Results 1 to 12 of 12
    Jan 2016
    13
    Should i run my battery till its completely dry?
    I run my batteries till the car stops moving.
    Is this harmful to the motor or the battery?
    Currently i am driving a rustler with a brushed motor.
    RC Qualifier jcpede's Avatar
    Dec 2015
    Just follow the tire marks and broken parts.
    439
    You can drain them as much as you want and you'l be fine
    RC is an addiction just don't make me go to rehab
    RC Qualifier WonderMelon's Avatar
    Mar 2016
    Myerstown, Pennsylvania
    957
    NiMH batteries should be used until they're dead.
    RC Qualifier Panamon Creel's Avatar
    Oct 2014
    Central Mexico
    427
    Stop as soon as you notice that the acceleration gets sluggish otherwise the battery will heat up a lot which is not good for the battery. Even better if you stop a bit earlier since the deeper the discharge the shorter the overall battery life will be ( that goes for all rechargeable batteries )
    Dec 2004
    PA
    4,083
    Posts #2 and #3 are incorrect. Post #4 is correct.
    DO NOT DISCHARGE A NIMH BATTERY PACK ALL THE WAY TO EMPTY!
    20,527
    Quote Originally Posted by Jakey View Post
    What he said.
    Alt-248 on the number pad =
    Dec 2013
    42
    Can you ellaborate a little bit on that? Should you immediately fully recharge the NiMH's? Let them cool off for a little while? Put a half charge on them? Leave them completely discharged? TIA
    Mar 2016
    957
    Let it cool down. Put a full charge. Leave them charged. Heck I'll be wrong probably so...
    13,530
    Let it rest and cool, then put on a full charge. If they sit for a bit without use, occasionally top them off or cycle them.
    You don't want to run them down till they die, the lowest I take them down is around 1.0v per cell. 0.9v/cell is the lowest and any lower will cause damage. Plus they don't have the "memory effect" like nicd batteries do so you can charge them at any point.
    Trenton, ON, Canada
    138
    If you discharge a NIMH till dead you are in danger of the cells going to reverse polarity. I have a pack where one of the cells went reverse.
    Trenton, ON, Canada
    138
    In furtherance to a cell going to reverse polarity, the affected cell will not except a charge, it will get really hot and will start to vent.
    Feb 2014
    Kansas City Missouri
    13
    Glad I saw this post because I ran my NiMH's down till they were stone dead yesterday. First timer here.
