Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 122
  1. #81
    Eastern Shore, Maryland
    4,028
    As far as the 2028 goes I still believe the kv is to low for our application.
    Viper did it with gearing of 35/46, and with 6s he is getting a strong torquey 38 mph.
  2. #82
    Dec 2015
    New Jersey
    389
    Quote Originally Posted by wrightcs77 View Post
    Less than 110*, though it is only 22* out in MN.
    are you running a fan on your motor? I'm going to give 18/50 a shot sometime this week.
  3. #83
    Dec 2015
    9
    Quote Originally Posted by SLW-SVT View Post
    I went out for my first run with the MMv1 installed and it was great having a custom throttle curve and 40% torque limiting. It's definitely a new animal. On 46/18 gearing my temps were 114 motor and 105 esc.
    Here's the mount i used. bottom is from the Hot Racing MM mount kit and the top is the traxxas mount with the legs cut off. The standoffs are flattened on the back side.
    I just ordered my mmx esc, could you post some links to what you used to mount it with? Looks very clean. And could you tell me if I have to order any bullet connectors for this new esc?
  4. #84
    Jun 2013
    MN
    161
    Quote Originally Posted by bigtim1985 View Post
    No fan on motor, haven't needed one yet.
  5. #85
    Jun 2013
    MN
    161
    My data log info.
    Smc 9000mah 3s
    MMX esc, torque control set to 0 (not limited at all)
    Stock motor
    19/50 gearing
    In the snow, 26 degrees outside, wet tar roads
    Took it out to do some data logging.
    Max amp draw : 145.6 amps
    Max watts: 3,160
    Max esc temp: 184.2
    Max motor rpm: 71,890
    Esc fan is not turning on, have to look into it.
    Hope that helps
  6. #86
    Dec 2015
    New Jersey
    389
    what's a reasonable temp range for the mamba X? I'm hitting 156F running 18/54. according to the castle website, the fan only runs above 150f.
  7. #87
    RC Champion SLW-SVT's Avatar
    Lake Jackson, TX
    1,638
    Quote Originally Posted by Redabe87 View Post
    The bottom plate is this: http://www.ebay.com/ulk/itm/281871520424 and the top is the Traxxas mount with some standoffs. I think the Traxxas mount is all you need. Maybe someone can confirm that here.
    X-Maxx Max6 | EB48.3 | ET48.3 | Axial Grave Digger
  8. #88
    Mar 2013
    243
    My data log info.
    Smc 9000mah 3s
    Stock motor
    19/50 gearing
    Max watts: 3,160
    Max esc temp: 184.2
    Hope that helps
    71,000 rpms is a little off also.
  9. #89
    Jun 2013
    MN
    161
    Quote Originally Posted by Dragonfueled1 View Post
    It is half that, I didn't change the motor reading to 4 pole.
  10. #90
    Mar 2013
    243
    Ahhh ok I don't remember having to change that but I guess I did .
    Wonder how much the fan will help cool the esc. I'm guessing 30 degrees at least
  11. #91
    Sep 2010
    19
    Thanks for sharing. I haven't had issues with my ESC at all, but I bought the MMX to replace it before I change the gearing on the truck and produce more heat.
    Slash 4x4 ultimate / X-Maxx / Losi 5ive-t
  12. #92
    Jul 2011
    139
    I went to buy a mmx today and the hobby shop didn't recommend it at all. But if I wanted to anyway. That I should use a capacitor block.
    Dunno what to do
  13. #93
    Dec 2015
    104
    Quote Originally Posted by anthonykujo View Post
    Dunno what to do
    They were likely not recommending based off the manufacturer's recommendations. Amp-wise, it's fine. The Xmaxx is big, but not really carrying the weight to justify a 1/5th esc IMO.
  14. #94
    Jul 2007
    1,323
    Castle doesn't recommend the MMX for vehicles over 15Lbs and the X-Maxx weighs more than that, that's why the hobby shop doesn't recommend it.
    Castle doesn't like to give Amp ratings for their ESC's so they give stupid (IMO) weight recommendations that really don't mean anything. In reality the ESC doesn't care how much the vehicle weighs, it's all about the load placed on it. The higher you gear a vehicle the more Amps the motor will draw. You could easily gear a 1/8 buggy or truggy that weighs under 15Lbs to draw more amperage than the X-Maxx does with the stock motor and gearing.
    Many people have switched to the MMX in their X-Maxx and it works fine. Just use stock gearing to start and keep an eye on temps and go from there.
    I need R/Cers anonymous.
  15. #95
    Jul 2011
    139
    Ok. Should I use the capacitor block or just run it.
    They have it for $149 which isn't too bad
  16. #96
    Mar 2013
    243
    I haven't used the capacitors neither has anyone else and they have been fine
  17. #97
    Jul 2013
    204
    Looking at the ripple voltage logs from the MMX posted in another thread here, I would add one.
  18. #98
    Jan 2016
    York PA
    341
    Quote Originally Posted by LizardXO-1 View Post
    I agree with this guy, A cap pack will only help the esc live longer, I believe these XO1 guys, he's not the first one to say they use a cap pack on the MM esc.
  19. #99
    Jan 2016
    162
    I'm going to try and run a log today, I'll let you guys know what the ripple looks like.
  20. #100
    Jul 2011
    139
    Use the castle block? Is it waterproof?
  21. #101
    Mar 2013
    243
    I'm curious now. I ordered a castle cap pack. I had no issues at all but was seeing up to 3.5 volts ripple so let's see if this lowers that a little. I'll post up once I try it out!
  22. #102
    Jul 2011
    139
    I'm going to buy one today.
  23. #103
    Feb 2016
    78
    Quote Originally Posted by BigBird82 View Post
    Using an old Mamba Monster Mount for my Emaxx, some M3 Standoffs that are 25mm tall, an Aluminum Plate, and a little bit of hand fabrication, I was able to mount mine last night. Going to finish the wiring tonight. I am happy with the way it turned out. You can still see the X, the switch is mounted nicely, and most of the wires are covered up giving it a clean look.
    That looks awesome! I'm going to be doing the same but I'm also adding the castle cap pack. Do you have more pics of your setup?
  24. #104
    Feb 2016
    78
    Did you have to reverse the esc?
  25. #105
    Jul 2011
    139
    Havent had any problems with mine yet.
    Turned brakes down to 50%........ Still touchy
  26. #106
    Feb 2016
    78
    I was just reading on the castle site it says I need the castle quick connect duo to view the data logging. Is this true? I know I need the castle link.
  27. #107
    Dec 2015
    New Jersey
    389
    you dont need the duo, it just lets you connect to the link without having to open the receiver box and unplug anything.
  28. #108
    Feb 2016
    78
    OK thanks.
  29. #109
    Feb 2016
    78
    Couldn't I just use a y harness?
  30. #110
    Dec 2015
    New Jersey
    389
    I though about that too, except if:
    If your ESC has a 3-wire AUX connection (White/Red/Brown) you MUST disconnect it prior to connecting your ESC to
    the Castle Link USB adapter. Failure to disconnect a 3-wire AUX connection from the receiver may result in damage to the Castle Link USB adapter.
  31. #111
    RC Racer X-Maxx's Avatar
    Aug 2017
    145
    just a quick question, on the mmx, can you disable dataloging if we don't have a windows computer? I've looked online but nothing turned up.
  32. #112
    Aug 2017
    255
    Unless you have a Jamba x laying around in my opinion it not feesable to but one for $140 she. You can buy a he max6 for about the same. It capable of 8s where the mamba only goes up to 6s. Cool to know it will work in the x maxx ok though.
  33. #113
    RC Turnbuckle Jr. mwe-maxxowner's Avatar
    Feb 2004
    pageland, sc(south of monroe)
    5,723
    I do already have one, and I don't care about running 8s. I want to run 6s, with no fires. Lol
    Sent from my Moto G (5) Plus using Tapatalk
    460, straightpipes, buried throttle, nuff said :D
  34. #114
    Aug 2017
    255
    Lol I hear ya. I'm probably going to go with the hw max 6 so I have the ability to run 8s if I want to.
  35. #115
    Oct 2016
    4,191
    The castle cap pack is literally the most meager cap bank for sale. Get a Kill mode or Saga pack.
  36. #116
    Aug 2017
    255
    What is the benefit of this for the esc?
  37. #117
    Oct 2016
    4,191
    Quote Originally Posted by Nightflier x4.6 View Post
    They significantly reduce ripple voltage(voltage sag). Ripple voltage kills esc's. So better performance and longer life.
  38. #118
    Aug 2017
    255
    Wow I might have to do that mmx.
  39. #119
    Oct 2016
    4,191
    10% ripple is borderline. It's not as if the cap packs are expensive. I'd do it on any ride that's an amp hog.
  40. #120
    Aug 2017
    255
    No the farly cheap I thought
