Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 190
  1. #121
    Dec 2015
    New Jersey
    389
    I'm trying to help, but you keep asking the same thing, and you refuse to check to see if it's your issue. If it's not, the only other option is your not doing the calibration correctly.
    https://traxxas.com/forums/showthrea...=1#post6147235
    Quote from Traxxas Employee:
    "It's important to note that an issue with the temp sensor on the motor will probably cause what you're seeing with limited forward power. The setup is designed to limit power if the motor gets too hot, or if it's not receiving a temp signal."
  2. #122
    Mar 2016
    18
    I've said I checked and checked many times... made sure temp sensor was plugged in... didn't see any issues there. What if I disconnect it from receiver??
  3. #123
    Mar 2016
    18
    Now that I'm looking at it there is no temp. Sensor on the Castle 2028 motor..
  4. #124
    Jan 2008
    91
    Quote Originally Posted by Aspengt View Post
    Double Back Flip Attempt Fails. And shredded yet another tire! Come on Proline!
    love the videos!
  5. #125
    Mar 2016
    18
    So with throttle reversed on transmitter and direction reversed on motor, I can get full speed/ throttle but esc is blinking red and when I push up to apply brakes, it throws it immediately in reverse...if I pull the trigger all the way down, the led will be solid red.... not sure where to go from here
  6. #126
    West Chester PA
    356
    Quote Originally Posted by XMaxx2015 View Post
    I had nothing but issues with the stock traxxas receiver and controller for both X-maxx trucks. Reversed and extremely show. In the end I just switched to another receiver and all fixed.
  7. #127
    Dec 2015
    New Jersey
    389
    You can use the temp sensor that was on the original motor on the 2028. As long as the temp sensor is plugged in you should be good to go. I have successfully calibrated/used both the Castle Mamba Monster X ESC as well as the Castle XL-X with the stock Traxxas receiver/transmitter. I guarantee I did not have to reverse the throttle channel or change any other settings on the transmitter or ESC to get everything working.
    Honestly I would start from scratch. If you still have the stock motor/esc, I would just try plugging the stock esc back into the receiver and see if you can re-calibrate the stock esc. Test and see after calibration if full throttle gives you a green esc light and full reverse a red light. You don't have to install these items in the truck, just rig them up for testing purposes. If that all works then I would tell me that you are doing something wrong during calibration, or somethings going on with the Castle ESC. Just out of curiosity do you have the trigger set to 50/50 or 70/30?
  8. #128
    Mar 2016
    18
    50/50 is how I have it a set up
  9. #129
    Mar 2016
    18
    So I called Castle and was able to calibrate via steering wheel turning left and right.. we switched the steering snd throttle channels in order to do that... still leaves me being unable to calibrate the esc... any idea let me know
  10. #130
    West Chester PA
    356
    Ok, so to recap and correct me if I'm wrong.
    Stock traxxas receiver
    Temp sensor plugged in correctly
    Can't calibrate esc
    XMAXX is slow in forward still
    Steering still backwards
    Is that everything?
  11. #131
    Mar 2016
    18
    They do not have a temperature sensor hooked up to the castle 2028 motor. Stock receiver, steering works perfectly fine.. only issues that I cannot calibrate the ESC slow forward throttle..flashing green light. It never goes to valid green even when full throttle is reached. When I go to calibrate, there are no tones like it's just looking for the full throttle position the whole time.
  12. #132
    Dec 2015
    New Jersey
    389
    I don't think I'm uderstanding you correctly. You keep saying there is no temp sensor hooked up to the castle motor.
    Do you have the factory temp sensor that was hooked up to the factory motor still plugged into the receiver? It needs to be plugged in. If not it will never give full throttle input to your esc which seems to be your calibration problem as you were able to calibrate it after switching channels.
    This sensor can be taped or zip tied to the 2028 so it will read motor temp.
  13. #133
    Mar 2016
    18
    I had Kershaw do the build and he did not include any original electronics besides receiver transmitter and servo. I have a bone Stock X maxx as well so I'll try and,take it from there and see if that works. I didn't think it was necessary to have it.... I'm hoping thay,solves the problem.
  14. #134
    West Chester PA
    356
    Yes you need to have the stock temp sensor plugged into the receiver. Otherwise you will never be able to calibrate the esc because the receiver goes into a restricted mode without the stock temp sensor plugged in.
  15. #135
    West Chester PA
    356
    X2015- let us know if plugging in the stock temp sensor fixes everything for you.
  16. #136
    Mar 2016
    18
    Yes I was able to calibrate... now just need to test it out tomorrow... will keep you posted !!
  17. #137
    Feb 2016
    35
    How do you stop it from flipping while it's in the air?
  18. #138
    Jan 2015
    holland michigan
    650
    You control the car in the air with the throttle. So if you hit the brakes in the air the car will stop flipping of flip forward
    RC. an addiction I'm proud of
  19. #139
    Mar 2016
    18
    All good guys !! Calibrated the first time once temp sensor was plugged in.. Thanks so much for the help !! Thing is a beast !! Power on demand! !
  20. #140
    West Chester PA
    356
    Like a glove! Haha....... Yes it's in and it fits. Doesn't get any tighter though.
  21. #141
    Dec 2006
    camillus, ny
    2,850
    Oh yes yes yes! More details please!
    Man i need more than 50 characters.
  22. #142
    West Chester PA
    356
    Quote Originally Posted by Apexracing View Post
    Working on a video tutorial on how it was done. It's not a simple modification.
  23. #143
    Dec 2006
    camillus, ny
    2,850
    Complicated is fine with me 1:1 cars is my other passion
  24. #144
    Dec 2015
    New Jersey
    75
    Looking forward to your video, as I have been waiting for someone smarter then me to figure this one out. Thanks for your work.
  25. #145
    West Chester PA
    356
    Video of how I went about upgrading my X-Maxx with a Savox 1/5 scale steering servo. If you are considering upgrading hopefully this video will help.
  26. #146
    Mojave Desert
    3,013
    This will be helpful to a lot. You should have created a new thread for this video/process.
    We are all one race. The human race.
  27. #147
    RC Champion rizz0d's Avatar
    Jan 2002
    1,168
    that's really custom. nice job and thanks for putting that tutorial together for us.
  28. #148
    Feb 2016
    Utah
    16
    Cool Nice Work!
    dude awesome! I have never seen so many after market stuff on an X Maxx (mostly cuz its so extrodanary)
    and when you go on google to look for parts you cant just search 1/5 scale rc truck parts. its so different but in times like this when they dont have any parts on traxxas.com for the thing it make this truck so hard to replace broken parts
    but keep building and modifying this until its even more bad to the bone and beast and adding to the thread and I can't wait to see how this turns out!
    P.S. Its me Wyatt Thayne.
  29. #149
    Dec 2015
    New Jersey
    75
    The video has disappeared ?!?!??!
  30. #150
    West Chester PA
    356
    Quote Originally Posted by Marley510 View Post
    Yes, I removed the video. After the 2nd test run the 2 part epoxy was pulling away from the stock plastic. I didnt want people to follow a video that could potentially fail. I am working on a completely different mounting system. This time I'm building a bracket out of aluminum. Will post updates and possibly Video of the much improved conversion.
  31. #151
    West Chester PA
    356
    New and much improved X-Maxx 1/5 scale servo mount! Still needs wet sanded and polished!
  32. #152
    Jan 2016
    32
    That looks awesome. What is the thickness of the aluminum you used? Do you have a lathe?
  33. #153
    Dec 2006
    camillus, ny
    2,850
    Wow that looks nice! Any mods required to the chassis?
  34. #154
    5,644
    Wow, that's factory looking! Nice job!
    Manager at LHS ~7 Years. I've seen some stuff lol
  35. #155
    Jun 2013
    MN
    161
    That looks very nice
  36. #156
    Dec 2015
    134
    do you have a video for this one?
  37. #157
    West Chester PA
    356
    Quote Originally Posted by chrismm6773 View Post
    Thank you guys!
    Chris-I do have a bunch of video clips and pictures that I have to put together but yes I hope to have a video up soon.
  38. #158
    Jan 2002
    1,168
    wow. i thought the first iteration was nice, this one is over the top. great work.
  39. #159
    Dec 2006
    camillus, ny
    2,850
    Yea tighten up some of those tolerances and that will be a real nice piece. I bet that top plate could be cut from graphite. Then you would just need the stop for the rear.
  40. #160
    Eastern Shore, Maryland
    4,129
    The aluminum looks, and looks like it works a lot better.
