Page 2 of 2 FirstFirst 12
Results 41 to 72 of 72
  1. #41
    Nov 2015
    113
    Im going to order a 53t pinion from Kershaw and step down to 4s on one of my xo's.
  2. #42
    Nov 2015
    113
    Traxxas drive shaft supplier might get a bonus this year
    Dejavu?
  3. #43
    Nov 2015
    113
    Ran 2 6s tonight. 22/56 gearing.
    Inner rear joint snapped.
    Im going to run low grip pmt slicks instead and see if it helps.
  4. #44
    Oct 2015
    880
    You keep breaking stuff with those GRPs. Have you thought about just running the stock tires or is that not an option at this point?
    Catch my videos at youtube.com/c/offworkhours
  5. #45
    Nov 2015
    113
    My second xo is converted back to stock.
    Its working great for speed runs.
    Ill give the pmt's a try and if i keep breaking axles its back to stock.
    Btw snapped inner joint last night.
    So they last ~2-3 6s packs
  6. #46
    Oct 2014
    United Kingdom
    59
    In what situation are you breaking the joints though? Is it when you're accelerating or any specific situation? also what settings are you running on your ESC?
  7. #47
    Nov 2015
    113
    Avcr =100% decreased punch
    dragbrake and initial brake reduce to 15% on skyrc beast.
    Not sure if I kill them during braking or acceleration.
  8. #48
    Oct 2014
    United Kingdom
    59
    AVC is one thing, but you'll also need to change the punch setting in the ESC itself. The AVC is merely like a traction control system, not a true punch setting adjustment, so you'll need to dial that back a bit.
  9. #49
    Nov 2015
    113
    Did a run with my second xo.
    factory punch is set pretty high.
  10. #50
    Nov 2015
    113
    Ran my second xo with stock tires.
    25+ 100mph runs.
    stepped up to 8s and did a couple of 90mph runs.
    Hit full throttle and got air born at 100mph.
    8s with 5892 got some insane acceleration!
    Broke one tie rod.
  11. #51
    Nov 2015
    113
    Im going to tune the 8s down to 4s to avoid snapping axle/inner joint.
    huge 43t pinion from KD ☺
  12. #52
    Nov 2015
    113
    43t vs 34t
  13. #53
    Nov 2015
    113
    This thing is just getting slower.
    Factory tires took care of the axle problem.
    Now with 43t pinion and 48 spur 1340kv motor its down to 85 mph.
    I bet that my move jumping to a single 6s battery instead of running paralell just caught up on me.
  14. #54
    475
    or just ebay.com Bruckner hobbies......
    Quote Originally Posted by Superlead View Post
    German Ebay.de got PMT and GRP
  15. #55
    Aug 2016
    30
    Are these the tires you guys are getting?
    http://www.ebay.com/itm/SP-Sedan-Rac...YAAOSwfcVULytc
  16. #56
    Aug 2016
    4
    I have been using foam tyres on mine after the first 10 runs. I balanced the rubber wheels they still distort at speed and cause lots of speed robbying for the car. With the rubber wheels it run 135k's put the foam wheels on next run was 180k's with no other changes.
    Now with a bit of other mods I'm doing 240k's for most runs and have never broken a drive train part.
    https://youtu.be/A7gYmVtMpBc
  17. #57
    Jan 2014
    377
    what axles are you using? have you thought of using MIP axles?
    may want to try foams, they will offer some slippage under hard acceleration from a dig more so that your PMT's
  18. #58
    Nov 2015
    113
    Stock xo-1 axle. Do you have a link for a stronger version?
  19. #59
    Aug 2016
    Houston, Texas
    607
    Tekno has the M6 drive shafts, but they might not fit the XO-1, but you might be able to use the XO-1 axles, and the Tekno shafts with a little mod work
  20. #60
    Nov 2015
    113
    The inner ball joint connected to the differential and the outer ball joint on the splined shaft are the weak spots. Ive not found anything to replace those. Do you have a link to the tekno shaft?
    is it tkr6852x?
  21. #61
    Aug 2016
    Houston, Texas
    607
    that's the one. it looks like it has a part that connects to the differential that might be tougher that the stock. also the dogbone style eliminates the splined shaft. i saw a forum where somebody changed out the stub-axle to the xo stubs. you might also be able to find it without all the extra hubs and stuff, since you probably want to stay with the XO aluminium.
  22. #62
    Jan 2014
    377
    I thought MIP made axles/cv for XO1 but its for the slash 4x4.
  23. #63
    Nov 2015
    113
    MIP might need a slash 18 mm adapter from rc hornet.
    Tekno still got some weak spots also.
  24. #64
    Nov 2015
    113
    Jumped down to a 1550kv 5874 with 43t pinion.
    Did 109 and ended up killing my 8s esc and battery.
  25. #65
    Mar 2017
    31
    you dont need these big lepord motors i have see a xo1 with a castle 2200kv 1515 go 125
  26. #66
    Nov 2015
    113
    I know, difference is that I can do speed runs constantly without over heating.
  27. #67
    475
    Thank you! It's all about the heat!
  28. #68
    Nov 2015
    113
    Did a full setup for both my xo's.
    Just like Ive noticed IRL the stock setup is not optimal.
    And I used a chassis setup system to dial in camber and toe.
    And my corner weight is now as i want it.
    If it pull to the side during acceleration corner weight might be the main issue.
    My street tweaked xo had good suspension and weight setup.
    Camber was too much off in the rear.
    Had 2.5* and now its 0.5*.
  29. #69
    Dec 2015
    Europe - Portugal
    182
    From last photo you changed the position of the rear shocks...can you post how to?
    And why changed it? To have more easy acess to change pinion's?
  30. #70
    Dec 2015
    Europe - Portugal
    182
    Well i figure it out doing it on mine...just reverse the LEFT and RIGHT A-ARM and nothing else. Now the question is why? Beneficts if any?
    -Will try mine with this config and report back!
  31. #71
    Oct 2015
    880
    People swap the side the springs are on so the larger pinion gears do not hit the spring or the a-arm
  32. #72
    RC Racer kzsteve's Avatar
    Jan 2018
    norcal
    247
    maybe geared to high for motor to pull
    XO-1 GUY GETTING OLDER BY THE MINUTE
