Results 1 to 8 of 8
Thread: Carb install
    Feb 2016
    35
    Carb install
    This is going to sound weird, but it's driving me nuts.
    I just rebuilt my trx 3.3 and carb.
    I'm trying to put the carb on, and it won't go all the way in. I don't want to force it because I just bought this new carb body.
    It feels like it is under pressure. I have tried moving the piston in different positions and have had no luck.
    I dont even have the head on yet...
    Please help.
    13,707
    Put the lower o-ring down in the block. The other o-ring is around the carb throat. As you push it in, give it a twist back and forth to fully seat it past the lower o-ring.
    Feb 2016
    35
    The lower o ring is in the block, the other is on the body. It won't go past the lower o ring even with twisting... I even tried my old carb body with the same result.
    13,707
    Remove the lower o-ring and reinstall the carb and compare the difference with how far it goes down. You may need to add a little lube to the o-ring to assist with seating the carb.
    Feb 2016
    35
    Took the o ring out and it went in no problem. Put the o ring back in and twisted it and it went in. Took it off and they was a piece of o ring the thickness of a hair that had been sheared off. Now it will go in with only minimal pressure (not too loose though) Thanks!!
    RC Champion MaXXL's Avatar
    Nov 2015
    1,222
    Well you should change that o ring now. Its been pinched and may not seal.
    Or just run it anyway while keeping an eye out for symptoms of an air leak. Just until its time for a carb rebuild.
    10 RCs and counting 😅
    Feb 2018
    East Central Oklahoma (SW Florida in heart!)
    That's great! Thank you so much. I've had this issue on a 3.3 and a 2.5R engine. I just couldn't figure out why they wouldn't seat properly. A little silicone grease and some twisting, and they both seated great. Again, thanks for these posts, I appreciate it much.
    Oct 2005
    19,503
    I always use a little nitro fuel on the o-rings, usually does the trick.
    All Lives Matter
