Results 1 to 18 of 18
    Jul 2013
    37
    Aluminum vs RPM vs Stock parts
    Just wondered what the consensus was here on aluminum vs RPM vs Stock replacement parts. I have zero aluminum aftermarket parts on my trucks. If I break something I usually upgrade it with RPM parts i.e: arms, bumpers, nerf bars... My thought process is that rpm is a higher grade of plastic but will give when impacted, and is cheaper.
    That said, I just replaced my front wheel bearings in the slash and when the bearings went they took the blocks with them. I was about to buy RPM blocks and thought twice before buying stock for 5 bucks. What do you all do?
    Feb 2016
    11
    Rpm to me is the best.
    Aug 2015
    NSB FL
    136
    Rpm in some parts, aluminum on others. Depends on what the job of the part is
    RC Qualifier FROSTYEYE's Avatar
    Nov 2015
    NJ
    396
    It really depends on you, I've snap rpm parts just as easy as stock, I believe the aluminum for the blocks and the carries is the way to go, tightens up suspension and with stands more abuse than plastic.
    If it cant be broke, I'll break it.
    Apr 2015
    The ICT!
    943
    Depends on the build.
    If It's a basher, all RPM. Make it a big, bendy indestructible thing. Gumby with wheels.
    If it's a racer, you are going to want more aluminum and stock stuff, as it is stiffer and more precise in it's function.
    Slash, Street Rally, 4x4 /Slash, Summit LT, Aton.
    Feb 2002
    9,356
    Quote Originally Posted by Doogamaster2817 View Post
    that ^^^^^^
    Feb 2013
    Montreal, Canada
    5,590
    Akuminum c hub and carriers for me, aluminum motor mount amd traxxas hd motor plate ( acts as a better heatvsync than stock), rpm ams or stock shock towers, vxl camber and steering links, aluminum bearing adapter.....
    Live life to the fullest
    Feb 2013
    Montreal, Canada
    5,590
    Aluminum c hub and carriers for me, aluminum motor mount amd traxxas hd motor plate ( acts as a better heatvsync than stock), rpm ams or stock shock towers, vxl camber and steering links, aluminum bearing adapter.....
    Indianapolis
    14,199
    The Ultimate and Platinum Edition Slash 4x4 trucks have close to the perfect amount of aluminum parts. Add an aluminum motor mount and you are good to go!
    Apr 2014
    Illinois, USA
    20
    I love all rpm parts.
    Jul 2013
    37
    I like RPM as well. Does anyone have RPM C hubs and steering blocks? Do they get damaged when the bearings go bad?
    Nov 2013
    North Carolina
    121
    🏾️exactly what I have.
    Jul 2013
    37
    Thoughts on brands of aluminum parts? ST racing= good quality?
    Apr 2015
    The ICT!
    943
    Quote Originally Posted by Super67Nova View Post
    I do on my 2wds. Never had an issue with a bad bearing messing them up. I'm not sure how that even happens, unless the bearing gets so bad it seizes up and you start spinning it in the hub. I like these RPM parts, but they are flexy...which can be a downfall for steering parts. If you are bashing, perfect, if you are racing or want precise steering without a lot of play you are better of aluminum on these parts. My 2 cents.
    STRC or Traxxas brand are fantastic quality. Love my STRC stuff.
    RC Champion MikeMcE's Avatar
    Feb 2016
    Deep in the Everglades
    1,291
    BINGO!!!! I added the traxxas aluminum shock towers, a HR roll bar(ties front and rear together) and a TKR6855 – Big Bone Center Driveshaft and Outdrives .
    Truck is now very tunable with those GTR shocks!
    RPM makes great stuff, if you plan on destroying your arms.....I use them and cant break them
    HANG UP AND DRIVE!
    Slash 2wd 4x4
    PRO MT Yeti 4x4
    Feb 2016
    1,291
    Quote Originally Posted by eldax View Post
    strc or traxxas brand are fantastic quality. Love my strc stuff.
    ditto !!!!
    HANG UP AND DRIVE!
    Slash 2wd 4x4
    PRO MT Yeti 4x4
    RC Champion traxxasfan21's Avatar
    Nov 2015
    in sunny CA
    1,113
    I just got my first STRC product (slash 4x4 bellcrank) and it seems very high quality but I have yet to see
    Too much power is just enough
    Feb 2016
    1,291
    Quote Originally Posted by traxxasfan21 View Post
    I used that on my 2wd......fit was a bit of work, nice , tight and smooth with the bearings
    HANG UP AND DRIVE!
    Slash 2wd 4x4
    PRO MT Yeti 4x4
