Results 1 to 33 of 33
    RC Qualifier guardog's Avatar
    Nov 2011
    Pa
    745
    Tmaxx Build with Picco .28
    Just a pic of my recent Tmaxx Build. Looks so good I may just keep it as a shelf queen
    uh oh.... that didn't sound good
    Apr 2013
    747
    What tires are those?? Is that engine a direct bolt on? What u need to get it to work on a 4907 maxx? More power than a trx 3.3? Can the stock grey tranny handle this engine or needs metal gears?
    Jun 2015
    36
    It's a direct fit with the OFNA mid block motor mount. The JL Max .28 is called a mid block because it's got big block displacement and a small block exhaust port, witch is why it fits on a stock Tmaxx chassis because a big block exhaust doesn't fit between the engine and shock tower. Even the small block header has to hav crazy bends in it to work. It blew my mind when Traxxas extended the chassis on the Tmaxx and they did it in the front of the truck instead of the rear. If they extended the rear ther would be many more engine options including big block. The only way to run true big block is to find a big block chassis (extended in rear). The JL is a very potent mill though.
    Jan 2015
    28
    Looks great man!
    I'm definitely going with this motor setup once I go blow through a few 3.3 I have.
    Those 17mm hex wheels?
    Apr 2013
    747
    Can a gray tranny hold up to the power? How about the driveshafts?
    Nov 2011
    Pa
    745
    Have not ran it, so I can not give an honest opinion of transmission. From viewing other posts, I've seen where other have installed Robinson Racing steel gears. I'm going to try the gray tranny stock gears with F.O.C. first and replace if necessary. I have installed 17mm hex adapters to accommodate the Axial Yeti XL tires. The chassis is an extended version (4908) I believe.
    I have the Picco .26 in my Revo an absolutely love it. Crazy power throughout the entire band paired with a THS exhaust.
    Still have a few more shiny parts to add but almost there. Had enough parts left over that I built a "Beater" maxx also.
    Nov 2011
    Pa
    745
    Other side showing THS pipe.
    Jul 2014
    Broken Arrow, OK
    209
    Sweet ride guardog. What bumpers are those?
    everything being dif doesnt mean anythings changed
    Oct 2015
    DSOTM
    36
    I really dig those tires they just look great. I think the bumpers are proline right? With over three times the hp it's going to go like a stabbed rat.
    Ps don't leave it on the shelf, my Revo has been on the shelf for 6 months and now I have to wait another 4 months to use it again, it's agony I tell yah.
    Jun 2015
    36
    I've been running the JL for a year now, plastic drives and axles don't last very long but no trouble with black tranny so far. Easier to tune than 3.3 and makes my Sportmaxx dance.
    Jul 2014
    Broken Arrow, OK
    209
    Quote Originally Posted by Liebherr View Post
    Bumpers are possibly Pro-line, eh? I'll look into that, i really like the way they look.
    "...like a stabbed rat" don't think I've ever heard that one, it sure made me giggle.
    Nov 2015
    8
    Looks like the header barely fit😊 wish I woulda known about this a year ago when I started my bb build, ended up finding a acncm mega chassis, then took another 2-3 months to find engine mounts.... After a few months of hunting down parts I managed to get my Lrp to fit.... I now run a ue thunder chassis while the acncm hangs on the wall.... Nice build though
    Jun 2015
    36
    Sweet, I'm running the LRP ZR .32 in my other Tmaxx, a Dynomite BB chassis. Smokin my buddies 5.9 Savage every time.
    Nov 2011
    Pa
    745
    The tires are off of my Yeti Xl, Put on 17mm hex to accommodate them. The bumpers are proline with working lights. Just trying to figure out how to turn them on / off with 3rd channel on transmitter
    Nov 2011
    Pa
    745
    Finally have it finished over 1,100.00 invested . Every part is aftermarket. Went with RPM arms just so there would be a "flex" point if something were to go wrong. Very pleased with the outcome
    13,321
    Very nice! It's a Dodge but I'll give credit where due regardless.
    Dec 2015
    lakeland fl
    29
    yea that looks reel good lots of luck with it
    Nov 2011
    Pa
    745
    Love the Dodge Double G. All three of my Tmaxx's are sporting the Dodge body.... Thanks !
    Oct 2005
    South Florida
    19,477
    Looks sweet !!!!
    Love the build, don't love the air filter... IT didn't flow well enough for the 2.5 yet alone a thirsty and demanding .28
    Change the filter and you will unleash the beast... I'll put dollar to dime, you put a more updated 2 stage filter with better flow you will need to richen your settings from the old filter due to more air flow into the engine through the carb.
    More air needs more fuel = more power. You prbably already know this, it's just a point... I think it looks great, nice and beefy!!!!!
    Enjoy
    All Lives Matter
    Jun 2015
    36
    Good eye naught, I was too distracted by all the shiny parts
    Nov 2011
    Pa
    745
    Will do nitronaught. Thanks for the input and compliments!
    May 2014
    ohio
    1,300
    Quote Originally Posted by guardog View Post
    i can explain how to do this, just shoot me a pm and i can tell you how to control the lights from your 3rd channel.
    2.5r Pede, 2-speed O.S.21tm rusty , 3.3T-maxx
    Nov 2011
    Pa
    745
    ordered switches. Thanks mxaustin
    Oct 2005
    South Florida
    19,477
    Here's the quick cheap way.... There are others that support more lights as well. http://www.amainhobbies.com/rc-cars-...i24257/p151670
    Operates off the 3rd channel.
    All Lives Matter
    Nov 2011
    Pa
    745
    Just ordered 3 of these. Hope they work well. Had good reviews
    RC Champion MaXXL's Avatar
    Nov 2015
    South Florida
    1,222
    Never used lights before so i'm in the dark (lol pun). Is the 2A switched output going to be used to power the lights directly? What is the 5A output going to be used for? Receiver?
    10 RCs and counting 😅
    Apr 2013
    747
    The front and rear of the truck have the same amount of preload on the springs?
    May 2014
    ohio
    1,300
    its a very similiar design to the one i used, however it has a total of 6 wires where mine had 3. that may get a little more complicated
    Nov 2011
    Pa
    745
    Yes. For receiver or future winch
    Nov 2011
    Pa
    745
    Quote Originally Posted by 2010 View Post
    Yes. They are equal in all 4 corners
    Jun 2015
    Virginia
    30
    That's a nice build. I am getting ready to drop a .28 jl in my maxx. How do you like the motor?
    Oct 2005
    South Florida
    19,477
    Quote Originally Posted by fordgtr06 View Post
    Hope you have one, because I'm pretty sure they are discontinued..... Along with all the Picco line..
    All Lives Matter
  33. #33
    69
    I've seen this truck for sale on eBay and I think one other place. Nice truck mate!! Love the power plant setup!! I'm debating turning my Tmaxx 3.3 I to a Picco power planted animal. Hard to come by these Picco engines nowadays.
