Page 6 of 6 FirstFirst ... 456
Results 201 to 233 of 233
  1. #201
    RC Champion thesmogman's Avatar
    Oct 2013
    Dublin, CA
    1,249
    Well after putting three packs thru the truck I have to say that I like the new bellcranks. For some reason I had to turn down the steering as I had too much turning capabilities. Right front was clicking at full turn.
    I am wondering if STRC did change something in the geometry ????
    And no breakages..... He he.
    Slash 4x4 Tekin RX8GenII w/Pro4 4300hd
  2. #202
    Jan 2017
    50
    Looks good. How close do the bell cranks blue match to the traxxas blue?
  3. #203
    Oct 2013
    Dublin, CA
    1,249
    They are a little bit lighter blue than the Traxxas parts, but it matches my STRC motor mount just fine.
  4. #204
    Oct 2013
    Dublin, CA
    1,249
    Well, not really an update... just showing what a little soap and water and a scotch pad can do.
    I got it pretty dirty and scratched so I thought I would try to clean it up a bit.
  5. #205
    Feb 2002
    9,352
    Looks brand new
  6. #206
    Jun 2014
    Southern California
    7,528
    Cleaned up nice!
  7. #207
    RC Qualifier MaxxBash's Avatar
    Nov 2016
    632
    Nice I should do this too. Lookin good!
  8. #208
    Oct 2013
    Dublin, CA
    1,249
    Well an report of a problem. I posted a while back about the rear hub carriers that I bought with the c-clip style hinge pin's.
    I took a small tumble the other day while running at my apt's and did this to one of them.
    While trying to remove it I totally messed up the carrier. So to you all, keep using the screw type hinge pins or get a better set of hinge pin's. Now I have to order another set. Boooooo.
  9. #209
    RC Champion shack351's Avatar
    Dec 2016
    Kville
    1,127
    Quote Originally Posted by thesmogman View Post
    Hey Smog,
    Wow, that's a pretty good bend there! I replaced all mine with Lunsford Titanium and so far, so good. They fit nice and tight and got rid of some play as well. Not too bad for about $20.
    Lunsford Racing Titanium Hinge Pin Kit Slash 4x4 - Part# LNS3727
    -Shack
  10. #210
    Oct 2013
    Dublin, CA
    1,249
    Well over the weekend I changed out the front hub carriers and properly shimmed them. The only part that was still original on my truck. They has almost no slop. Very happy
    I also experimented with the center diff w/100k, drove about half a pack and I didn't like it so I rebuilt the revo slipper with some new stock pads. Drove the last half a pack and I thought I need to try something else. So I changed the rear diff to 7K from 10K and went with the silver sway bars. Nope that was not it so I went to 15K in the diff and back to the black swaybars.
    Then the front started to push a bit so I lowered the front ride height a touch and moved the swaybar links longer(more sway)... and there it is.
    So to add this all up at this time I am at..
    Front - 20K diff, Blue Traxxas springs and 42.5wt in the shocks with 3mm. on the black swaybar.
    Rear - 15K diff, Pink Traxxas springs and 35wt in the shocks with 0mm. on the black swaybar.
    I find it weird that I had to change so much to get it handling like I like it.
  11. #211
    Oct 2013
    Dublin, CA
    1,249
    I had to do it... I got the Traxxas S1 compound tires. I have to say I like them!!
    I geared up a little to 19/52 and with full sized tires it was flying. But it didn't like the speedbumps, first wheelie and snapped an axle. The S1 compound does have more traction than the normal tires.
  12. #212
    Feb 2002
    9,352
    snapped an axle you say.......
  13. #213
    Oct 2013
    Dublin, CA
    1,249
    Yeah I did, I tightened the slipper with the old tires. Then I thought I would try the new ones out and forgot to loosen the slipper. I didn't expect to have that much more traction. Could also be the new SMC pack too.
  14. #214
    Jun 2014
    Southern California
    7,528
    I know you don't want MIP X-Duty axles... what about Tekno M6s?
  15. #215
    Oct 2013
    Dublin, CA
    1,249
    A little update.... Since last time I have changed quite a bit on the truck.
    Front 42.5wt oil with the 1.5 pistons and blue Traxxas springs. 10K in the diff. 1.5 degree camber. Sway bar at 7mm.
    Rear 35wt oil with the 1.6 pistons and pink Traxxas springs. 5K in the diff. 1 degree camber. Swaybar at 1mm.
    Center diff, I have been up and down with wt's and found that 30K work's pretty good.
    I have been running on my parking lot with speed bumps and a very fun drop-off that induces great wheelies coming back up it. I am still running the normal compound Traxxas tires.
    My gearing is at 18/54 on 2s right now, I am liking it with the warmer weather we have been having.
  16. #216
    Oct 2013
    Dublin, CA
    1,249
    A new pic of my truck. Got a bigger sticker from the Traxxas girls at the NHRA race at Sonoma. http://s67.photobucket.com/profile.php?do=editpassword/thes...rkpz2.jpg.html
  17. #217
    Sep 2016
    Canada
    143
    ALL of your pics in this thread are not visible anymore. They have been taken by ransom by Photobucket! Pay Pay Pay!
    READ: https://forums.traxxas.com/showthrea...ics-in-a-Forum
  18. #218
    Jun 2014
    Southern California
    7,528
    Let me help:
  19. #219
    Oct 2013
    Dublin, CA
    1,249
    I noticed Photobucket was different. Thanks. I'm bummed.
    They are holding my photos for ransom. Boo!!!!
  20. #220
    Feb 2002
    9,352
    Yeah, they screwed over all the online forums
  21. #221
    Sep 2015
    2,161
    Are you guys seeing this? Because I use photobucket and don't pay, and I'm seeing my pictures.
    youtube.com/c/RazorRCvideos
  22. #222
    RC Qualifier spunkybob's Avatar
    May 2016
    600
    Quote Originally Posted by RazorRC22 View Post
    Hey man, I can see this one, but not some of your original ones.
    Sent from my SM-G935F using Tapatalk
  23. #223
    Feb 2002
    9,352
    So.............
  24. #224
    Aug 2017
    215
    Get the Tapatalk App. You can post, upload photos as you post, and check all your favorite threads from 1 app.
  25. #225
    Feb 2002
    9,352
    Quote Originally Posted by Aqualungs View Post
    I use tapatalk almost exclusively now to put pictures online.... if no picture, I just use the desktop.....
    I belong to several forums
  26. #226
    Aug 2017
    215
    Tapatalk is great
  27. #227
    Oct 2013
    Dublin, CA
    1,249
    Going to do ttak. That doesn't fix all the images. No way to do that. On another note my last post with my settings is still working great. I hope others will try to experiment with the settings I have posted. Of course with out the pics.
  28. #228
    Feb 2002
    9,352
    did you run today?
  29. #229
    Oct 2013
    Dublin, CA
    1,249
    did you run today?
    Hey Jimbo, why yes I did. I threw the Revo slipper back in and swapped the 54t to the 52t and a 18t pinion.
    Drove great. I had to adjust the slipper a little, but that was all. How about you, did you dust off your truck?
  30. #230
    Oct 2013
    Dublin, CA
    1,249
    Wow, just ran the truck. I took razors and yellow's advise. Dropped all 4 shock oils by 5wt. So that has the truck at 35wt. Front w/1.5 pistons and 27.5wt. w/1.6pistons in the rear shocks. I have 10k front diff and 5k rear.
    Had a lot of traction and snapped a axle with a tighter slipper than I like. I thought about why, should I adjust the slipper. Adjusted it and traction rolled a couple of times.
    So after changing ride height and swapping to the center diff @30k. plus putting on my Traxxas S1's the truck drove great. I was surprised at the traction and handling.
    Sometimes looking at a different set-up help's a lot. I really enjoyed how the truck handled.
    Thanks!!!!
  31. #231
    Oct 2013
    Dublin, CA
    1,249
    Just ran a whole pack with the new setup. Everything is working great. I had older people watching it. They were amazed and so was I. Wheelies all over and it's jumping great over the speed bumps. I kinda abused it and it took it. Got alot of compliments. WOW!!!!.
  32. #232
    Feb 2002
    9,352
    I always get little kids asking if they can play with it, then they start getting annoying and keep asking after I say no.....
  33. #233
    Feb 2002
    9,352
    Any updates? It's been awhile
