Page 12 of 16 FirstFirst ... 21011121314 ... LastLast
Results 441 to 480 of 605
  1. #441
    Apr 2015
    773
    Quote Originally Posted by MaxxBash View Post
    I agree with you as far as the gluing of your tires.....I completely messed up my new badlands mx2.8.....so wobbly it's embarrassing.
    It's fun sometimes to go back to stock size and have to readjust your skills.
    This is why I switched to beadlock Wheels. I suck at gluing tires. I got tired of having at least one or two wobbly Wheels out of four
    Sent from my VS985 4G using Tapatalk
  2. #442
    Sep 2015
    2,197
    Quote Originally Posted by MaXDee View Post
    I admit I was thinking about this thread as I was gluing up my Rustler wheels/tires this afternoon! I'm not the best tire-gluer in the world, but it gets easier the more you do. The secret is AKA tire glue with 3/4" of the little tubing as a nozzle.
    youtube.com/c/RazorRCvideos
  3. #443
    Apr 2015
    773
    Quote Originally Posted by RazorRC22 View Post
    I never did it enough to get good at it. I would end up whipping one of the wheels across the room when I didn't glue correctly and the glue set. Ironically I do use AKA glue.
    A ProLine beadlock wheel/tire with strc aluminum rings is only 1 oz heavier then a glued Wheel and Tire. I can change a tire out in about 3 minutes with a electric screwdriver and no wobbly tires
  4. #444
    Feb 2002
    9,355
    I have done several sets, I still suck... just not for me
  5. #445
    Apr 2015
    773
    I got these little brass inserts from McMaster-Carr. I put a drop of CA glue on either side and push them in with the back end of a flat screwdriver so they're flush with wheel. I've never had one pull out on me and they never strip.
  6. #446
    Apr 2015
    773
    I have another set in silver. I use the silver set to race with at the track with my TLR 22SCT 2.0 and my Slash. Black to bash with.
  7. #447
    Sep 2015
    2,197
    Whatever works for you, but 1 oz. is actually a lot of weight. Especially x 4 on rotating mass. I'm guessing it's actually quite a bit less than that per wheel, because that seems way more than I would expect.
  8. #448
    Apr 2015
    773
    Jimbo74's Sl4sh LCG Build
    You're probably right on it being quite a bit less than 1 ounce. The aluminum rings weigh next to nothing. If you hold the bead lock wheel and tire in one hand and a glued tire in the other, it's hard to tell which is heavier. You can barely tell that the beadlock is a hair heavier then it's glued counterpart.
    I went with bead locks because I got tired of having at least one wobbly tire out of four. It just makes the truck drive like poo.
  9. #449
    Apr 2015
    773
    Me too.
  10. #450
    Feb 2002
    9,355
    just heard proline has finally released some 2.8" premounts on f11 wheels for the 17mm crowd!!!!! finally!!!!!!
  11. #451
    Jun 2014
    Southern California
    7,563
    Saw that yesterday on their website:
    https://www.prolineracing.com/1-10-mt-tires-premounted
    First 4 offerings in the list.
  12. #452
    Feb 2002
    9,355
    great.... now i have to spend more $
  13. #453
    Apr 2015
    773
    I hope they add 2.8 Mashers to the 17mm list.
  14. #454
    Feb 2002
    9,355
    had a chance to play hard today
    the motor was warm, probably more than it should be, but nowhere near causing damage I think
    temp gauge on the esc showed the esc was ambient, so the lowest level the gauge shows
    got in a couple traction rolls!
    did manage to brain fart and launch it into reverse into my ankle... that was awesome, especially since I was wearing crocs
    still looking to upgrade to a 40mm motor and a 3s or 4s battery..... BUT... if I want to stay 2s, I should stay around 2500-3000kv...
    I swear, I am just probably jsut going to have to breakdown and get a 1515 Castle or a 1/8th Tekin if I want sensored.
    on a serpeate note (and because I am lazy, but also want it to be documented here, in my thread) what would I need to start adding telemetry to my stuff? I have the link app/bluetooth, rx with tons of ports on it
  15. #455
    RC Champion shack351's Avatar
    Dec 2016
    Kville
    1,127
    Hey Jimbo,
    Was that with the 4KKv "smog" motor?
    Yeah, I've had some reverse issues myself! Luckily nobody hurt.
    I know you wanted a 40mil can but there is A LOT of other really good stuff outside the 40mm realm. What about something like a TP4250-Sensored, in the 2D-4D range? There's no doubt about what they're capable of. I am very anxious to try out my TP4670. No sensors but that's ok... I just want raw, high-rpm 8S power anyway!
    -Shack
  16. #456
    Feb 2002
    9,355
    36 is lackluster at this point, and I don't want a 42.
  17. #457
    Dec 2016
    Kville
    1,127
    Apparently I need some schooling here. What is it about the 40 that makes you not want anything else but that? Just curious!
    -Shack
  18. #458
    Feb 2002
    9,355
    I don't want to hack up the chassis or run some ridiculous motor mount
  19. #459
    Dec 2016
    Kville
    1,127
    Hey Jimbo,
    Why would you need to do that? The "40mm" CC 1515 is actually closer to a 42mm (41.4 to be exact) diameter can and I did not cut or modify anything for it to fit. Many of the so-called 40 & 42mm cans that I've looked at are just like the CC 1515 and come in with an actual size that's a bit less than 42mm (finned or not-finned). The TPP 4030 line-up is 40*63 and should drop right in the Slash. Not saying you want that motor but it seems there are at least a few quality options other than CC to be had that don't require the things you mentioned above. You definitely shouldn't have to settle for anything less than what you want. Hope you find it!
    -Shack
  20. #460
    Feb 2002
    9,355
    Also not trying to spend $200 on a battery and a motor
  21. #461
    Feb 2002
    9,355
    there are BIG things in the works right now.......
  22. #462
    Apr 2016
    Midwest
    1,006
    Care to share details?
    "Gone racing"
  23. #463
    Feb 2002
    9,355
    Quote Originally Posted by SlashMaxx4x4 View Post
    not yet....
  24. #464
    Feb 2002
    9,355
    shack351 here is what I ended up getting today.... and your PM inbox is full (or you blocked me )
  25. #465
    Feb 2002
    9,355
    and just a teaser....... the upgrades are going to be YUGE!!!!!!!!
  26. #466
    Dec 2016
    Kville
    1,127
    Once I saw that you painted your Sl4sh pink with purple polka dots... I had to draw the line! No, it was full... sorry about that. I have the same scissors and they work great. Nice choice. I also see that you've invested in some quality soldering stuff. Your Hakko soldering station, with the above mentioned chisel pack and such, should allow you to do some nice soldering! It should be said that having quality soldering hardware, like yours, is a pricey investment but if you're serious about your connections, the cost is justifiable.
    A guy (kid) at our local track, where I normally just like to observe, kept having weird issues with his Slash... on 2S! When the time was right, I asked him if I could look at it and almost instantly I could see that his connections looked like they were done by a circus monkey. I'm not berating him, at all, (I have been a circus monkey many a time!) he just didn't understand the consequences of a sloppy soldering job. So I asked him if I could pull and tug on some wires and, after he agreed, I pulled with maybe 5-10lbs of force and the negative wire pulled right off the Traxxas-style connector he was using on his battery. Another tug and the positive followed suit. Normally the connector blade should just slide out but not here. He told me that he had an old Radio Shack iron that his grandfather let him have. I told him to go pick up at least a cheap Hobbico 60W version... less than $10. Well, I saw him again a few weeks later and, as I hoped, his rig was running well. He had got the new iron and done a much better job his second time around.
    Sorry to ramble Jimbo! Nice purchase and can't wait to see your "surprise" rig!
    -Shack
  27. #467
    Feb 2002
    9,355
    haha, you and thesmogman already know what my YUGE! things coming are, lol --- but both of you have been sworn to secrecy, for now
  28. #468
    Sep 2015
    2,197
    Nice solder stuff, the 63/37 does actually make a difference over 60/40, good choice.
  29. #469
    Feb 2002
    9,355
    Teaser pic.......
    it's going to be YUUGGGEEE!!!!
  30. #470
    Feb 2002
    9,355
    Alright.... here is the YUGE!!! reveal:
  31. #471
    Feb 2002
    9,355
    42mm x 69mm 1900 kv, SMC, sensored motor
    4s, 131 amp /90c, 6700 mah, SMC True Spec battery
    elastic velcro strap form the hardware store, made to work for now
    Genuine Amass XT90 connectors
    15/52 gearing (currently, may change)
    10 gauge Acer Racing "Superworm" wires
    Gorilla double-sided mounting tape indoor/outdoor
    That esc plate was made for me by thesmogman when I got my RX8. I added a hole and was able to secure it to the chassis using 2 pre-existing threaded holes
    Trimmed 2 threaded holes off chassis under motor, I felt like they were going to rub, so I shaved them down. I may have issues with the driveshaft rubbing the motor can. A smaller pinion may not be possible. Could do a larger spur if needed.
    I do have the slipper locked down, it is the regular slash slipper, but has aluminum pads.
    Past mods:
    Tekin RX8 Gen2, ver. 258
    HPI Vorza D8 shocks
    F/R MIP X-Duty
    XO-1 Diffs
    Power HD 1217 metal gear, high speed/high torque servo run @ 7.4v
    Tqi radio system with TSM and app on Android
    EDIT: Just a note, the RX8 Gen 2 does not like 10 gauge wires, I had to squash them into a slot to slide into the posts
  32. #472
    Feb 2002
    9,355
    Weight
  33. #473
    Feb 2002
    9,355
    Charging this bad boy up
    Charger is 80watts/10amps, it it fed by a power supply that is 12vdc, 75 amp/900 watts
  34. #474
    Feb 2002
    9,355
    dangit, forgot to mention the motor is an 1/8th scale, 4-pole, with a 5mm shaft
  35. #475
    RC Qualifier MaxxBash's Avatar
    Nov 2016
    635
    Looks slick! What's the plan for it? Speedster? Or super racer?
  36. #476
    Feb 2002
    9,355
    Nothing. Just driving the way I drive.... without worry of frying stuff for inadequate equipment
  37. #477
    Nov 2016
    635
    Very nice! My next plan is definitely going censored.
  38. #478
    Jun 2014
    Southern California
    7,563
    Very nice Jimbo. Looks like fun!
    Hahaha! Keeping it covered like Jimbo?
  39. #479
    May 2017
    332
    Out of curiosity why 1900kv motor?
    Uh and with my 2400kv I gear it at 20/50
    Sent from my SM-G900V using Tapatalk
  40. #480
    Nov 2016
    635
    Where is the cable? I tried to find it earlier but now luck lol
