Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 122
  1. #41
    RC Racer mdschmidt90's Avatar
    Dec 2014
    Fruit Heights, UT
    248
    This thread is an interesting read for me.... I'm really liking the sounds of throwing in the mamba monster x esc vs spending almost $400 on the cc xlx 2028 combo. I'd have to wait and see long term how you guys are doing woth this esc combo vs stock. It sounds like you guys are having good results So far! Where are you guys finding these esc for $100? Lowest I found was liquid rc on eBay for $140.
  2. #42
    Dec 2015
    New Jersey
    389
    I got mine from liquid rc but had a coupon from ebay which brought it down to $100. Between the 18t pinion, the castle motor fan, and the Monster X, I couldn't be happier with the truck. Honestly, unless you are trying to do standing backflips I think the 2028 is overkill for this truck. I'm not saying that if someone gave me a free 2028 combo I wouldn't throw it in but with the few mods I have done thanks to this forum I am super happy with the truck.
  3. #43
    Dec 2014
    Fruit Heights, UT
    248
    Quote Originally Posted by bigtim1985 View Post
    Right on bro! That's what I like to hear. I havent had much time running my truck yet but the things I hear on this thread I've noticed with the truck, I would like a bit more speed (changing the gearing) and more low end punch so 100-140$ seems legit plus all the stock esc issues has me concerned. I will give it more time and see how you guys do with it. Keep us posted! Thanks
  4. #44
    47
    Soldered mine up tonight. Didn't get a chance to drive it. The x looks good though!
  5. #45
    Dec 2015
    Bloomington, Indiana
    47
    How big of difference is there between the monster 2 and the monster x I have a 2 laying around might give it a try.
  6. #46
    Eastern Shore, Maryland
    4,042
    The original Mamba Monster was rated 120A continuous and 300A burst. I would assume the Monster X is even higher. If it's only pulling ~120A peak then this ESC is perfect for the X-Maxx.
    I talked to Castle a little while ago, because I was looking at going to a MMX for my Emaxx. Castle told met that the output power of a MM1, MM2, and MMX were the same. The difference was the MM1 wasn't waterproof, and the MMX had Data Logging and a stronger BEC. He also told me that, unless I wanted Data Logging, it wasn't worth the cost difference between a MM2 and a MMX.
  7. #47
    Mar 2013
    243
    Did they mention if they thought it was ok to use in an xmaxx? I don't care either wAy mine works awesome just curious.
  8. #48
    4,042
    No, that conversation was before the Xmaxx came out. I will be calling them soon to ask about a XL-X. When I do I'll ask, and tell you what they say.
  9. #49
    Mar 2013
    243
    I was the thinking about what you said about the mm2 vs mmx. I personally think the X is way better. Not only do you have the option of running a sensored motor but the biggest difference for me is the smooth start up running sensorless. I can basically crawl with this truck cause the X is so smooth on start up. The monster 2 kinda jumps to like 20% throttle when trying to go slow. The X has virtually no cogging and almost feels sensored.
    Just some thoughts I had.
    I've been messing with rx8's lately and I really like em but not waterproof. The feel and smoothness is even better then castles.
  10. #50
    Jun 2013
    MN
    161
    Put in my MMX and hitec radio last night. The truck is like a whole new animal.
  11. #51
    Dec 2015
    New Jersey
    389
    Anyone who has switch over to a castle ESC noticed lower motor temperatures? I couldn't get mine much over 100f yesterday with an outside temp of 50f. Usually I'm closer to 140f. I have to do some more running to verify this. It'd be funny if a simple ESC swap solved all the issues people are having with this truck....minus the leaky shocks...
  12. #52
    Mar 2013
    243
    I think the temps are lower because it has so much more torque you can't hold it wide open as much. More power makes you not use as much throttle. That's my theory anyway
  13. #53
    749
    Does the 24v fan blow that much stronger than a 5v one? Thanks
  14. #54
    Mar 2013
    243
    Yes and no. Fans are rated for rpm and cfm air flow. In general it seems like the higher voltage fans move more air. I guess they are more efficient? Gotta look at the cfm rating though to compare. Some 5 volt fans move allot of air.
  15. #55
    Dec 2015
    New Jersey
    389
    Did another run today with the Mamba X and 18t pinion. My motor temps did not go over 100f after hitting LVC on my SPC 3s 6500 65c's. I'm gonna do a couple more runs, but it looks like the fan isn't needed anymore. I'm amazed that simply changing the ESC has such an effect on the truck.
  16. #56
    Dec 2014
    Fruit Heights, UT
    248
    What's the temperature outside?
  17. #57
    RC Qualifier rtmike's Avatar
    Oct 2015
    Across river Portland,Or.
    680
    Liquid RC must be out of the $140 ESC's.
    I went through AMain & found an online coupon code, $15 off $150 ( 151516 ) that got it down to $146 with shipping.
  18. #58
    Jan 2016
    24
    were all just buying them too fast ;x, i just picked up one off him thursday
  19. #59
    Dec 2015
    New Jersey
    389
    today was in the 30's, my other run with the same temps was in the 50's.
  20. #60
    Dec 2015
    New Jersey
    389
    where did you guys mount the switch for the Mamba X esc? I can't find a good spot.
  21. #61
    Mar 2006
    Canada, Québec
    649
    The HW MAX6 are 145$ with coupon on amain and I think it better than mamba x, the Max6 can handle 8S with a 1200kv motor and he have a minimum 160 amps and maximum 1050. The Max6 have a electronic switch versus a mechanic switch on the mamba x. The Max6 have a super Bec 25 amps versus 8amps on the mamba x.
    Stampede 4x4 1415 1Y 2400kv, 4S 5200 30C
  22. #62
    Jun 2010
    54
    Using an old Mamba Monster Mount for my Emaxx, some M3 Standoffs that are 25mm tall, an Aluminum Plate, and a little bit of hand fabrication, I was able to mount mine last night. Going to finish the wiring tonight. I am happy with the way it turned out. You can still see the X, the switch is mounted nicely, and most of the wires are covered up giving it a clean look.
  23. #63
    Dec 2015
    New Jersey
    389
    Excellent. I just ordered the same Mamba mount last night because my ESC tape is already coming loose.
  24. #64
    49
    I just picked up my X-Maxx tonight ( haven,t even opened,box yet )and have the Mamba X being delivered . Just wondering how you guys soldered the dual Traxxas connector to Mamba X esc? Anyone have pictures?
  25. #65
    Dec 2015
    New Jersey
    389
    I used deans connectors and one of the short motor wires they give you with the Mamba X to make the series connector. Use your stock ESC for reference.
  26. #66
    RC Champion SLW-SVT's Avatar
    Lake Jackson, TX
    1,638
    I went out for my first run with the MMv1 installed and it was great having a custom throttle curve and 40% torque limiting. It's definitely a new animal. On 46/18 gearing my temps were 114 motor and 105 esc.
    Here's the mount i used. bottom is from the Hot Racing MM mount kit and the top is the traxxas mount with the legs cut off. The standoffs are flattened on the back side.
    X-Maxx Max6 | EB48.3 | ET48.3 | Axial Grave Digger
  27. #67
    RC Qualifier SkidMan's Avatar
    Oct 2011
    Quebec,Alma,Lac-St-Jean
    298
    Nice job!!!!!
    -Blue X-maxx
    -E-Maxx 60.2mph
    -Spartan 48.2mph
  28. #68
    Riverton Utah
    5,642
    Looks good guys! I love how factory it looks.
    Is owning 27 RC's too many? No way!
  29. #69
    Jul 2013
    204
    This might be another option for mounting Mamba Monsters and MMXes. HPI part #103676. Not sure if it fits the Xmaxx, but it's a nice ESC tray, I use it on different cars.
  30. #70
    4,042
    I spoke to Castle the other day to ask them some more questions. One of my questions was the one you wanted me to ask. They said that they didn't know for sure (as of now), due to them not having an Xmaxx to test out different Castle equipped setups with it. They did say though, that they would like to have that kind of information out for us by this summer. They also said to be careful with your MMXtream ESC setup, because it may not have enough umph when the weather gets warmer. Anyway, I told you I'd ask, so I wanted to tell you all what they said.
  31. #71
    13,500
    Not doubting what you are righting, I'm doubting that a company like Castle would not have an Xmaxx in their possession to do some R&D. Each day that passes by money is lost. Sounds to me it is a rubber stamp excuse.
  32. #72
    Mar 2013
    243
    So they think it may get hot in the summer. I'll deal with it then lol for now it's perfect.
  33. #73
    4,042
    Of course we both don't know for sure, because neither one of us are there in person...you could be right, though. I do know two things. One is, I have talked to this guy on many occasions over the years, and he has always seemed square to me. And two, I can believe that Castle hasn't gotten an Xmaxx yet, because one of my local hobby shops hasn't receive their first shipment yet while another one of my local hobby stores has gotten in three shipments of three Xmaxx's...all before Christmas.
    Something else we might want to consider, is that, Traxxas didn't partner up with Castle this time for their Xmaxx's power needs. Being this is the case, there wouldn't be any need to give Castle a working prototype of an Xmaxx for them to work with. All-in-all, I can at least entertain the idea that Castle is giving me some reasonable scoop.
    Yep, but I agree with you. I wouldn't worry about it until then. I'm kind of leaning towards a Castle XL-2, and maybe even a Castle 2028 to go along with it. I haven't 100% made up my mind yet. The nice thing about you using a Castle MMxtreme is that it's more cost effective, and when installed it looks like a true factory setup.
  34. #74
    Mar 2013
    243
    I've overheated many esc's through the years. Luckily with thermal protection it's no big deal and causes no damage.
    So with that said when it warms up I could care less if it gets hot. My concern would be if it hits thermal shutoff constantly. I'm guessing if the fans workin it will be fine. If not I'll cut the top of the case open and mount a huge fan in that to. Only if that fails will I be upgrading to an xxl. All about air flow. Even the motor with a huge fan can easily take loads it wasn't designed for. As long as we can cool it , it'll work fine
  35. #75
    Mar 2013
    243
    As far as the 2028 goes I still believe the kv is to low for our application. And I really think even if you upgrade the esc the motor will be fine. It's not overkill and has the rite amount of power.
  36. #76
    Jan 2016
    24
    Got my MM-x all dialed in last night, amazing little upgrade.
  37. #77
    Jun 2013
    MN
    161
    Holy wheelies batman......
    Put in the MMX, it was pretty good. Switched to 19/50 gearing...........look out. Can do complete backflips from a standstill. Can pull wheelies at about 60% throttle. Just insane.
  38. #78
    Dec 2015
    New Jersey
    389
    how are your temps running 19/50?
  39. #79
    Jun 2013
    MN
    161
    Less than 110*, though it is only 22* out in MN.
  40. #80
    Dec 2015
    9
    That install looks great! Could you post some links to where you got the mounts from?
    Also, I just ordered the mamba monster x and do I need to order any bullets to make this esc fit?
