Results 1 to 16 of 16
    Mar 2016
    Southern California
    7
    Question Any essential upgrades for rally?
    Just curious if anyone has any suggestions for really important upgrades for traxxas rally.
    Sep 2011
    Iowa City, Iowa, USA
    4,355
    You will want an aluminum bearing adapter for sure. Other than that not really. Unless you want to start on durability upgrades like aluminum steering blocks and axle carriers.
    Mar 2016
    Southern California
    7
    I just picked one up from the LHS. Good thing i did that, i guess the bearing in the motor mount seized up. No more runs in the rain for me...
    Speaking of motor mounts, which one should i get? Theres a huge debate in the rally forums about KHZ vs HR or whatever other companies make them. I was thinking strc? From what i seen, its a really important upgrade
    Last edited by Double G; 05-08-2016 at 07:02 AM. Reason: merge, edit the post instead of posting more
    Jun 2014
    Kansas
    3,013
    Quote Originally Posted by onion978 View Post
    I still run stock plastic ones in the three that I have. I do have the hr mount but it's sitting in parts bin. I haven't really seen a change in temps. 2 trucks runs in 120-130 temp range my third one will run 150 temp wise
    I do have the the aluminum bearing adaptors on all 3 though
    Oct 2010
    3,143
    Here are upgrades I like:
    Mamba Monster 2 ESC with Neu-Castle 2650kv motor
    STRC aluminum shock caps
    Traxxas hardened steel, titanium nitride-coated shock shafts
    Traxxas sway bar kit
    Losi springs
    King Headz aluminum motor mount
    Traxxas aluminum slipper shaft bearing adapter
    VG Racing chassis brace
    Tekno drive shafts
    Tekno aluminum hexes
    Obstacle Magnet
    Mar 2016
    Southern California
    7
    I might look into those upgrades, see if my LHS has some of them...
    Mar 2016
    Southern California
    7
    I recently got the traxxas big bore shocks, do i need to purchase aluminum caps with those?
    or do the big bores come with aluminum caps already?
    Last edited by Double G; 05-08-2016 at 07:03 AM. Reason: merge, edit the post instead of posting more
    Jun 2014
    Kansas
    3,013
    The big bores already have aluminum caps even the body is made of aluminum. I personally would of just bought tin shafts and aluminum shock caps for the stock ones if I didn't want to spend the money. Since the big bores really ain't much of an upgrade imo
    Sep 2015
    26
    quick question here............the 2650 kv motor mm with esc you recommend..........can I use a 2s battery to power this setup?
    Oct 2010
    3,143
    Both my Sl4sh and P4de have a Castle 2650kv motor powering them. For ESCs, the P4de has the MM2 and the Sl4sh has the Sidewinder 8th. Either is great. Both trucks run surprisingly really well on 2S. 3S is almost too f-f-fast and 4S is stupid, crazy, insane.
    Obstacle Magnet
    Sep 2015
    26
    appreciate it
    Sep 2015
    26
    Quote Originally Posted by jvogel View Post
    Losi springs
    Tekno drive shafts
    could not help notice you said losi springs..........can you help me out with maybe some part numbers for fronts and rear.... I am doing some jumps on asphalt and cant seem to keep the nose from the ground even with good approach speed
    Oct 2010
    3,143
    Losi Springs Chart
    Losi Part #, Rate, Color
    2" Springs (for front)
    LOSA-5128, 2.5 lb., Red
    LOSA-5129, 2.9 lb., Orange
    LOSA-5130, 3.2 lb., Silver
    LOSA-5132, 3.5 lb., Green
    LOSA-5134, 3.8 lb., Blue
    LOSA-5135, 4.5 lb., Black
    2.5" Springs (for back)
    LOSA-5150, 2.3 lb., Pink
    LOSA-5152, 2.6 lb., Red
    LOSA-5154, 2.9 lb., Orange
    LOSA-5156, 3.4 lb., Silver
    LOSA-5158, 3.7 lb., Green
    LOSA-5160, 4.1 lb., Blue
    Obstacle Magnet
    Sep 2015
    26
    thanks many..........which rate in the back would you recommend as well oil weight..........the jang seemed to have a pretty good set up on his rally to slash 4x4 conversion
    Oct 2010
    3,143
    Really depends on what works for you. I don't run concrete and jump but that sounds quite dangerous and cool!
    Obstacle Magnet
    Sep 2015
    26
    lol its fun, but level landings are very important......otherwise parts bill go wayyyyyyyyyy up
