So I have like no budget.... but I want a reliable soldering iron. I would prefer about 80 watts.....
I have an iron now, but the tip is all gross and black, it wont tin.... it is jsut nasty, and solder wont stick to it, needless to say, it is very difficult to solder with it
And I know you get what you pay for.... I just don't want to spend a ton, and I want relative quality..... the cheaper, the better
I personally love this one with the replaceable tip:
http://www.weller-toolsus.com/solder...550.html?buy=1
There is also this one, I use this for on the go or away from home jobs:
http://www.weller-toolsus.com/solder...***.html?buy=1
If you like to have the gun always on go with the second one. The first you have to hold the trigger to heat it up.
Have Fun and Drive Recklessly
You can go cheap on a lot of things in this hobby, but two things going cheap on that will lead to nothing but frustration are hex wrenches and soldering irons.
Most certainly get a Weller, they are great quality, and the heating coil is replaceable (and easy to find). Recommend getting a pencil-style iron, those pistol style can get a little unwieldy for doing the smaller stuff. You can get an 80w Weller for less that $40, and you can get a 80w station for around $65.
The trak power tk-950 works great.
That one's about $70 at Tower Hobbies right now.
I bought a Chinese 852D+ solder rework station for less than that on eBay. It has a temp controlled solder iron and temp and flow rate controlled hot air wand. Works great and has enough tips to do anything from computer repair to hobby stuff. Hot air wand is great for heat shrink and also works for desoldering.
What broke, uh, needs upgrading now?
Weller 80 watt iron with either the 1/4" tip or the 3/8" tip. I have used this iron professionally for years and have soldered thousands of RC packs with it. Cannot be beat for only $35 or so.
Jakey, what type of solder is best for RC? High silver content or standard lead?
Let get get this question right.
Good
Cheap
80 Watt Soldering Iron??
What do you consider cheap?
If your dealing with todays R/C's and have electric R/C's... Weller Wes51 Average cost $90.00
Taken care of it will be the only soldering Iron you ever buy.![]()
All Lives Matter
Weller SPG 80L
Good and cheap at $35. Again, I have professionally soldered and assembled thousands of Nimh packs using this iron and followed up with soldering on thousands of Traxxas and Deans connectors to LiPo packs using the same iron.
It's cheap, it's good and it works!
For most of my work I use Radio Shack 60-40 solder. If working on a special project, I pull out the "good" stuff; 63/33 tin/lead solder. It makes for a shiny and strong joint.
Someday I'm going to have to drop a WES51 off at Jakey's house, just to see the raising of his eyebrows.
Then again, he can probably solder with a hair dryer as well as I can with a soldering station...or even Weller. (See what I did there?)
Alt-248 on the number pad = °
Nothing wrong with either. I suspect the tips available with the 80W are larger than those available for the WES51.
The 80-watt Weller iron is available with a 1/4" chisel tip. Nearly perfect for all but the smallest wires and items.
Get best and cheap soldering station iron from http://www.bestoninternet.com/comput...n-electronics/
My vote goes for the trak power 950 as well, we use that at the hobby shop I work at and it sure is nice
RACE IT, BREAK IT, FIX IT, REPEAT!
soooo.... time to revisit this
looking into the trakpower 950 right now or the hakko 888
weller was also in the searching
a we51 or 80?
I've had very good luck with my Weller wlc 100. From tiny wires to big coax cables it does the trick.
I really like my Trak Power 950, I do quite a bit of soldering at home, make my own light systems, wire up battery and ESC connectors (Deans mostly), and it works great.
Tower has these for $60 right now. I do recommend picking up the 3.2mm tips, I prefer those to the 2.4mm it comes with.
https://www.towerhobbies.com/cgi-bin...&I=LXATBK&P=ML
For the widest selection and availability of tips, adjustability of temperature, impeccability of reputation, and value of product, I don’t think you can beat the Weller WES51. It is what I chose.
went and looked at it today, it's only 50 watts
also saw my local Fry's had the Hakko FX888D, for $10 cheaper than the Weller 51.... they did have tons of tips in stock and on hand for that one as well....
The Hakko seems like a good unit as well, seems pretty highly regarded on these forums ~$100
Well, I got impatient.....
Ordered a Hakko FX888D off Amazon. It will be here today.
Got it :-)
I will be soldering some xt90 connectors and 10 gauge superworm wire from acer racing soon![]()
so.... I want to pick up some solder now..... not sure what is the best to get. I don't want some cheapo, made in China of questionable stuff. I want lead in it.. I have heard Kester may be what I want, but when I try to look them up, come up with tons of part numbers, for what appears to be the same product. the 63/37 is what I have read about as being the best. with a 2-3% rosin core.
Also, my instruction manual says htere are 2 little sponges that go in the slits that re cut out, I didn't get those? I have already contacted the seller, and asked a question on Amazon. I tried looking for those seperatley, and cant find a picture of them anywehre.
I am also going to pick up a pack of 5 different tips for it, and also some tip cleaner paste in a tub.
I tend to destroy tips, because I am horrible at doing the proper maintenance
Here are the little sponges I am missing![]()
Nice looking Iron! Looks to like they just forgot to cut the holes out on your sponge. All I do with my sponge is just dampen it and wipe off the iron after each solder.
Just checked out different solders. Seems 60 tin / 40 lead is the way to go. Its even safer than lead free as far as breathing the fumes. Of course we all try and prevent that don't we.
With the 60/40 you have more flex in your joints from movement. With the lead free it is a bit more hard which makes it a bit brittle and could snap the joint. Unlikely but there is that possibility.![]()
Choose Life !!!
the holes were cut out of my sponge, but the little pieces weren't there... anyways, the seller on amazon went and checked, and said they are supposed to be in the bag (my bag was sealed) so they just weren't in there. He shipped some off for me.was looking @.
63/37 is what I want. and not lead-free, because lead-free sucks
looking @ the Kester brand, but not sure which to get, seems they have a lot of 63/37 with tons of different part numbers, for what appears to be the same product?
Well, here is what I just ordered....![]()
[QUOTE=jimbo74;6424109]Well, here is what I just ordered....
I noticed that yesterday myself. Kester must be a big supplier of soldering products. Not cheap either. I ordered some myself. 60/40 rosin core.
They made the pic look as if they just cut the smaller pieces out of the larger sponge. I guess they sit in water to keep the larger sponge damp longer?happy soldering!
Choose Life !!!
I typically use 60/40 for ease of soldering. I’ve never used a eutectic solder so am interested in what you think about it.
IMO, getting the solder joint right is much more important than the solder material used, but a superior solder combined with skilled application is obviously the best case.
it does look like those pieces are just cut out of the larger sponge, but I never saw them in my package, and the sponge was in a sealed pack..... the Amazon seller is sending me one....
from a bunch of looking on the net about RC soldering, Kester appears to be top notch stuff, not the no name, ebay stuff made of questionable alloys -- and I got th 63/37 which is supposed to be even that much better than the regular 60/40
$8 for a 60-watt iron is the best cheap one you will find: https://www.towerhobbies.com/cgi-bin...&I=LXPR36&P=ML
If you want to spend more the TrakPower TK-950 will do most everything you need to do in RC: https://www.towerhobbies.com/cgi-bin...&I=LXATBK&P=ML
already way past that dude
Speaking of the Ripper
, My soldering iron just arrived this morning. I guess I can take the one I have been using back to work...lol Kester solder is on the way. I am thinking the 63/37 may have a bit more rosin in it.
Dang Ripper 80 dollars at High Rise. I got it for 65 shipped.......Straight from the jungle!!!!!!!!!
Choose Life !!!
I am still working on my skills, but getting much better with every solder I make. I will Probably go solder crazy as soon as my solder gets here.... Practice makes perfect.
Choose Life !!!
I didn’t see any flux in your list. I like to use the liquid type applied via a needle tip applicator bottle.
not using any, the solder is rosin core, and better than regular 60/40
also, I will be using tinner on the tips, and they are also pre-tinned... the tinner is lead free, but is also flux as to what I have heard....
going to use the smaller chisel tip in the 5 pack I got...
about to start the soldering.....
so, those half moon sponge pieces were there, they are not the slits, but inside the slits, still attached, but pre-cut.
the rx8 does not liek 10 gauge wires....
the hakko did great. really pleased with it, used the medium chisel tip that came in my extra set of 5 tips I bought. used the tinner, used the sponge, and also the brass mesh stuff too.... made sure not to leave it on too long, the tip still looks awesome, and it is tinned, for storage.... Really like it. using good tools is sooooo nice.... Finally, I am to the point in my older age, that I still want budget, but wont skimp on quality... I go to Harbor Freight a lot, and get stuff, but certain things, I will only go brand name
My joints are kind of ugly looking but they're shiny. 10 gauge is hard to work with
