    Apr 2016
    5
    Question I want to change my Rustler to Bandit.
    hello~
    As you see above I want to change my Rustler to Bandit.
    I guess I need to parts. One is BODY and the other is front TIRE.
    If I change those two parts then my Rustler is to be Bandit??
    Jul 2014
    710
    there are several more suspension parts that make the bandit different from the rustler ,,, but that is a good start ....try that and see how it goes .....I like my bandit to be all bandit,,,
    but after all the upgrades ,,, it is not....
    Jul 2014
    NAWLINS
    3,952
    As Monkey stated there is more but a body and you will need both front and rear tires. To use the Bandit tires you may have to replace the stub axles.
    I run Rustler suspension on my St,Patty's Bandit...
    The one on the right is bone stock Bandit.
    T/SportMax/Slayer Pro/Bandit
    Stampede/Rustler
    Apr 2016
    5
    Thanks~~
    Mojave Desert
    3,013
    Quote Originally Posted by psy8219 View Post
    Yea if you just want the Bandit look then yea that's all you'll need.
    To make it a TRUE Bandit you'll have to change the A-arms, remove the hex hubs, shorter front axle, both rear and front tires are 2.2, shorter rear driveshafts and shorter camber links and steering links.
    Apr 2016
    5
    um... I see thanks
    Jul 2014
    NAWLINS
    3,952
    If you look closely the green one on the Rustler suspension is of equal height with appropriate 2.2 wheels. The only difference is the width. The green one is wider than the bone stock Bandit.
    Stampede/Rustler
