Page 1 of 3 123 LastLast
Results 1 to 40 of 83
    Feb 2016
    582
    Smile X-Maxx On Board Audio - It's Alive!
    I got the Traxxas OBA to work on my X-Maxx. I'm still using the 2ch transmitter as I probably wouldn't use the launch mode. I'm using a LIPO battery balance plug to power the unit while the unit is secured with double stick tape and a zip tie.
    There are two sound units but one is wider than the other and the smaller one does not lay flat.
    For the longer piece I installed it in the back window. I had to trim the flaps so that the unit could fit closer to the body but without touching it. I was also able to use the stock screw holes on the unit. I also had to cut the flap that the wire is wrapped around.
    For the shorter piece I made two spacers since the audio unit does not lay flat. One side is higher than the other. These spacers fit on the X-Maxx crossbar.
    Just remember that these units vibrate the body so you have to leave space in between the body and audio unit.
    As for the screws I just used whatever I could find and later I will put washers when I get some.
    Feb 2016
    582
    Oklahoma City, OK
    2,704
    Dude....that is AWESOME!!!
    "RED"
    RC Champion jeteffect's Avatar
    Apr 2015
    1,760
    Man, great job!!
    Eastern Shore, Maryland
    4,247
    Those OBA's are fun aren't they. I put one in my XO-1 last year, and I've had a ball with it. Anyway, if you want you can dump the extra battery, and tap power off of your ESC's BLACK and RED wire. Your OBA module will accept 22.1vdc.
    Better to die a man, than live like a mommy part.
    May 2005
    79
    I like it!!
    Feb 2016
    582
    I had an extra battery laying around. I'd rather use that to power my 5 sets of lights (I installed more since this video) and 2 30mm fans instead of draining my main battery.
    4,247
    Just for the sake of discussion, you don't need to do that. Your 30mm fans, LED's, and OBA don't pull any kind of current that you would ever notice a reduction in running time, or would have any kind of stress on your BEC. You would be better off with the weight reduction of one less battery, for sure. What you have now is like a person who normally uses standard commercial power for their home, but now wants to build a full sized electrical power plant just cause they want to add electricity to their garage. You can do it, but it's a lot of unnecessary overkill...just saying.
    Feb 2016
    582
    Oh cool. I figured I have a spare battery so why not use it. I'll change it around once my new motor/ESC arrives.
    Mar 2016
    28
    hello
    where did you get the oba unit,,not the speaker units,just the electronic module,
    I tried to bye it from Traxxas but they don't sell it.I HAVE TO BYE A TRUCK THAT HAS ALREADY GOT IT INSTALLED.
    and I just got a new XMAXX 3 weeks ago.
    thank you
    For those out there that want to cool down the motor on your XMAXX,use a fan from a CPU and clip it on with tie wraps,
    it works fine.
    14
    You can buy each piece individually on eBay. Just type in Traxxas oba on the search.
    Mar 2016
    28
    thanks for the info Killswitch.
    Feb 2016
    195
    Silly question, but does anyone know if the OBA module is waterproof? Just purchased two for my Traxxas kits and my kits do get played with when it's wet out.
    Feb 2016
    582
    I read that it is. I hope so because I already shot it down with water.
    http://www.rccaraction.com/blog/2014...n-board-audio/
    Feb 2016
    195
    Quote Originally Posted by Blkdrgn808 View Post
    Thanks, that's good to know. I guess I'll just throw it in the truck and see how it goes.
    4,247
    I'd think it would be, being that the Slash is water resistant.
    Feb 2016
    582
    I redid the installation of the OBA module and turned it sideways and it fit perfect. It actually slides down over two nipples and the screws line up 100% like it was meant for it. Power for the module is now run from the receiver.
    4,247
    There you go.
    Mar 2016
    28
    hey,
    better put a heat sink on it,
    I hear they heat up.
    have a nice day.
    Feb 2016
    582
    Quote Originally Posted by momole70 View Post
    hey,
    have a nice day.
    Heatsink on what? The module or the speaker parts?
    4,247
    You don't need a heat sink on any of your OBA components. They will run fine as is.
    Feb 2016
    195
    I installed one of these modules in my XMaxx to no avail. I guess it doesn't work with aftermarket radios :-( What happens when I power up the XMaxx is that the sound goes to full throttle while the radio is in the neutral position. Only way to get the module to go into idle mode is when the breaks are applied. I've tried everything and aside from slapping the stock radio in, I see no solution. There appears to be two program ports on the module when the case is removed but that stuff is beyond my abilities.
    4,247
    I couldn't tell you on that. I like, and use Traxxas radios on all my stuff...even my non Traxxas stuff. Their radios are reasonably priced, work well, and they have the nicest telemetry setup. I would like to see Traxxas developed their own telemetry display, though. That way, they could tell Apple to go take a hike. Not that I dislike my Apple products, but I would like to see Traxxas not have to depend on anyone but themselves for RCing goodness.
    Feb 2016
    582
    Just an update. I tried running two pairs of speakers to get it louder. It seems that the module cannot handle it. It will play it fine standing still but once you start moving and about 10 seconds later it will die. I bet if running it 12v from the battery it will be fine. Anyways I also noticed that the speaker mounted on the roof is not as loud as the windows. Adjusting the spacing did not matter as I think it will not vibrate that area enough. The back and front window are best. I bet the rear bed behind the latch would be a good place too.
    You have to shave down the body support for the front window for the speakers to touch the body.
    Much louder
    4,247
    What I did to get the sound and volume I wanted was make polycarb tuning disks (it's kind of like doubling the bodies thickness), and silicone-ed them to my body.
    You can just barely see them in this picture sticking out under my speakers.
    Mar 2016
    28
    Hi there sir,I hope you can help me.After ordering a OBA 28 days later I got it this morning.I tried installing it but I'm kinda lost, I'm familiar with electronics,but there is no diagram whatsoever with the unit.I connected blue plug to speaker,and b+ to a battery now i'm left with a green plug,a grey one and a bigger one that's black which seems to be built to receive onother one.Now on my receiver I got RPM space free,ch4,ch3,and a second ch1.if you can tell me where those plugs go in,I would very much appreciate.Im sending photo of the plugs,thank you so very much.
    momole70
    Feb 2016
    582
    Mar 2016
    28
    hello,,how do I transfer pictures on this site?
    momole70
    thank you
    RC Champion traxxasfan21's Avatar
    Nov 2015
    in sunny CA
    1,113
    Tapatalk (app) works great for pictures.
    Too much power is just enough
    Mar 2016
    28
    thank you so very much,,,,
    this will surely help,
    what a great site this is.
    momole70
    Mar 2016
    28
    info on oba
    hello,
    How do I*upload pix and videos?
    I got some valuable info to show you fellas concerning sound volume on oba units,and SPEAKER SYSTEM.
    thank you
    momole70
    Mar 2016
    28
    hi,your wiring setup is bad,I had same problem,
    grey plug to ch 2,green plug to ch3,big black plug must be connected to esc module,big black female.got it?
    but by now you surely got the thing working.
    momole70
  33. #33
    Mar 2016
    28
    hello again;
    how do I get my pix's and videos on this site?
    I've got some info concerning XMAXX oba, and volume range and voltage supply to oba.
    thank you,
    momole70
  34. #34
    4,247
    I use Photobucket. If you go that route, let me know.
  35. #35
    Mar 2016
    28
    OK ReglarGuy,now that I joined photobucket and uploaded a couple of pixs,how do I get them over hear?
    thanks
    momole70
  36. #36
    Feb 2016
    582
    If you mouse over the top left of the pictures in Photobucket it will bring up a Share link. Click on it. Then Copy the link under IMG. Paste that link when you reply to the thread. You need to do that for every picture.
  37. #37
    Mar 2016
    28
    ok,,thanks i'll try
    momole70
  38. #38
    Mar 2016
    28
    hi ,why is it so hard to upload pictures on these threads?
    I tried with photobucket,but it's too complicated for me, i'm 78 so i'm limited when it comes to handling computers.
    Building rc vehicules,that i can handle.
    thanks for reading me,
    momole70
  39. #39
    Mar 2016
    1,155
    momole70
    Used tapatalk app it's way easier than photobucket..
  40. #40
    Mar 2016
    28
    hey,,
    i'll try right now
    thanks
    momole70
