Results 1 to 12 of 12
    Jan 2016
    3
    Converting Traxxas connector to XT60?
    Is it possible to remove the traxxas connector from the battery/esc and switch to an XT60 connector? I can do that type of soldering work very easily. But, would it be safe to use? I have a stock 8.4v 3000mah NiMH battery but find it annoying to leave my (non-rc) car running to charge it. Already have a fancy battery charger/balance for my other lipos/hobby batteries and don't want to pay another $50 just for a traxxas specific one. Thoughts?
    Nov 2015
    michigan
    236
    Yes,it is very common for people to change connectors.
    Jan 2016
    3
    That's good to hear. Thanks
    Jun 2015
    Brossard, QC
    1,211
    If all your RC are using XT60, yes just switch to that.
    Dec 2001
    Everywhere man
    1,210
    Quote Originally Posted by IllusionX View Post
    That's what I run on everything, great connector and yes any can be soldered on it's an easy job.
    Vaterra Team Driver
    Meow
    Jul 2018
    5
    Can someone please share pic of your XT-60 setup on the RC car? I'm confused about Traxxas own connector that has extra balance lead within the actual plug? Not sure what the extra small lead is doing which a XT-60 type connector will not have?
    Dec 2003
    Dekalb, IL
    2,192
    Quote Originally Posted by JamesHavoc View Post
    Depending on the traxxas pack, the small lead is the balance wire. On a 3S pack, there would be 2 small leads and 4S, 3 small leads. The two main power wires a 2 balance "leads". So, to replace the end on those packs, you would have to make jumpers from the main leads to the proper balance plug leads.
    You can kind of see how the traxxas plug is wired here with a 3S pack:
    For a 2S, you would have to make a connector similar to this and the extra single wire would go to the middle pin in the connector:
    Expert rigging at it's best!
    Jul 2018
    9
    New to the sport here:
    I seem to be a little confused. (And, of course, I am 6 months old in the sport and am already seeing the need to upgrade my battery charger; which presents a problem (for me) when looking at the Trassas battery connector. (Four of my five batteries have the Traxxas ID connector.))
    The text of the “07-05-2018, @ 10:14” says that a 3s pack has two small leads (It is so on my Traxxas 3s, 5000 battery).
    Then the first diagram above “how a 3s LiPo is wired” shows 4 wires on the balance plug.
    Then the next picture shows a Traxxas 3s (like mine) with two balance leads (just like mine).
    Then in the third picture (1,2,3) a 2s is shown; and using three wires (my 2s Traxxas batteries only have one wire).
    Might anybody be able to help me out?
    Jul 2018
    9
    Oh, yea; if I change to the XT-60 connectors, how do I charge using my Traxxas Charger?
    Thanx
    Dec 2003
    Dekalb, IL
    2,192
    To do a 3S, you would need a voltmeter to make sure your putting the correct small wire in the correct pin of the balance plug. From ground to positive, the voltage should increase in increments of 1 cell's voltage.
    RC Champion lektro's Avatar
    Nov 2016
    Virginia Beach/ South USA !
    1,922
    I would first, start my own thread. Forum etiquette
    Choose Life !!!
    Jul 2018
    9
    Thanx for the direction. My bad.
