Page 40 of 48 FirstFirst ... 303839404142 ... LastLast
Results 1,561 to 1,600 of 1887
  1. #1561
    Sep 2016
    191
    What!!!! lol i want a set now but crap thats some $$$$$
    https://www.integy.com/st_prod.html?...5#.XVB3DOhKgXh
  2. #1562
    Nov 2018
    Spokane, WA
    695
    Quote Originally Posted by dallas1990 View Post
    Thing with these I believe is that you need the X Maxx 6S axles to use them I might be wrong but if I remember I sold my old 6S truck axles to someone that wanted to use them for the tracks
  3. #1563
    Sep 2016
    191
    Quote Originally Posted by Overpowerxmaxx View Post
    i cant justify $340 for a full set but thats kind of a bummer. i thought the 8s and 6s where the same size since they both fit in the caster hubs. been awhile since i did the upgrade kit on my old 6s.
  4. #1564
    Apr 2007
    Long Island, NY
    412
    If it allows for a body wrap to adhere to it, I might consider it.....
  5. #1565
    Sep 2016
    191
    Well I got some money for the rebuild/mod list I would like to get a new motor. I'm thinking about the tp5860 1440kv but idk if my Kershaw motor mount is strong enough.
  6. #1566
    Dec 2017
    Germany
    379
    I would not recommend TP5860 1440kv, i have many issues.. first its 441A, I'm getting low voltage warnings under full load, higher C-rated Lipos help but Max5 esc is to weak to handle 441A, not getting out full potential. It also have weak shaft, pinion backing off, vibrations and only warranty in China etc.
    i think if you want extreme power, go Lehner 3060 built-in fan and ztw beast 300a or 250a mgm esc.
  7. #1567
    Sep 2016
    191
    Quote Originally Posted by VIX View Post
    That's what I was afraid of. But I already ordered it lol. Oh well I got some 70c lipos but the max 5 will be getting upgraded in 2-4 weeks. Truck is getting it's yearly cleaning and rebuild. So I can wait for a esc or get a different motor. Also I'm just a basher no need for top speed runs much.
  8. #1568
    Oct 2018
    13
    What esc are you upgrading to from the Max 5? Or are you upgrading the parts on the Max 5? If so anymore info?
    Sent from my Pixel 2 XL using Tapatalk
  9. #1569
    Sep 2016
    191
    Quote Originally Posted by G8eraid View Post
    Probably the ztw beast 300 amp esc. I do have a leopard hobby 5892 1340kv but need to resolder a bullet connector on it. If the tp gives me to much trouble with the max 5.
  10. #1570
    Mar 2016
    1,155
    I had the leopard 5892 1340kv and tried to resolder bullet connector but I could not solder it because leopard 5892 had a Copper wires.
    "AVENGED SEVENFOLD "
  11. #1571
    Dec 2017
    Germany
    379
    I would send TP5860 back, refund. It’s a heavy motor for bashing, I would only replace stock ESC to max6, Proline armor body with washers and replace stock parts that’s break a long the way to stronger enjoy the jumps
  12. #1572
    Sep 2016
    191
    Quote Originally Posted by PATS4LIFE View Post
    well double crap. 2 fingers broke off the connector which is why it needs fixed.
    to late the old stock parts where sold 2 years ago.
  13. #1573
    20,539
    I donít understand the copper wire problem. Can you explain?
    Alt-248 on the number pad = į
  14. #1574
    Sep 2016
    191
    Probably his solder didn't want to stick
  15. #1575
    Sep 2016
    191
    Crap I bought 3.5mm bullets for my leopard motor lol. What size do I need
  16. #1576
    Jul 2019
    Greeley, CO
    551
    Today I procrastinated replacing my steering servo again!
  17. #1577
    Nov 2018
    Spokane, WA
    695
    You need 6.5 mm for the max5
  18. #1578
    Mar 2016
    1,155
    I don’t understand the copper wire problem. Can you explain?
    Tin would not stick to it due to the coating of the copper I’ve tried using sand paper,blow torch,and alcohol to remove the copper coating and still tin would not stick to it,so I end up taking to a electronic repair shop that has been soldering for years and even he said he had a hard time soldering the copper wire on the motor.
  19. #1579
    Sep 2016
    191
    thank you I'll go to my LHS in the morning for them.
  20. #1580
    Eastern Shore, Maryland
    4,449
    I want you to know, that I'm only telling you this to help you. I'm not trying to be a smart fleshy rear area of a human being, okay. I've soldered bullets on Max5's plenty of times for my friends (so that they could have cleaner installations), and I've never seen a coating on the copper wires. (IMO) there is a very reasonable chance that you're not using a hot enough iron.
    To do Max5 wires you need a Waller100 soldering iron (or equivalent) with a 7/8" flat tip (picture below/right). However, if by a crazy chance you do have some sort of coating on your copper wires, you can use M.E.K. to remove it. Nothing on earth (I'm exaggerating a very small, teeny tiny bit) can stand up to M.E.K. except glass and the material types that make glass.
    P.S. If you ever use M.E.K you definitely want to follow all the safety precautions for using it.
  21. #1581
    Jun 2017
    Ohio
    1,357
    Not trying to speak for him, but I believe his problem was with the bullets on a leopard motor, not the max 5. I feel like we, the forum, had a discussion about checking motor wires for "solderability" when I was upgrading my motor. Either way, I agree with what you said. When I was putting the correct size bullets on my motor I had to put a new tip on for the last one because it just wasn't getting hot enough. Motor wire can be funny, I see how he was having a problem.
  22. #1582
    Sep 2016
    191
    Really bad solder job. Im still learning but it works and no resistance. https://imgur.com/gallery/AfANE4N
  23. #1583
    Jul 2019
    Greeley, CO
    551
    That looks like a cold solder joint. The best way to solder is to tin each wire first then attach. make sure you use flux, enough heat and heat-sink clamps if need be.
    The solder should wick onto the material being soldered. If it doesn't then your material is either dirty or too cold. The solder should never be lumpy at all. That is a sign that the solder and not the wires are being heated.
    Apply the iron to the wires and the solder to the wires, not the iron tip. If the wires are clean and hot enough, the solder will flow onto them easily.
    Also, make sure you are using the correct solder...there are different types.
  24. #1584
    4,449
    Yes, it looks like he was. The good news is, though, that that's the same motor I have on my Xmaxx, so I can still offer him the same advice.
    I shortened the wires on my XLX and Leopard 5892 1340kv motor with no soldering problems using my Weller100 soldering iron. Just for the sake of conversation, mind you, I do test any ESC's and motors I want to solder out first before I start cutting leads.
    From what I've seen in the past and present (from doing many over the years) is, the ESC's and motors that can't have their leads shortened and re-soldered, are usually the smaller ones used for small scale RC's. Not all smaller motors and ESC's, but if I come across one that can't be soldered, it's the smaller scaled stuff.
  25. #1585
    Sep 2016
    191
    Quote Originally Posted by USMC1984 View Post
    Thanks for the tips. Lol luckily I bought 100 pairs of connectors. Also I guess I thought you heated the solder. So I did it backwards. But that's the part of learning
  26. #1586
    Jul 2019
    Greeley, CO
    551
    Do you understand what tinning is? I shouldn't have assumed you or anyone else does, on the other hand, if you do, no offence is meant.
  27. #1587
    Sep 2016
    191
    yea i just need to watch more videos and spend more time doing it
  28. #1588
    Jul 2019
    Greeley, CO
    551
    You might also want to use heat sink clamps to prevent overheating the insulation as well.
    Make sure you have the proper solder and flux too.
  29. #1589
    Sep 2016
    191
    good idea thanks
  30. #1590
    4,449
  31. #1591
    Jul 2019
    Greeley, CO
    551
    What a gem! LOL, that reminded me of the films I saw in the military.
    I love those old tutorial films with no BS, they got right to it in the Sgt Joe Friday voice.
  32. #1592
    Sep 2016
    191
    thanks i'll watch it now. i just got home from town and bought some better solder. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  33. #1593
    Mar 2016
    1,155
    Welp decided to play with truck to test the new leopard 58113 870KV
    Geared at 25/30 1.5mod after 10mins run, boooommm!!! there goes my rear differential ��
  34. #1594
    Oct 2016
    4,708
    Didnít you have fast lane internals?
  35. #1595
    Sep 2016
    191
    https://imgur.com/gallery/dmhy6Zo hows it look? I bought a smaller (physical size) soldering iron and the heat shrink was a little to big so that's why it's burned a little. But that's the cleanest soldering I've done
  36. #1596
    Mar 2016
    1,155
    Yes I did and now Iím trying to get it replace through warranty,Iíve sent email with pics yesterday and still havenít got a respond so will see.
  37. #1597
    Sep 2016
    191
    Oooo that looks painful
  38. #1598
    Jun 2017
    Ohio
    1,357
    If those are the FLM spider gears and pinion that's a shame. They look like they are made of high quality hardened steel on their website and those look like the cheap traxxas low alloy ones.
  39. #1599
    Mar 2016
    1,155
    Tell me about it,Iím disappointed about it,but hope they will replace it under warranty,suppose to covered for warranty if it ever breaks.
  40. #1600
    Sep 2016
    191
    just bought some stronger belts for my belt drive. i stretched the belt i got with the pulleys. if i do the same thing again im going mod 1.5 gears. i got a pair of 225-15mm (wide) 5m belts and a pair of 220-15mm (wide) 5m belts.
