Results 1 to 23 of 23
    Jan 2016
    61
    Steering servo help.
    Hey guys,
    My steering servo on my mini Revo is clicking won't turn either direction. When I disconnect it from the steering assembly it works. As soon as I connect it back to the steering assembly again it stops turning and starts clicking.
    The plan was to add a second stock steering servo before this happened. But now I'm thinking maybe I should just get 2 of the SAVOX 250mg steering servos. Are these better then stock? And is one SAVOX 250mg better then running 2 stock servos?
    Thanks in advance.
    RC Champion traxxasfan21's Avatar
    Nov 2015
    in sunny CA
    1,113
    The savox servos are a million times better than the stock ones. It would be a lot less hassle to run one savox instead of 2.
    Too much power is just enough
    Jan 2016
    61
    Is it worth it running 2 SAVOX servos? Or would it be too much, overkill?
    Nov 2015
    in sunny CA
    1,113
    One savox is enough
    May 2002
    Midvale Utah
    1,773
    In order to successfully run two you need to fabricate some sort of adjustable link for one of them.
    Dacaur
    Jan 2016
    61
    Thanks traxxasfan21.
    dacaur, would the same type of fabrication be needed to run 2 stock traxxas steering servos as well?
    Nov 2015
    in sunny CA
    1,113
    Yes it would
    May 2002
    Midvale Utah
    1,773
    Reason being, your your servo arm goes on a splined shaft, so has a finite number of positions available. You could get lucky, and end up having the solid link be exactly the right length, bit more likely it won't be, so the servos would constantly fight each other, any time the truck is plugged in. Making one link adjustable allows you to find tune it do that doesn't happen.
    Dacaur
    Jan 2016
    61
    Quote Originally Posted by dacaur View Post
    dacaur, thanks for breaking It down for me great explanation! By any chance do you know the difference in torque between the stock traxxas servo and the savox servo?
    May 2002
    Midvale Utah
    1,773
    No, but its a lot. I would guess about double, judging solely by the seat of my pants....
    Dacaur
    Jan 2016
    61
    Lol, thanks. I actually just looked it up and the Traxxas 2080 40oz. vs 69oz. SAVOX. So about 29oz. of torque difference.
    Jan 2016
    61
    Just found out about BlueBird 390 Steering servo which is 75oz. of torque.
    May 2002
    Midvale Utah
    1,773
    Yea you can save a few bucks on that one but you have to waterproof it on your own, if you care about keeping it wateproof.
    Dacaur
    Jan 2016
    61
    It's actually a couple dollars more then the savox. And wouldn't mind it not being water proof. What I want is a steering servo with enough torque to be equivalent to the torque produced from running 2 stock traxxas servos.
    Jan 2016
    61
    Ended up going with the 1 Savox servo and its good. But I will mention if you tighten up the knuckle set screws if you will, the Savox does have the torque to turn the wheels you have to keep them snug but too much. If the're too loose it will have a ton of play and it will throw your camber off. Might have to add one of the Permatex thread lockers, to try and keep the set screws from getting loose.
    I am curious about what 2 Savox servos would be like though....
    Nov 2015
    in sunny CA
    1,113
    It would be overkill
    Jan 2016
    61
    Quote Originally Posted by traxxasfan21 View Post
    Your mostlikely right, but I might just try it. Since I have to buy another for my basher I'm going to build.
    Jan 2016
    20
    Quote Originally Posted by TonyTorque View Post
    Was it drop-in or had to mod to fit? And what's the model number of your new waterproof servo? (If you recommend it as an upgrade )
    E-Revo VXL 1/16 Brushless TSM & TQi 2.4GHz Radio
    Jan 2016
    61
    Quote Originally Posted by TheEmperor03 View Post
    Direct drop in, just had to reverse the steering. Definitely un upgrade from the stock servo.
    SAVOX SW-0250MG
    Bought mine on ebay for about $28 shipped.
    Feb 2016
    256
    There is probably a tooth broken on a gear in the servo. That is what it was for me. Buy Traxxas metal gears for that servo, or get the Savox.
    Sep 2013
    Draper utah
    73
    I would recommend just getting a Savox servo or bluebird servo. I have the blue bird and it's wonderful. Only problem is that it's not waterproof. Running 2 powerful servos I think would be unnecessary and may lead to damaging the servos because of the fighting going on with the link being not a perfect length. You could also buy a hitec servo, not sure what the model number is. The waterproof one is a bit bigger, so you would need to make it fit somehow. Anyway, I would just go with one servo.
    Jul 2012
    28
    The Savox servos are waterproof now.
    2,334
    Quote Originally Posted by 1FastS197 View Post
    ^^Have heard nothing but good news about the Savox servos.
