Page 5 of 46 FirstFirst ... 3456715 ... LastLast
Results 161 to 200 of 1809
  1. #161
    Riverton Utah
    5,644
    Quote Originally Posted by 2k2ss View Post
    Wolfslash what brand oil did you use in the diffs
    I used Traxxas 100,000 diff oil. One bottle did both diffs.
    https://vortexhobbies.com/traxxas-di...30-p-1665.html
    Manager at LHS ~7 Years. I've seen some stuff lol
  2. #162
    Dec 2015
    Rochester ny
    159
    I'm also running 100,000 diff oil in front and rear. There was not even half full stock.... I just topped off with the 100k and the diffs felt much stiffer. I did not have enuf to empty them and refill with all 100k. Next time I have it apart I will empty them and refill with 100k maybe 150k rear and 100k front. I also run 100k in my stampede from and rear.
  3. #163
    May 2005
    79
    Thanks wolfslash16
  4. #164
    Jan 2016
    26
    If I was to refill both with 100k would 2 bottles be enough?
  5. #165
    Jan 2016
    24
    Quote Originally Posted by stang9779 View Post
    1 is more Then enough to top off the diffs, if thats what your asking
  6. #166
    Jan 2016
    26
    I'm new to the hobby and have a few questions about diff oil. What's the advantages to thicker diff oil?
  7. #167
    Dec 2015
    Rochester ny
    159
    Wolff said one bottle did both, I only had about half a bottle left over from stampede... make sure you loctite the diffcup screws mine came loose and we're wobbly causing some premature grooves to wear into them... all fixed now melted a spur gear today after lock nut came loose and backed off... oops. Now that is loctited and double nutted. New spur tomorrow... xo-1 has same spur gear when I called LHS they had no "xmaxx" spur gears when I asked about xo-1 the guy got an attitude and came back on the phone was like if it's a bla bla bla then we have one... wait so you just looked at xmaxx part # and xo-1 part # and don't remember if they the same... wow... yes I will be there in am for it thanks... it's to bad I don't work there I seem to know more about the maxx than anyone who works there... was telling them about the erevo pushrods working for shock shafts beacuse they had none when I was there and they looked at me like I was high. it's working it's sitting right there in front of you... been like that since day after I bought it there... I love this thing I beat the snot out of it and it takes it like a champ.
    Thicker diff oil makes it harder for it to one wheel peel so to speak. I think some also call this diffing out... like when you turn and the outside wheel lifts off ground and spins faster than the wheel on the inside with traction is spinning... Thicker diff oil helps prevent this distributes traction more evenly... helps keep truck planted on the ground so to speak. Hope this helped I'm sure someone else can explain it better.
  8. #168
    RC Champion rizz0d's Avatar
    Jan 2002
    1,168
    Quote Originally Posted by Drty42 View Post
    this is a good explanation. i do want to add that as you increase the wt of diff oil you will decrease steering since it will be harder for the wheels to travel at different speeds.
  9. #169
    Dec 2015
    Rochester ny
    159
    Skid plate made from some copper I had laying around... 17/50 gearing today one fan on motor temp was 129 after about 3/4 run of 500 maw 3s packs way down from yesterday also about 20 degrees cooler outside today.
  10. #170
    Maine
    90
    I installed the MM2 and 50/20 gearing in to my xmaxx. It will pull the tires up pretty easy now. Its a completely different truck with the mm2. I am running the stock motor.
  11. #171
    Dec 2015
    134
    backflip
  12. #172
    RC Champion jeteffect's Avatar
    Apr 2015
    1,760
    Quote Originally Posted by jeteffect View Post
    Today I uploaded a few photos of my Spartans and put both up for safe - will be difficult, but attempting to part with them both to make room for when the X-MAXX gets in.
    Sold both Spartans, made space for X-MAXX.
    Also X-MAXX Parts arrived. Got to assembled complete diffs. I'll rebuild them with different oil a h them avail to just SWOP out with stock to experiment.
  13. #173
    Riverton Utah
    5,644
    Just installed Traxxas 18/50 gearing, a new front bumper loop mount, and a new shock cap. I'm going to run it here shortly and let you guys what I think of the 18/50 gearing, should be interesting.
  14. #174
    Jan 2016
    97
    Om the manual it says that it should be filled half up. Do you fill them completely?
  15. #175
    Feb 2016
    4
    Some great ideas here. I think definitely the fans idea here. Otherwise, I've just unpacked mine and taken it for a spin.
    Running two 5000mah/3s batteries. Any idea what the fans will consume?
  16. #176
    Riverton Utah
    5,644
    Quote Originally Posted by minim View Post
    I personally fill them 95% full, I figure any extra will just seep or leak out until it's at the level it wants to be. That and it's way stiffer and dialed in feeling IMO.
  17. #177
    Dec 2015
    85
    Ordered a BL5 and program box from Kershaw. Gonna run it with the stock motor for awhile.
  18. #178
    Dec 2015
    Rochester ny
    159
    Quote Originally Posted by ian408 View Post
    Not enuf to say so, I run 2 castle fans plug straight into reciver box with you splitter... there is no need to go overboard with fans unless your running some crazy gearing...
  19. #179
    Mar 2015
    Central Fl.
    226
    Plasti dipped my Kershaw mount and planning on installing in the morning. Gotta prep the XLX and take her on her maiden voyage. Will be 6s until my two 4s batts arrive from SMC in time for the weekend.
    X-Maxx - 8S Castle XLX/2028
  20. #180
    Jan 2016
    Sacramento, CA
    55
    Random vacation day today, home by myself, and a lot of gifts to myself arrived. Had fun tinkering with the truck.
    Finished my PlastiDip project on the Rims. Turned out okay, but definitely nothing to brag about. Overspray caused bubbles, and I needed to use a razor blade to cut back at the excessive pealing while I took off the paper tap
    Installed 2 Yeah Racing Tornado High Speed Cooling Fans (30x30x10) on both sides of the ESC. They pack a lot of punch for such a small size
    Hot Racing goodies. I didn't install the 54t Steel Center Diff Main Gear yet. And it is heavy. Anyone interested in the motor mount, keep in mind you will not see it when its installed. Other than top of each mount from birds eye view.
    The HR front mount does NOT match the stock mount, as the extended tab is missing. See below.
  21. #181
    Jan 2016
    Sacramento, CA
    55
    Received my Traxxas Fusible Link today. Easy install, just make sure you push hard enough to get the terminal seated fully inside. You'll hear a click when it does.
  22. #182
    Apr 2015
    1,760
    Installed aluminum shock caps.
  23. #183
    Oct 2015
    110
    Got my fuse link and my Bluetooth receiver installed and firmware updated. Gonna put 100k in the diffs tomorrow
  24. #184
    Jan 2016
    55
    Broke my first suspension component, right rear axle carrier. Did it on a multiple front flip into my fence lol. I love how easy the X is to work on, it's easier than working on my son's stampede! Took me 5 mins to fix the axle carrier.
    Also did a first time onroad speed run. Stock gearing, motor, esc and 6s. Did 34.7mph on the gps. I'm satisfied!
  25. #185
    Mojave Desert
    3,014
    You know the rules Jet! No pics or it didn't happen! lol
  26. #186
    Jan 2016
    York PA
    341
    Finally got my Kershaw/HobbyWing stuff installed, now I'm excited to see how high I can get it to fly now that it's twice as fast!!
  27. #187
    Dec 2015
    New Jersey
    389
    Super clean install
  28. #188
    Riverton Utah
    5,644
    Quote Originally Posted by bigtim1985 View Post
    Super clean install
    I agree, it looks close to what factory would do.
  29. #189
    Jan 2016
    55
    I want to see video of that in action. Super excellent install!
  30. #190
    Jan 2016
    26
    +1 for videos
  31. #191
    Jan 2016
    York PA
    341
    http://www.youtube.com/watch?v=GASqK0O97Fw
    Snow bash with the new super rooster setup lol slipper immediately started slipping as soon as it got wet, you can hear the chatter
  32. #192
    Dec 2015
    10
    Quote Originally Posted by yoshgixxer View Post
    Looks great! What exactly did you use?
  33. #193
    Jan 2016
    York PA
    341
    It's leopard BL5 or also known As HobbyWing Max5 esc and a leopard 1340kv motor
  34. #194
    Jan 2016
    97
    What gearing is that? Looks fast on your videos is it still possible to crawl?
  35. #195
    Jan 2016
    York PA
    341
    29/50 seems to drive slow just fine, I don't know how fast it would be in dry grass, but it does seem fast on thick heavy wet snow!
  36. #196
    Mar 2015
    Central Fl.
    226
    Let there be light!
  37. #197
    RC Racer dwilli9013's Avatar
    Dec 2015
    Machesney Park Illinois
    151
    Shhhhweet! Stance like no other just looks Boss!
    XMAXX EREVO SAVAGE Digging Ditches
  38. #198
    Dec 2015
    85
    How do you like the BL5? I just ordered one from Kershaw.
  39. #199
    Jul 2011
    139
    I dig the aluminum mount
  40. #200
    Jan 2016
    York PA
    341
    Quote Originally Posted by bdougwrx View Post
    So far so good, took it out for the ultimate water test, swamped the truck In the river, got it caked in mud and snow, then hosed it off when I got home, so far so good. It also puts out some serious power, trucks unbelievably fast even with the punch control turned all the way to soft. So far I like it Way better then the old XLX it replaced
