Page 5 of 6 FirstFirst ... 3456 LastLast
Results 161 to 200 of 204
  1. #161
    Dec 2015
    St. Peters, MO
    3,329
    I read that discharging a lipo to 1v per cell then submerging in 3-5 gallons of saltwater(1/2 cup of salt per gallon) for 2 weeks neutralizes it so i can be thrown away in regular trash. Can anyone else verify this?
    Sent from Eastern Missouri
  2. #162
    Jun 2015
    Brossard, QC
    1,211
    Basically you could just use a bulb and empty the battery down to 0v and skip the saltwater.
    Sent from my ONE A2005 using Tapatalk
  3. #163
    Dec 2015
    St. Peters, MO
    3,329
    Quote Originally Posted by IllusionX View Post
    Oh so thats all its doing. Saltwater is just closing the circut and draining batt, got ya.
    On a different note...
    I dont advocate this but, for those experienced enough with knowledge of electricity and soldering, fixing balance plug leads that have come loose out of packs is pretty easy. I had no clue it was even possible. Just a heads up before you toss a perfectly good pack and drop $50+ on new one. I just did it lastnight and back like new again.
    I did realize something. Those leads are delicate and if leads come out of pack with the red n black charging leads then tape all together tightly at base point of where they come out of pack. This will take the stress off those balance leads when handling batts.
    Please dont attempt if unsure, dont have experience or knowledge and let manufacturer or someone who does do it for you.
  4. #164
    Jun 2015
    Brossard, QC
    1,211
    Quote Originally Posted by Briber View Post
    That's one reason I don't like the leads to come out of the lipo like this. Most of my lipo are 4mm inboard connection
  5. #165
    Dec 2015
    St. Peters, MO
    3,329
    Heres what Im not liking about inboard though. If they are 3mm or 4mm connections on battery but everything else in system is 5mm and 6mm bullet connectors on leads going to my 2200kv motor, arent I bottlenecking current right out of the box???
  6. #166
    Jun 2015
    Brossard, QC
    1,211
    Well, since this is a traxxas forum let's take for example a TRX connector. It is good for 60A, and is used on a mamba monster ESC that connect the motors using 6.5mm bullets.
    Alright, so you don't like the TRX connector, and your standard is deans? No problem, but you've got yourself a 60A connector again.
    So the 4mm inboard seems fine to me. Also some batteries only comes inboard, such as saddle packs and shorty.
  7. #167
    20,525
    Do you know what "good for 60A" means?
    Alt-248 on the number pad =
  8. #168
    Dec 2015
    St. Peters, MO
    3,329
    Spill the beans man lol. What are you getting at with that question?
    IllusionX after seeing the wires soldered to pack vs the inboard style, Im still in belief that its way more conductive. I dont want the heat of the bottle necked draw at pack. If its gonna bottle neck Id rather it be else where on the higher power 150a systems. All my opinion. Appreciate yours too!
  9. #169
    20,525
    The amperage rating for connectors is based on the increase in the heat of the connector. It is usually measured with a rise of 20C or 30C. Connectors can and usually do cope with much more that their amp ratings specify. A 60A connector won't burst into flame at 65A or even 100A. Conversely, I've had EC5 connectors heat uncomfortably when pushing a continuous 40A through them.
    Ratings are wonderful...and sometimes useless.
  10. #170
    Jun 2015
    Brossard, QC
    1,211
    Look for connector resistance I guess. EC5, according to SMC testings have pretty bad resistance.
    https://m.facebook.com/story.php?sto...10025885696564
  11. #171
    20,525
    And yet they are rated for 120A. And please check out this webpage from SMC:
    EC5 Male low resistance 5mm connector
  12. #172
    Jun 2015
    Brossard, QC
    1,211
    Well, EC5 does provide lower resistance than XT60.
    I think I did good by going all TRX and 4mm bullet for my batteries.
  13. #173
    Dec 2015
    St. Peters, MO
    3,329
    It doesnt list resistance rating though. Plus no doubt, in general, I know theres exceptions(metal type, coating etc), the bigger you go, inherently is going to be less resistance due to more surface area contact. Im more focused on the inboard batts female bullet connector size. I know its least resistance in tests for that size but how critical is it if its a 3 or 4mm connection in batt there and the bullet connection on back side of esc to motor are 5 or 6mm??? Is there enough of a bottleneck to hinder performane and or cause connection point to over heat in batt??? Does the female bullet size in batt increase for each step up in batt voltage?
  14. #174
    Dec 2015
    St. Peters, MO
    3,329
    So Dcuda69 and I got in to a discussion about trx lipo battery balance lead adapters in a different thread. I ordered one and have a question on it. What do with the two wires not hooked up?
  15. #175
    Jun 2015
    Brossard, QC
    1,211
    You should have gotten the real plug from traxxas...
  16. #176
    RC Champion Dcuda69's Avatar
    Jan 2015
    WI
    2,954
    That is weird looking? Not sure about those 2 leads...strange. I would spend the $12 on the Traxxas piece just for piece of mind. Personally I still don't get the whole iD plug stuff at all but that's just my opinion.
    Slash 4x4 Ult 2150kv
    Rustler vxl
    Ford GT vxl
  17. #177
    Dec 2015
    St. Peters, MO
    3,329
    Quote Originally Posted by Dcuda69 View Post
    Lmbo!!!
    I didn't even know Trx sold one till after I recieved mine in mail, furthermore it was totally misrepresented at time of purchase. I wish Co would be honest, I just don't get why they have to be so shady! I've sent an email we will see what happens. This and an Amazon Prime issue I had is making me loose faith in purchasing things online. I may eat the price difference, spending a little more and just get stuff from lhs.
  18. #178
    Jun 2015
    Brossard, QC
    1,211
    In every lipo thread, I post the original traxxas part so you can't get the wrong part..
    But I think I get what they are trying to do here with the 3rd party cable..
    Remember, traxxas doesn't sell the iD connector by itself, so people need to get creative
  19. #179
    Dec 2015
    St. Peters, MO
    3,329
    No offense in previous post I just though it was a funny picture and conveyed my thought lol.
    I saw that and appreciate when pt #'s are listed especially when a link is posted too! The problem here is... didnt see and realize that til 3rd party cable was in hand lol. To be honest I didn't think Trx would sell a part like that as it promotes usage of non Trx products and when you open a Trx lipo it says use only on Trx charger. Obviously I stand corrected and thank you for your help.
  20. #180
    Jun 2015
    Brossard, QC
    1,211
    The 3rd cable should work too, you just need to follow the instructions(if any) how to plug it into the iD connector.
    Sent from my SM-G930W8 using Tapatalk
  21. #181
    Dec 2015
    St. Peters, MO
    3,329
    There were no instructions in package, so I emailed the company asking how to return. They sent me back pictures of how to hook it up. If im not satisfied they will still refund so it's all good.
  22. #182
    Sep 2017
    150
    I kind of regret getting a cheap lipo charger and I'm thinking of buying a better one soon. What would you guys recommend?? I would be using it for 2 and 3s batteries
    How about this one?
    https://www.amazon.com/dp/B00ND7J38C...otorcopters-20
  23. #183
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by opethrapture View Post
    How about this one?
    What charger do you have now, what type of batteries you run and how many you want to charge at one time and how long you want to wait for a battery to charge?
  24. #184
    Sep 2017
    150
    The charger would be for charging 2 and 3s lipos. It would be great if I could charge 2 batteries at a time and get a full charge within 90 minutes.
    This is the one I have for now:
    https://www.eurorc.com/product/13431...---nimh---lipo
  25. #185
    Jun 2014
    Kansas
    3,013
    Well that charger you posted earlier isn't much of an upgrade compared to what you have now. Only difference is 6a compared to 5a both still charges with only 50watts. I would look for a dual channel charger with more watts output. I'd have to check again on which was my first charger for 2 batteries it was ok still took awhile to charge it was good for me at the time, till I got more lipos since my boys started running them in their cars so I needed bigger charger lol
  26. #186
    Sep 2017
    150
    Ok, I see, thanks for the answer. I'm totally lost and have ko idea what to look for so any help is highly appriciated
  27. #187
    Oct 2016
    4,205
    More wattage faster charge
  28. #188
    Dec 2015
    St. Peters, MO
    3,329
    Hitec x2 on left, Hitec x2 pro (built in soldering station) on right. Imo best little chargers for the power & price you can get. With wifi modules to operate and check status from phone and dc pigtails to charge from car batt out in the field. Oh and use to charge 2 phones at same time too. Both of these are more than sufficient for my charging needs of all these lol.
    I need just one more rc, then Im done,
  29. #189
    RC Qualifier Iansprouse1's Avatar
    Dec 2016
    Asheville NC
    441
    wow! SMC racing must get a sizeable chunk of their income from you!
  30. #190
    RC Qualifier Bige4u's Avatar
    Jan 2017
    Texas
    427
    No wonder SMC is always outta stock... you lipo monger you!
    Bashing along @ 30mph...
  31. #191
    RC Qualifier IndyBama's Avatar
    Jun 2017
    Bama
    468
    Hey big, i think u were the one that told me bout the wp sc8 esc? And the goolrc 2650kv bl motor? Im getting close to have all my parts for my p4de and was wondering wat lipos are best? Which motor 1/8 or 1/10? And wats the best pinion/spur for bashing. Ive almost got my sons p2de done. Goina go stock gearing with the xl5 for starters. Thanks for the help in advance
  32. #192
    Dec 2015
    St. Peters, MO
    3,329
    Quote Originally Posted by IndyBama View Post
    Really??? On the batt question smh... look at post 188 above! Lmbo Gearing all depends on what motor, esc & lipo voltage you plan to run. Anything from 11/54(1/10 on 2s) to 20/50(1/8 on 4s). Decide what combo then we can give better gearing advice.
    Quote Originally Posted by Iansprouse1 View Post
    When I find a good quality product that withstands my abuse, i gotta stick with them! They will continue to get my business if they stay that way too!
    Quote Originally Posted by Bige4u View Post
    Thats funny, hey dont be haten on me because Ima preferred customer. Oh btw wanna buy a couple? Haha.
  33. #193
    Jun 2017
    Bama
    468
    Im goina go with the wp sc8 and the 2650kv. From the sounds of it smc is goina b my best bet lol
  34. #194
    Dec 2015
    St. Peters, MO
    3,329
    My 2700kv sc8 combo runs 15(maybe 18 cant remember lol)/50 on 4s. But its a place to start once installed.
  35. #195
    Jun 2017
    Bama
    468
    What plug does the smc use briber? Just tryn to be ahead of my build lol. But a build is usaully never done, theres always sumthin new to add or change
  36. #196
    Jun 2014
    Kansas
    3,013
    When you go to order them you have a choice of your style plug. Traxxas is one of them
  37. #197
    Dec 2015
    St. Peters, MO
    3,329
    Like er33 said make sure you specify which connector.
  38. #198
    Jun 2017
    Bama
    468
    Ok, gettin ready to check them out now. Slow goin on gettin parts. Cant wait to get them runnin!!!!!
  39. #199
    Jun 2017
    Bama
    468
    Aight Briber, u talked me into it lol. I was checkn out smc. Think im goina go 2s wen i buy batterys. Wats goina be best for the wp sc8 esc and goolrc s3674 2650kv bl motor?
  40. #200
    Sep 2017
    150
    Since it’s impossible to use 3s battery on the indoors course I have been running 2s batteries which provide sufficient punch. Instead of buying another 2s lipo I was considering switchin to 3s Instead and using the traxxas link taking down the throttle to about 60-70%. Would that work??
    When driving outdoors I could just switch back to 100% and enjoy the full power of my 3s batteries
