    Aug 2014
    57
    Seeling the spartan
    So towards the end of last year, i upgraded to the wholts piano wire drive. Its nice, but obviously much smaller in diameter than the stock flex cable. Which leads to my point. How do i seel that or reduce the hole so water doesn't poor in. I tried stuffing the whole thing with greece but it only worked for like 5 minutes.
    All help is appreciated.
    Thanks
    RC Champion traxxasfan21's Avatar
    Nov 2015
    in sunny CA
    1,113
    You may have to go back to the stock shaft (or at least the diameter)
    Too much power is just enough
    Jan 2014
    Ohio
    809
    You could put a Teflon liner in your stuffing tube or possibly put a bushing at the end of the shaft near the prop. Don
    Feb 2016
    10
    Teflon liner is the worst thing to add to any high-performance (6S+) boat.
    It causes the cable to kink from the friction and explode. If running say 4S or less it won't matter because it won't generate enough friction to matter.
    Aug 2014
    57
    So get a bushing for the end of the drive shaft before it goes to the strut? Also, im running a wire drive. Does that really have that much friction? And where does one get a bushing to fit the wire. It is .078 in. Diameter i think. Its from jeff wholts.
    Aug 2014
    57
    Would the .078 wire fit in the .098 teflon liner? Thats the closest size i can find on OSE.
