Results 1 to 11 of 11
    Feb 2016
    118
    Thumbs down Engine just put back together and not running well
    Just put my 3.3 engine back together and now it only runs if I put the throttle. Dies immediately after letting off the throttle. It's the same type of sound as when one runs out of fuel while driving. Is this sound like an air leak of some sort?
    http://<a href="https://youtu.be/OGX...GXaFsWR700</a>
    Feb 2016
    118
    Video Link Of Engine Problem
    13,707
    Make sure the cutout on the piston faces the carb. Good way to tell is to pull the header and look through the exhaust port and when the piston gets to TDC and you can see the rod you'll need to flip it around.
    RC Qualifier rigelkent09's Avatar
    ILLINOIS
    289
    Quote Originally Posted by rpage1979 View Post
    DG is right, did that mistake before and the problems are same as yours, the cut out on the piston should face the carb...
    RC Champion MaXXL's Avatar
    Nov 2015
    South Florida
    1,222
    Also the hole in the conrod needs to be oriented correctly. I dont remember which way it faces tho.
    10 RCs and counting 😅
    13,707
    Quote Originally Posted by MaXXL View Post
    Carb .
    Feb 2016
    118
    Thank you very much! I am sure that is my problem as I did not pay attention to that when I put it back together. Also, do the small notches on the inside of the back plate go towards the top?
    Feb 2016
    35
    Yes they do
    Feb 2016
    118
    Quote Originally Posted by leblancchris View Post
    Yes they do
    Thank you!
    Feb 2016
    118
    That indeed was the problem. I disassembled it and the cutout was facing the exhaust port. Haven't started it back up yet but hopefully that's all it was. Thanks again for the help!
    Feb 2016
    118
    Started it up last night and it ran like a champ! Amazing what problems a backward piston will cause haha!
