cannot wait for my Upgrades for my x=max ..yeah ha they wreckon 65 mph we will see...
How come everyone is out of stock on batteries??? and with my leopard 1340 motor what the best batteries anyone???
4c 5000mah ?? 11.1v or go the bigger ??
Gonna be installing these today since I'm still waiting for spur gears and also will be ungluing tires so I can tape them up![]()
"AVENGED SEVENFOLD "
It's like Merry XMas for your XMaxx![]()
just finish making mount for the Max5 esc,also got it programmed.just need to put everything back together..
MY co-workers and I had a bash party tonight once we got off work. Two Slash 4x4's, a Slash 2wd, my X-Maxx, and a other brand rock racer all went out to a football field with a empty city canal. After about 45 min of mass carnage, and a bunch of batteries, the only truck left running was my X-Maxx. One slash sheared the center drive shaft, the other a stock a-arm, one cooked a slipper clutch, and the other one had some odd ESC glitch. Man I love my X-Maxx, it's a tank!![]()
Manager at LHS ~7 Years. I've seen some stuff lol
Finally Max5 all mounted up and secured,just waiting for UPS to drop off my 46t,50t,spur and bearing for slipper clutch...
Sent from my iPhone using Tapatalk![]()
Received modified wheel adapters for Silverback 5th scale wheels ,mounted 5T Hostile MX tires.
Ran a bit on the street with Hostile slicks > Truck is A Blast <
fabricator
Took the truck out for a spin on my lunch break.![]()
8 X-MAXX's and 1 MAXX....
Well just did a speed test run with f/r spiral cut diff gears,Max5 esc and 23/46gearing,I'm a bit diasspointed,top speed 41mph,it seems like esc wouldn't let it reach full throttle,it takes off very quick but it just won't reach full throttle not sure what's going on,could it be my battery?i fully charged it 5 days ago but didn't get to run the truck til today,I check voltage before running it both batteries were 12.4V and all cells are pretty much the same @4.125 BTW its Traxxas 5000mah 3s 25c.
Best I got was 38, 18/54 gearing, max6 esc and Traxxas 5000 lipos.Maybe time for 8s?
Pats4life, my guess is either you haven't properly calibrated the throttle on the ESC, or your slipper is too loose. Might give those things a try.
Re caliberated throttle but same thing,I guess I'll remove the bearings that I put on slipper clutch and put spring back in and go from there..
Just a little jump.
https://youtu.be/EFV6soPiYTU
Wait till the abs frame melts to the heat sink fins, keep an eye on it, it will happen.
Wait till that abs housing melts to the heat sink fins. Keep an eye on it. It will happen. I run up to 220 degrees, stuff melts that hot.
Well just receive my smc 4s batteries hard case,,and it fits in the battery tray but can't close the security bar,,now what?:/
You'll probably have to convert to Velcro straps like one member did with their X-maxx
Anyone have the link on how to for Velcro battery strap?i search but nothing
It was addressed to me, so here it is: https://traxxas.com/forums/showthrea...cerns-Answered
-=/ X-Maxx - 8S XLX/2028 \=-
Take a look in my buildthread if you want to keep the bars, I get the feel that the batts are more secure for heavy bashing my way![]()
New paint on the prographix body
Take a look at the way I did it: https://traxxas.com/forums/showthrea...=1#post6211951
Much less clean but no hacking involved and took all of 10 minutes to install. I got 8" velcro straps from Amazon. No modification needed beside removing the light gray battery clips
But yeah if you have the time & dedication, Viper's mod is definitely cleaner!
... As for what I did today? Well like the previous 2 weeks I'm just looking at my XMaxx. It's grounded until I receive a replacement Read Transmission Output GearI'm envious and impatient but that's part of the hobby isn't it.
Just tried out 8s on Max5 w/stock motor 23/46 gearing what a difference from 6s,,,truck is crazy fast,I'm running smc 5200mah 70c after maybe less than 10min esc started flashing red,can't be motor temp cuz temp was 157* could it be my battery?
Went to a skate park with my co-workers, and I ran my X-Maxx. I blew up a front tire trying to flip it back over, and after I kept driving it I shattered a front carrier...
Fun time.![]()
