Page 5 of 16 FirstFirst ... 3456715 ... LastLast
Results 161 to 200 of 621
  1. #161
    Feb 2002
    9,398
    I use a Craftsman ratchet wrench with a 17mm socket for my HR adapters.
    is it a 6pt or a 12pt? thin wall or other?
  2. #162
    Feb 2002
    9,398
    ok, so had a chance to try the slicks, they are eh..... at startup, they make the truck jsut torque sideways hard to the right.... once i get moving, they are pretty decent though.... awesome drifting... they do seem a little softer now though... I did do a burnout, and it seemed to have helped
    now, with the 17mm HR, the nuts on the left side come loose on their own....
    My new wrench, big bone, and arrma wheels are out for delivery... just nervous to crank down on these things, as I think that is why I blew a 12mm wheel, because the hub was tight
  3. #163
    Apr 2016
    23
    Jimbo update the thread.
  4. #164
    Feb 2002
    9,398
    what do you want updated? got my big bone in the mail today, my arrma wheels and my wrench
  5. #165
    Apr 2016
    23
    Your first post/thread isn't showing the image.
    Nice keep us updated with images.
  6. #166
    Feb 2002
    9,398
    Quote Originally Posted by DatGuyAsh View Post
    that is because those pictures have been removed and replaced
  7. #167
    Jun 2014
    Southern California
    7,591
    6 point. Don't know if it's a thin wall or not, but it fits in my F-11's!
  8. #168
    Feb 2002
    9,398
    big bone is in
  9. #169
    Feb 2002
    9,398
    so ran it with the big bone, is it supposed to be that loud?!
    remember that gear noise I originally had? this sounds like that, but way worse... I did leave the bone slightly loose in the cups, with the 2 orings on each end, should I tighten them down? I don't think so, there is almost no play in my slipper shaft forward and aft now.... sounds like a 2 stroke motor......
  10. #170
    Jan 2016
    305
    LoL I have the same thing with the big bone. It's like a dragging clanking sound. I was told and read forum posts that the big bone hits the chassis in a spot in the front tunnel. I haven't had it apart to check. But some people just run it and the big bone will wear it's groove, others dremel the area for clearance.
    Sent from my SM-G900V using Tapatalk
  11. #171
    Feb 2002
    9,398
    Quote Originally Posted by Tacobox View Post
    yeah, I have heard that with the HCG, but I run the LCG, I looked it isn't touching anywhere, I just don't want it to jam up from not having enough play, or cause any problems... The noise may just simply be the drive pin in the bone contacting the drive cup
  12. #172
    Jan 2016
    305
    I dunno, I've got the lcg as well. I'm not sure. I've only got 5 min tops of run time on my build. So I don't know what is making the noise. But pull the big bone out, put stock in...noise goes away
  13. #173
    Feb 2002
    9,398
    yeah, I know it is the big bone, it is the only thing that has changed, and it wasn't like that before
  14. #174
    Jan 2016
    305
    I was at a loss too. So when you figure it out let me know. I'll be home later tonight. Maybe if I'm feeling like it I'll rear mine apart too.
  15. #175
    Feb 2002
    9,398
    I know exactly what it is, it is the big bone, nothing to take apart, the stock isn't as noisy, but it also doesn't have a pin and cups
  16. #176
    Sep 2015
    2,243
    I'll be honest, I'm not sure what the point of the big bone driveshaft is. The stock one is light, and has 6 points of engagement. I guess if the chassis is twisting a lot, the big bone allows some movement in the two ends and will still maintain smooth drive, but I use a chassis brace and so my chassis doesn't flex at all in the driveshaft direction.
    youtube.com/c/RazorRCvideos
  17. #177
    Jan 2016
    305
    I did it because of the mmx/2200 set up and potentially running 2.8 tires. My buddy ate up 2 stock shafts from the torque. So I just went ahead and followed him and went big bone from the start.
  18. #178
    Feb 2002
    9,398
    So I am actually running it, because it was only $20, is supposed to be an upgrade, and my stock, hollow one is cracking at the teeth
  19. #179
    RC Turnbuckle Jr. GeneralPede01's Avatar
    Sep 2015
    Toomsuba, Ms
    3,187
    I use the traxxas handle part number tra5480. It was cheap and works like a charm.
    Member of the triple digit club 100mph p4de
  20. #180
    Feb 2002
    9,398
    yup, that is what I got
  21. #181
    Feb 2002
    9,398
    got my Team Associated Factory Team 4mm turnbuckle wrench, it is awesome
  22. #182
    RC Qualifier Swampthing's Avatar
    Houston, TX
    472
    It's the Tekno front diff out drive rubbing. It has to be. Everyone with an LCG has the issue. I bet if you look at the underside of the chassis it will have rub marks. On visual inspection and even manually rotating the drive shaft I didn't think mine was rubbing either, but under throttle it sounded like a 2 stroke motor just as you described. Not enough contact to cause any resistance but just enough to make the noise.
    Rustler | MERV | Summit | Slash Ultimate | Slash
  23. #183
    Jun 2014
    Southern California
    7,591
    Watch from 6:01:
  24. #184
    Feb 2002
    9,398
    well, i know what i am doing tonight...... grrrrrrrrr
  25. #185
    Apr 2015
    The ICT!
    943
    The grind only takes a second or two.
    Slash, Street Rally, 4x4 /Slash, Summit LT, Aton.
  26. #186
    Feb 2002
    9,398
    yeah, but my good tools aren't here so I just took it apart with regular allen wrenches... joy..... anyway, I will take a pic, it looks like it did rub a little bit..... and it is easy to see because My chassis was dyed black
  27. #187
    Feb 2002
    9,398
    I think the issue I was thinking of was rocks in the driveshaft..... not this
  28. #188
    Sep 2015
    Toomsuba, Ms
    3,187
    I had thought of getting a big bone, but the stock seems to be doing fine so I decided against it. Plus with my center driveshaft mod I can't run one.
  29. #189
    Feb 2002
    9,398
    so, I haven't run it yet, but it does seem a lot quieter
  30. #190
    Houston, TX
    472
    Bingo! That noise was obnoxious wasn't it!
  31. #191
    Feb 2002
    9,398
    I am not 100% it is gone, but it does sound better initially
  32. #192
    Feb 2002
    9,398
    those slicks are pretty grippy.... I drove around on very dusty, smooth concrete without issue, there was sliding going on, but that is to be expected. These tires were actually pretty decent once they warmed up a little bit
    also got my toe/camber a little more dialed... it is running pretty good at this point, but I want to gear it to make it faster.... with less initial torque, because I love WOT and just spin out when I goose it from a stop --- that could also be due to the 100k in the rear.... maybe I should try some 50k (don't have) or some 30k (which I do have)
  33. #193
    Sep 2015
    2,243
    Loosening your slipper a little would probably help. Primitive form of traction control.
  34. #194
    Feb 2002
    9,398
    no. I run aluminum pads......
    not yanking the trigger would probably help too
  35. #195
    RC Champion thesmogman's Avatar
    Oct 2013
    Dublin, CA
    1,249
    Mister lead finger...... By the way I think you left half of your tires here. Ha Ha!!!
    With 100k in the rear both wheels light up and you lose traction. I am running 5k rear so I think your 30k would improve your handling. You could loosen the slipper a little too. I know you don't want to but there's a point where you are going to have to live with a little bad handling then.
    Moving your battery back did help a little. Had fun the other day!! Thank's
    Slash 4x4 Tekin RX8GenII w/Pro4 4300hd
  36. #196
    Feb 2002
    9,398
    I am going to try and fry my MMP. Since I got "mine" back after a wire replacement, it hasn't been the same, I think they actually swapped it with a defective unit, that was "refurbished" Castle has been giving me the runaround on this ESC, while I like Castle's software, I did not like being lied to by their "techs"
    put 30k in the rear, and changed gearing to 19/50
  37. #197
    Sep 2015
    2,243
    Turning down the throttle expo on your radio would help a little also to lay down the power more smoothly.
  38. #198
    Feb 2002
    9,398
    Quote Originally Posted by RazorRC22 View Post
    nah.... it's a choice...... turning down my lead finger would help more
  39. #199
    Feb 2002
    9,398
    45.85 MPH today!!!!
    not sure if I am hitting LVC or thermal overload... but at that time, I temped the motor, and was at 170*
  40. #200
    Feb 2002
    9,398
    so, it is definitely thermal shutdown.... blinking red and yellow
