stock tires. (Prevent water from getting inside tires)
    The RC screw kit left out few screws like steering servo and think something else already forgot lol 95% complete kit, tons of extra screws tho. Few screws were also different length but 1-2 millimeter difference so seems to work fine..
    The RC screw bearing kit left out bearings for the wheelie bar wheels 95% complete kit few extra bearings.
    Dont think I'm leaving anything out. It was a big project for only having the truck a few months and never taking it apart other than replacing spur/pinion, esc and reciever.
    Sent from my SM-G965U using Tapatalk
  30. #1510
    Mar 2016
    1,155
    Just received my leopard 58113 V2 870kv motor,next to it is 56113 8 pole 960kv motor from primal Rc
  31. #1511
    Mar 2016
    1,155
    Installed 58113 V2 motor with fastlane rc billet heatsink/dual fans with led lights.
  32. #1512
    Oct 2016
    4,382
    Lol. Those fans looks so tiny on the giant motor
  33. #1513
    Mar 2016
    1,155
    Yes it is but it cools the motor down to at least 40degrees.
  34. #1514
    Oct 2016
    4,382
    Oh Iím not hating. I run fans too. I will say for what they charge, they should be larger.
  35. #1515
    Mar 2016
    1,155
    Just received my x maxx work stand..
  36. #1516
    4,173
    If you had bigger fans that went out further past the very top of your heatsink, you would get even better cooling.
  37. #1517
    Nov 2018
    Spokane, WA
    372
    This is what Iím going to be running
    Iím not done installing it yet
    It will need its own power
  38. #1518
    4,173
    I really like the frame you made. You should consider two fans, and have those two fans get their power from your two Lipo's or BEC...maybe even three fans. It looks like your frame could handle three fans easy. Don't worry about the current drawing from your batteries. The small fans we use for our cooling draw very little current.
  39. #1519
    Nov 2018
    Spokane, WA
    372
    1 the fans are 60x60x40 and my motor is a 56112 so two will run in to the motor wires
    2 they are 12v fans they draw 3.5-4 amps and I donít believe there is a 12v bec ( send a link of Iím wrong)
    3 can I run them on the balance port or would I have to make a splice?
  40. #1520
    Oct 2016
    4,382
    The one Iím installing is adjustable up to 12vdc.
    Somehow builds are never done....
