Page 2 of 2 FirstFirst 12
Results 41 to 74 of 74
  1. #41
    Mar 2016
    1,162
    Quote Originally Posted by Manne View Post
    Nope. Four batterys totaly, all 4s. Two and two paralell connected in series after the paralell adapter .
    Cool but I wanna see how yours is setup,if u can post a pic it'll be nice,thanks
  2. #42
    Apr 2016
    10
    For anyone thats running the MAX6, any cogging issues? I have a brand new Mamba X I was thinking of trying but I would love having the ability to run 8S and not have to worry about the Mamba X's 120A limit.
  3. #43
    Dec 2015
    104
    Quote Originally Posted by jeb05 View Post
    None here. Very smooth on stock settings, almost sensored quality.
  4. #44
    Feb 2016
    Covington, LA
    106
    Very minimal cogging here also using a Max6 geared 17/50. Way smoother than the stock ESC, even geared up a bit. Geared back down to stock or slightly lower, I could probably use the truck to crawl with thicker diff fluid.
  5. #45
    57
    Ok. So I got the Max 6 installed.
    Punch was set to 5.
    Let me tell you, my Xmaxx is a brand new beast.
    Don't expect it to gain so much speed, but do expect a major increase in acceleration and torque.
    This thing now picks up acceleration like crazy and wheelies are easily made from half throttle.
    So if you are in thinking about getting the HW Max 6 ESC do not break your head, JUST get it. You won't regret it.
    Installation was very easy and it fits like if it came with the truck.
  6. #46
    57
    Now, can somebody please give some advise on the following:
    Can I use the Leopard 5892 1340KV with the Max 6 ESC without a problem?
    I know the Max 5 is the one used mostly with the Leopard motor.
    Anyone?
  7. #47
    Jan 2016
    162
    Yes that motor will work perfectly with that esc, but I believe you will have to relocate the esc up front with the Kershaw mount or make your own because of the motors extra length.
  8. #48
    57
    Here is my setup on the MAX 6.
    Again, this thing is a beast compared to the stock.
    It's like adding a 150 shot of nitrous on your Muscle car
  9. #49
    Mojave Desert
    3,013
    NICE! Glad to hear its a big upgrade over the stock!
    oh and did you get the program card? if so, which one? link?
    We are all one race. The human race.
  10. #50
    57
    Quote Originally Posted by G-Rustler View Post
    I did not use a program card.
    I just used the manual selections which you adjust with the select button on the ESC power switch.
    It is very easy to adjust once you know what you are doing.
    Just read the instructions and follow them as it says and this things is very easy to adjust.
    But yes, it is definitely worth every penny on this upgrade.
    Can't wait to put in the Leopard motor
  11. #51
    Feb 2016
    Covington, LA
    106
    Yunior, the problem with trying to use the Leopard 5892 along with the Max 6 in the stock ESC location is there is simply not enough room. Kershaw Designs confirmed this for me when I emailed them. Their motor mount places the motor 10mm closer to the ESC, and after taking measurements I found there's no way to for the motor using the KD mount. In fact, even the 5882 motor (which I believe is actually only 56mm in diameter) would be a very tight fit. However, the new 5874 will likely fit using the KD mount, but the verdict is still out as far as it being more powerful than the stock motor. Someone do that conversion and report their results please!
  12. #52
    Mar 2016
    1,162
    Max6Maxx- what's do u have your lvc set at on your Max6? I have mine set on high is it suppose to cutout at 3.7v?
  13. #53
    Feb 2016
    Covington, LA
    106
    I also have mine LVC set to high. My voltages after the batteries cool are between 3.65-3.70, which is perfect in my opinion.
  14. #54
    57
    Quote Originally Posted by Max6XMaxx View Post
    Thanks for the feedback.
    I guess I will go ahead and get the KD mount just to be safe.
    No biggie.
  15. #55
    Mar 2016
    1,162
    Oh ok cool when I took off the battery it warm and a bit swollen voltage was 3.75 but I didn't check when it cooled down already..
  16. #56
    Mojave Desert
    3,013
    Quote Originally Posted by Yunior View Post
    Punch was set to 5.
    Are you using Traxxas connectors?
    EDIT: disregard, the photo above answers my question
  17. #57
    Mar 2016
    1,162
    I have the Max5 I'm using Traxxas connectors and they're working fine,
  18. #58
    Mojave Desert
    3,013
    Quote Originally Posted by PATS4LIFE View Post
    Cool. That was my next question lol was wondering if the trx connectors were holding up with max ESC's. I should be ordering my Max6 soon.
  19. #59
    Mar 2016
    1,162
    I'm loving my Max5 truck is a different beast even with stock motor,,I'm pretty sure You will love Max6 esc
  20. #60
    141
    when installing the plugs on the end of the max 6 esc (the 3 wires That go to the motor)
    How long do you make them? I don't have my oem stuff to see.
    it got returned to traxxas under warranty which they replaced but I did purchase a max 6 as well
  21. #61
    Mar 2016
    1,162
    Quote Originally Posted by olliewog View Post
    I have the Max5 which is mounted up on the rail,my wire is about 31/2 inch but since u have the max6 maybe 2-3inch is good.
  22. #62
    Feb 2016
    jersey
    236
    If you route the max 6 wires towards the motor then come back to the front of truck you wont have to shorten them. That's how I did my install anyway.
    Fortenwinkler
  23. #63
    57
    This is a video of me with the new Max 6 ESC. Running on 18/50. This thing is a beast
    https://www.youtube.com/watch?v=gNtUYOqRziw
    No cooling issues at all.
    Everything was warm to the touch.
  24. #64
    Apr 2016
    10
    Awesome video Yunior. Nice job with the Phantom.
  25. #65
    57
    Thanks. It was actually shot with Gopro 4 and DJI Inspire.
  26. #66
    Mississauga, On.
    16
    So a quick question.. installing the max6 shouldn't interfere with the telemetry right? Since the telemetry module is plugged into the traxxas receiver.
  27. #67
    Dec 2015
    10
    Which batteries are you guys using with the Max5/6 setups? Stock truck geared 18/50 cooked 2 pairs of Traxxas 3s 5000 lipos in just 4 runs. Considering the Max5 or 6 but want to make sure I don't get batts that are going to puff.
  28. #68
    Mar 2016
    1,162
    Quote Originally Posted by Fairplayinc View Post
    Right now I'm still running 3s 5000mah Traxxas its puffing after runs but it's been 12 cycles of usage it becomes normal when it's cooled down,also running smc 4s 5200mah 60c(hard case)only had 4 runs through it but so far no issue
  29. #69
    RC Champion SLW-SVT's Avatar
    Lake Jackson, TX
    1,638
    i've been leaning towards the MMX but this thread makes me think the max 6 would be better. decisions decisions
    X-Maxx Max6 | EB48.3 | ET48.3 | Axial Grave Digger
  30. #70
    Jul 2016
    70
    18 54 max6 running 8s no cogging here as well
  31. #71
    Jul 2016
    70
    https://www.youtube.com/watch?v=beRsin_62wo
    Hi guys just ashort vid of my Xmaxx at the beach,running Max6 8s esc 18 54 i am loving this Truck
  32. #72
    Jan 2016
    97
    Is there any waterproof esc with datalogging ability for our truck? I'm close to ordering the Max5 or maybe max6 esc but I would love to have the possibility of setting it up and logging data with a computer. I can even do that on my tiny 20A racequad esc's so why not on these
  33. #73
    Mar 2015
    Baton Rouge, LA
    216
    Quote Originally Posted by minim View Post
    I haven't found any capable of that. The main issue seems to be that they all have huge cap banks which can't be sealed easily.
  34. #74
    Jan 2016
    97
    But the cap's themselves are sealed so then it should only be the connectors to the circuit board that is the problem. Don't the Max5/6 have the caps open like all the others? There are huge voltage spikes on brushless ESC's so those cap banks are needed. I've measured this on a 40A ESC and with/without cap's is a huge difference.
