    Jan 2016
    37
    48p to 32p equivalent
    hi guys I'm back
    I wanted to know in a quick and simple answer, if i could (a) get a 86t 32p plastic spur gear, or (b) get one of you guys to give me an equivalent setup. I run on a 2s 5000mah lipo and a 3800kv castle motor in my Slash 2wd. Basically, I stripped my spur gear, and I was running 23t/86t with 48p gears and they stripped. I want to have the same performance as I had before, but I want to use 32p for the bigger teeth. I want the spur to be plastic, obviously because i don't want transmission problems.
    Thx
    P.S. I already have a 20t 32p pinion on hand, so if i could get the same performance as the 23/86 48p setup using that gear, that would be convenient.
    Jul 2014
    NAWLINS
    3,952
    14/58 should be close to 23/86.
    T/SportMax/Slayer Pro/Bandit
    Stampede/Rustler
    RC Champion MikeMcE's Avatar
    Feb 2016
    Deep in the Everglades
    1,291
    https://traxxas.com/forums/showthrea...=1#post6201929
    here you go, with pictures... Note your gear cover won't fit
    and I did this last week as I found a bag of 32p 1/8 shaft pinions
    HANG UP AND DRIVE!
    Slash 2wd 4x4
    PRO MT Yeti 4x4
    Jul 2003
    70
    Quote Originally Posted by MikeMcE View Post
    Hot Racing sells a metal 32p gear that will work with the cover
    http://www.hot-racing.com/index.cgi?...r=STE256;c=430
    Feb 2002
    9,401
    what caused your spur to strip in the first place? generally, they don't strip unless of improper setup or mechanical failure of something else
    yes, plastic is what you should use, metal is all bad... ends up being a bandaid for improper setup, and requires expensive, hardened pinions
    Feb 2016
    1,291
    Quote Originally Posted by tnafe View Post
    hot racing sells a metal 32p gear that will work with the cover
    http://www.hot-racing.com/index.cgi?...r=ste256;c=430
    sweet !!!!
    HANG UP AND DRIVE!
    Slash 2wd 4x4
    PRO MT Yeti 4x4
    Feb 2013
    Montreal, Canada
    5,590
    I have used both traxxas, robinsons and asscociated 32p pinions, have had great results with the first two and no the cover will not fit, however because of the strenght and size of the gears most obstacles and pebbles will be chewed; make sure kids fingures and yours do not end up there too.
    The 48p gears are graeta and smooth , more precise gearing but since I have a mojory of my rigs as 1/8 system I changed all mine.
    Live life to the fullest
    Apr 2016
    Central Cali
    20
    Also, for quick on-the-fly conversions between 48p and 32p you can just use a short conversion formula:
    Tooth count divided by current pitch, multiplied by the new pitch equals the new tooth count.
    In an example from 48 to 32 should be
    86t / 48p = 1.791666666666667
    1.791666666666667 X 32p = 57.33t
    The equation works both ways. I usually use it at the lhs when making purchasing decisions on the fly
    Pedal on the RIIght!!
