Page 2 of 5 FirstFirst 1234 ... LastLast
Results 41 to 80 of 168
  1. #41
    Jan 2016
    7
    i am thinking to build one ground up just with aftermarket parts.... btw i have mine from 2weeks Awesooome truck
  2. #42
    RC Qualifier gunbar223's Avatar
    Lubbock, TX
    321
    Quote Originally Posted by HooliXDenmark View Post
    Sweet :-) nice to get to know evert little single washer and screw in your toy !!!
    Indeed a sweet toy.
  3. #43
    Lubbock, TX
    321
    Quote Originally Posted by S1000RR View Post
    I got mine Dec. 23 and when I got it out of the box I knew then I needed another one. Took me about a month and a half to save up for the one I got. I didn't want to start saving all over again and wait to buy another so this is the route I took. Good luck on your build when you get started.
  4. #44
    Lubbock, TX
    321
    X-MAXX #1 got some attention.
    6 X-MAXX's total one built from ground up 3 8s!!!
  5. #45
    Oklahoma City, OK
    2,704
    I see more parts than I do build - someone is slacking! Whats the price tag looking like? About the same as new or a little less?
    "RED"
  6. #46
    Lubbock, TX
    321
    No slacking. Diffs have been dropped in as well as slipper assembly. My steering servo will be here Saturday. This last batch of parts ran 85 and add 52 for the servo. I will tally it all up in just a few and see where it stands.
  7. #47
    Lubbock, TX
    321
    Total as of 3/2/2016 is $376.07
  8. #48
    Lubbock, TX
    321
    Front
    Rear
    Slipper minus spur gear
  9. #49
    Lubbock, TX
    321
    Servo can now be installed.
  10. #50
    Lubbock, TX
    321
    Servo installed.
  11. #51
    Lubbock, TX
    321
    Should I use a set of these Yes or No?
  12. #52
    Dec 2015
    New Jersey
    389
    I'm running knock-off brand 5th scale trenchers on mine. Looks a little weird at first since the tires are narrower, but the truck definitely handles high speed a-lot better.
  13. #53
    Oklahoma City, OK
    2,704
    what do they look like installed?
    "RED"
  14. #54
    Lubbock, TX
    321
    bigtim, can you post a pic of your rig with trenchers?
  15. #55
    Dec 2015
    New Jersey
    389
    Sure I'll have a pic up tomorrow morning.
  16. #56
    Dec 2015
    New Jersey
    389
    Fronts are 195x75 and rears are 195x80. They are Rovan "Excavators" aka Proline Trenchers.
  17. #57
    Lubbock, TX
    321
    Thank you bigtim for posting up your setup. I will have to check the sizes on the ones I have they may be all the same.
  18. #58
    Dec 2015
    New Jersey
    389
    here's a link to where I just ordered another set.
    http://www.ebay.com/itm/261983991611...%3AMEBIDX%3AIT
  19. #59
    Mar 2016
    Quebec
    183
    Do you use thermal paste between the motor and heat sink (aka metal fins)?
    I know computers a lot better than RC trucks and you'd never, ever install a CPU heat sink without thermal paste. It doesn't look like Traxxas used anything at all. For high-end, overclocked gaming PCs, we lap the CPU (i.e. sanding flat using a piece of glass and wet/dry 1200-1600 grit sand paper) because the IHS (integrated heat sink) on CPUs are never perfectly flat. Flat IHS + flat heat sink + thermal paste = best contact area possible = best thermal dissipation possible and yes, it does make a noticeable difference in temps. Since you seem quite serious about this build, maybe this is something you'd like to try
    Regardless, your project, thread and pics are awesome!! Kudos.
  20. #60
    Feb 2016
    582
    On my Stampede I tried using this thermal pad that I cut to size. The heatsink kept shifting around after large jumps. This helped it stay in place. http://smile.amazon.com/dp/B00UYTTXSM
    I haven't tried this but if needed you can get thermal glue but be prepared for a one time use only if the motor were to die. http://smile.amazon.com/dp/B0009IQ1BU
    On the X-Maxx I haven't had an issue with the heatsink and not using any thermal paste.
  21. #61
    Mar 2016
    Quebec
    183
    If ever, Arctic Silver 5 is the stuff to get. It's not adhesive, but it's an excellent thermal conductor paste.
    http://www.amazon.com/Arctic-Silver-...YS8G2Y0MYAHVSM
    Careful because it can get messy real quick
  22. #62
    Feb 2016
    582
    artic silver 5 will start to harden and then crack after time especially if the heatsink moves around. if you use that I would recommend using zip ties.
  23. #63
    Mar 2016
    Quebec
    183
    Quote Originally Posted by Blkdrgn808 View Post
    Oooh, good point! I never bashed my PCs with a baseball bat and didn't consider how that stuff would hold up under lots of vibrations and impacts.
    Apologies. I didn't mean to hijack this thread. Back to you, gunbar223!
  24. #64
    Lubbock, TX
    321
    If you got a problem solved I am happy.
    As for me I stopped by the HS today and picked up some parts. Post pics in a moment.
  25. #65
    Lubbock, TX
    321
    Picked these up today.
  26. #66
    Lubbock, TX
    321
    And this to make set complete forgot to add in last pic.
  27. #67
    Lubbock, TX
    321
    Visited LHS.
  28. #68
    Jan 2016
    62
    What's the price point you're at now? -.^
  29. #69
    Lubbock, TX
    321
    $626.29
    I have installed servo and steering links. Picked up more parts as well
  30. #70
    Lubbock, TX
    321
    Parts came in the mail today.
  31. #71
    Lubbock, TX
    321
  32. #72
    Lubbock, TX
    321
    Quick note
    If you have ever purchased a bearing set for the tmaxx it will come in handy for the steering assembly. Part#5119 and #5116 are used
  33. #73
    Lubbock, TX
    321
    How it currently sits.
  34. #74
    Feb 2016
    582
    IDK how you can do this? I get tired just from swapping batteries.
  35. #75
    Lubbock, TX
    321
    Does take a little patience. I let my daughter know last night that I was building it for her. She is pretty excited about it.
  36. #76
    Feb 2016
    582
    I tell my wife and kids the same thing but we all know it's for me.
  37. #77
    Lubbock, TX
    321
    When she is not using it yeah I am going to run it. She is passing the emaxx down.
  38. #78
    wow, great job!
  39. #79
    Lubbock, TX
    321
    Thank you freddyJ!
  40. #80
    Mar 2016
    Quebec
    183
    This is amazing! I'd love to do something similar, I have the patience to build it (being an amateur lego collector & builder) but I would not have the patience to wait for parts to come in
    Tip of the hat to you and +1 for being a cool dad
