Page 31 of 41 FirstFirst ... 212930313233 ... LastLast
Results 1,201 to 1,240 of 1624
  1. #1201
    Jun 2017
    70
    Had a little fun over the weekend & had my first breakdown lol. Some how the lower Rear A-arm pin that holds the tire knuckle on worked it way out past the screw that supposed to hold it on, causing it too come apart on a luckily small jump. nothing appeared broken or cracked and it was a quick fix yay ..... is it common for for the pins to work there way out ?
  2. #1202
    Jul 2016
    Finland
    33
    Just some Fun, no maxxes where harmed during filming. The video is in The video section.
  3. #1203
    Jan 2016
    62
    Are you sure? Looks like some suspension abuse happening in these PAXB spyshots.:-P
  4. #1204
    Jul 2016
    Finland
    33
    The blue one got a broken hand when misslanding a backflip, but The orange one just got tired of looking at The little vorza playing around.
  5. #1205
    RC Champion fourdub's Avatar
    Jan 2016
    Colton, Inland Empire, Southern California
    1,902
    ordered a set of R & L arms, lower and uppers.
    My left lower rear a-arm has been broken for 2 or 3 months now, but the break didn't really effect the driving or jumps ect.
    Will replace the arm before it has a catastrophic accident.
    Sla2hvxl,pe4evxl,erevobl
    "Richard Chilson"youtube
  6. #1206
    Oct 2017
    37
    installed rpm arms and the Cen hinge pin mod.. Finally i can play for longer than 2 mins without losing a hinge pin lol
  7. #1207
    Oct 2017
    303
    Mmm... I've break the nerf bar and chassis support on a soccer goal cage ....
  8. #1208
    United Kingdom
    877
    Plastic would have survived that! Or just broke the nerf bar.
  9. #1209
    Jan 2016
    1,902
    raced a little utv in the canyon
    I won... lol
  10. #1210
    Oct 2017
    26
    I just rebuilt my xmaxx. Both front and rear diffs. I shimmed them both. And it is still clicking under hard braking. 2 of my shocks are stuck and broken. What is a good upgrade option.
  11. #1211
    Oct 2017
    303
    Are your drive cups and driveshafts in good shape ? Did you check also ball bearings ?
  12. #1212
    Jan 2016
    1,902
    heres video of racing the utv... no contest lol
  13. #1213
    Oct 2017
    26
    Just replaced all the ball bearings. Driveshafts and cups are good. I figured out what was wrong. The slipper was way too tight so when I hit the brakes the diff cover would flex and allow it to jump a tooth. I loosened it up. Soon I will get aluminum covers and they should help.
  14. #1214
    Oct 2017
    303
    Quote Originally Posted by Racer5757 View Post
    What is the slipper ref please? And are you runinng 6s or 8s ? I am asking because I have also issues with differentials...
  15. #1215
    Jul 2016
    Moscow
    5
    Hi.for warm weather and smooth trails.these tires have delivered. https://youtu.be/T2NyWzjIgEs
  16. #1216
    Oct 2017
    26
    Quote Originally Posted by zeflex View Post
    I am running 6s with a super high discharge rate. I was running the slipper supper tight so all of the impact when I stopped went to the diffs. And I don't have the 8s center diff to take some of the impact.
  17. #1217
    Oct 2017
    303
    Sorry I am a little bit noob with parts and my english is not perfect so I don't get some details.
    What is the slipper ? Is there any part # to see what it is ?
    Center differential : I know what is the front and rear differential, but I don't know if I have a center diff on my x-maxx (it's a 2d hand one) ; do you have a part # or a picture to show me how it looks like ?
    Thanks.
  18. #1218
    Oct 2017
    26
    Thanks.
    I can't find a part number for the slipper clutch. If you take off the cover behind the motor you'll see you pinion and spur the slipper clutch is connected to the really big gear. The center differential is 7796. The center differential is only on an 8s truck.
  19. #1219
    Jan 2016
    1,902
    sunset bashing in the canyon
  20. #1220
    Jan 2016
    1,902
    running maxxes and slash 4x4's and 2wd's. and also a trx-4.
  21. #1221
    Nov 2017
    i would like a long rang cam on my XMaxx 8s . any one no a good long range ? i have fat shark Dominator V3 would like a easy hook up and how to .
  22. #1222
    Jan 2016
    1,902
    Hit a tree going bout 20-25 ripped the axle, bearings, cup and all right thru the carrier on the rear. Shocks, a-arms look good, just the carrier is broken lol.
  23. #1223
    Nov 2017
    62
    You see the two holes on that carrier? Put super glue on the seam,(careful not to glue where the bearing seat)then use a steel wires through those two hole, and twist the wires to tightening it. It could work depend on the breakage. See if it works for you. I did that with mine, and it held up ROCK SOLID til my RPM oversize carrier arrive. Anyways, it is just something you can try doing without a spare on hand. I could have keep using that broken carrier, but I ordered the RPM before I got this steel wiring idea, and it just worked. I wonder if that is what those two hole is for.
    PS: I have some steel wires stiches done on my xmaxx on bumper, and even chassis. It could work for anybody, but that depending on the breakage. And super glue will not hold on 99% repair alone. And that stock carrier you broke cost less than 5 bucks.
    Have fun bashing!
  24. #1224
    Mar 2016
    859
    Out running the V1 today,and something broke
    Back on the work bench again
    fabricator
  25. #1225
    RC Champion rizz0d's Avatar
    Jan 2002
    1,168
    Quote Originally Posted by fourdub View Post
    dang, that's a crazy break.
    youtube: rizzodtheRCvlogger
  26. #1226
    Jan 2016
    1,902
    Never noticed those tabs there before, thanks for heads up on the temp fix townie.
    I almost hit crazyxmaxx's metal shed hahahh0ahaha. Tree saved the day rizzod, ut juat dove out in frontnod the maxx lol
  27. #1227
    Riverton Utah
    5,644
    I sold my X-Maxx. It was getting a bit tired, and it was still a 6s with the original ESC. I've saving up for a new 8s green 'Maxx so I won't be out for long.
    Manager at LHS ~7 Years. I've seen some stuff lol
  28. #1228
    Oct 2017
    303
    Running in the snow... by 19 Farenheit ...
    I love it ...
    According to forerunner 201, max speed 28 mph, distance 3,72 miles and running time ~28 min... and the battery wat not totally empty ...
    BTW , I heard the differential have issue (it's not my first issue with front diff ...)...
    Cheers !
  29. #1229
    RC Racer X-Maxx's Avatar
    Aug 2017
    149
    I love it ...
    Cheers !
    if its an 8s, you shouldn't have an issue. I run the 8s diffs in my maxx, if its a modded 6s, thats a different story
  30. #1230
    Mar 2016
    859
    6s old runner needed upgrade to the cush drive
    8s rebuilt center drive with 20 million
    Now they are Ready for more punishment
    fabricator
  31. #1231
    15,251
    Made some more shock socks to try out, and worked on the pattern for my chassis cover. Also measured out what i need for my rear suspension mud flaps...
    Ya can't polish fertilizer...
  32. #1232
    Jan 2016
    1,902
    out bashing the maxxes and the slashes today at the foxtail / donkey track.
    I broke a front a-arm. drone on it for atleast half hour before I noticed lol.
    great day many hours spent driving the toys.
  33. #1233
    Sep 2016
    190
    mines been sitting on the shelf for a few months. havent bought new batteries and charger for it. want 8s for sure, i cant solder to save my life lol. the speed control has xt-150 would like adapters made so i can use traxxas connectors. any thoughts? also the closest hobbyshop is 150 miles from me now the local one closed up shop
  34. #1234
    Aug 2017
    168
    IIRC kershaw designs(if still in business) carries the adapter you are looking for--xt-150 to trx
  35. #1235
    RC Champion NYbandit33's Avatar
    NY
    1,153
    installed the wireless link module and voltage sensor. now I need the expander and GPS
    Monster Baja Sla2h VXL
    Rustler VXL
  36. #1236
    Sep 2013
    271
    Finally got mine put together. 8s version with lights and Xlx upgrade.
    Sent from my SM-N950U using Tapatalk
  37. #1237
    Riverton Utah
    5,644
    Still waiting for a green X-Maxx to come in from Traxxas so I can join the club again, I'm having a hard time waiting...
  38. #1238
    Jan 2016
    1,902
    out bashing with crazyxmaxx,
    got the fleet.
    I broke a rear left lower a-arm.
    dang, lucky it didn't take the shock with it.
    all in all was still a fun day.
  39. #1239
    Eastern Shore, Maryland
    4,168
    This is the greatest post ever in the history (dare I say it) the world! With (so far) 31 pages and 104,122 replies...that's impressive.
  40. #1240
    Aug 2017
    149
    Did it come in yet? Would love to see pics!
